Undercarriage Rust... opinions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YodaTacoTuesday, Mar 20, 2020.
  1. Mar 20, 2020 at 3:40 PM
    YodaTacoTuesday
    YodaTacoTuesday [OP] Well-Known Member
    2013 Spruce Mica TRD Off-Road Access Cab
    So I'm looking at a 2013 ACLB TRD offroad in Michigan. Yes I know, northern state, rust comes with the territory. This truck has around 60k miles on it. I am wondering if the amount of rust underneath is par for the course on a truck like this or if I should reconsider the purchase. Take a look:
    Also, I noticed in the second picture there appears to be some brand new bolts and some kind of new bracket on the frame. Anyone have an idea what these would be and why they would have been replaced? Thanks
  2. Mar 20, 2020 at 3:42 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Por15
  3. Mar 20, 2020 at 3:43 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    That doesn't look too bad. Not bad at all in my opinion.
    Marc70 and pdaddy like this.
  4. Mar 20, 2020 at 3:49 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Look on the inside of the frame on the passenger side right next to the catalytic converter. That is where they trust out. If it is good then I would go for it. Just make sure when you get it to treat the rust that is there. Personally I would use a wire wheel on a drill and bring all the rust to bare metal then apply a chassis paint like por15 or chassis saver. Finally I'd fluid film the whole underside every fall and spring. I was stationed in northern MI for 1 1/2 years and did this exact thing on my truck. Very very small amount of rust over the whole winter and in the spring that small spot went to bare metal and repainted. Fluid film works great. Luckily I moved back south!
    YodaTacoTuesday[OP] likes this.
  5. Mar 20, 2020 at 4:04 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    looks like the frame was replace a few years ago.
    pdaddy likes this.
  6. Mar 20, 2020 at 4:07 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
  7. Mar 20, 2020 at 4:34 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I can't tell from the pics if it's a new frame, but it definitely has received the latest anti-corrosion treatment process. That's what some of those new parts are from.
  8. Mar 20, 2020 at 6:57 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  9. Mar 20, 2020 at 7:20 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Not safe to drive
    burrito782 and PoweredBySoy like this.
  10. Mar 20, 2020 at 8:15 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    These threads are comical.
    burrito782 likes this.
  11. Mar 21, 2020 at 4:40 AM
    Too Stroked
    Tom
    Truth be told, for a northern state where they use road salt, it looks damn good. I wish my 2014 that's lived its whole life in upstate New York looked that good. Don't let all of the southern California, never seen salt, panic mongers scare you. That's life up here and that truck will be just fine. I would Fluid Film or Crown the entire underside though.
  12. Mar 21, 2020 at 4:50 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Looks real good to me, for the area & age. On a '13 you've got frame replacement coverage to '25 if it turns to shit (unlikely). Buy it, coat with Fluid Film, and sleep well...:thumbsup:
  13. Mar 21, 2020 at 4:56 AM
    JK2TACOma
    JK2TACOma Well-Known Member
    Michigan
    19 TRD Sport DCSB Super White
    Sliders, Roof Rack, Bed Rack, Clear Coated Frame(diy) & Waxed Alot!
    Very good looking MI truck.. Lived here all my life. Nice Taco..
    You could use the fact that your a little timid about buying it to get a better deal, but I would not walk away from that rust at all
    We're is it at??, lol
  14. Mar 21, 2020 at 4:56 AM
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    That’s in great shape coming from MI. Either the guy took great care of it, or the frame has already been replaced...
  15. Mar 21, 2020 at 5:40 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Looks great,the surface rust on the welds is perfectly normal. Just do your due diligence and fine tooth comb it. I'd have no problem buying that truck.
  16. Mar 21, 2020 at 7:00 AM
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    Wire brush + Rust Bullet
    Crosis likes this.
  17. Mar 21, 2020 at 2:48 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    I remember seeing stacks of new Tacoma frames at the Toyota dealers waiting to be installed on those that had failed inspection, and those new frames (including their LCAs) were already rusting at the weld joints.
  18. Mar 25, 2020 at 4:02 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "passenger side right next to the catalytic converter" U R Correct Sir ! My frame was perfect because I coated it every year - I didn't see this spot and glad I didn't because I got a new frame because the tec that inspected it knew what you know "passenger side right next to the catalytic converter" Great Advice
  19. Mar 25, 2020 at 5:27 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Is this true, 2013 are included in frame replacement?
  20. Mar 25, 2020 at 6:03 PM
    That one old guy
    Chuck
    Stockish
