Undercarriage coating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MACKT28, Sep 6, 2024.
  1. Sep 6, 2024 at 4:55 PM
    MACKT28
    MACKT28 [OP] Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Moving to Utah and was wondering what everyone does for frame rust protection. My truck is a southern truck living in GA and the truck has been in GA its whole life and want to keep frame rust from happening. Wondering if I should surface prep and have painted let me know your thoughts.
  2. Sep 6, 2024 at 4:57 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    AllTacosFloat, bucktales and Jakerou like this.
  3. Sep 6, 2024 at 5:03 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    ^^^ This. Moved to Utah as well and only can find rubber undercoating. Presently going the spray can route. Do whatever you need.done prior to moving if you have a trusted mechanic. All the trades here get top dollar. Next year I will have a spray rig.
    Black97v6MT likes this.
  4. Sep 6, 2024 at 5:37 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    Fluid Film every year. Rust belt dweller here.
    E3g, skrazz and Why I oughta... like this.
  5. Sep 7, 2024 at 5:24 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    If the frame doesn't have rust, then I don't think any prep is needed. If there are rusty spots, wire brush, use some sore of rust neutrilizer (ie Metal Prep) and then paint.
    The suggestions above are great. I have my truck sprayed annually at Krown (just looked and don't see any in Utah). No mater which of these products is used, do the application annually. Stay away from the spray on stuff that gets hard and only requires a single application.
    When you do get the frame sprayed, drop your spare and skid plate 1st. Wash the frame to make sure it is reasonable clean before spraying.
    Just got my truck sprayed at Krown this week. 15th application since I bought it new. Spent its entire life in Canada.
  6. Sep 7, 2024 at 5:35 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Same here.
    Bought the kit several years ago.
    Set of ramps and a compressor and away you go. :thumbsup:
  7. Sep 7, 2024 at 5:37 AM
    bucktales
    I also spray inside the tailgate as well as the receiver hitch.
  8. Sep 7, 2024 at 5:42 AM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
    i am trying out the amber cosmoline product on a Gen2 Taco after painstakingly removing that rubbery tarlike frame coating the dealer applied as new
    it is Supposed to last Much Longer than the FF product and less messy to the touch than the WW product
    i have yet to tinker in the KROWN product but heard it is very good...
  9. Sep 7, 2024 at 7:09 AM
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I am sitting in a Krown lobby waiting for them to finish up as I type, haha.
    I saw a lot of "still looks great after 3 years" posts, but your truck is a fantastic endorsement. Lucky we have them near me here in the US, not many outside of Canadia.
    JAGCanada[QUOTED] likes this.
  10. Sep 7, 2024 at 9:38 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Rust belt person here. I would avoid any rubberized coating or any other coating that dries hard to the touch as they dry hard and eventually crack allowing moisture in, the moisture sets in there longer, and rust forms. Rust preservative coatings that dry hard don't flow as freely when applied either. I learned this from experience. I purchased an '87 Ford Ranger new, applied a type of coating that dried hard, and after a few years it started to crack, it was hard to apply anything over it to keep the moisture out. All I can say is after 17 years and how badly the frame had rusted out, plus other issues, I drove it to the junkyard and got some cash for it.
    ABA180 and O'DubhGhaill like this.
  11. Sep 7, 2024 at 5:57 PM
    O'DubhGhaill
    As others have written, do not use rubberized or hard drying coating. Zebart is the death knell of frames. Youtube vids on this.
    Stuck in VT likes this.
  12. Sep 8, 2024 at 5:14 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  13. Sep 8, 2024 at 8:02 PM
    Smills91
    Smills91 Well-Known Member
    Any companies similar to them in the South East US?
  14. Sep 8, 2024 at 8:05 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Worst case you can DIY with some Woolwax in your driveway..
    EveryDayIsTacoTues likes this.
  15. Sep 8, 2024 at 8:27 PM
    Smills91
    I'd like the first episode with my new to me truck be done professionally.
    Then I'd be cool DIYing it after that.
  16. Sep 9, 2024 at 9:54 AM
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Not that I am aware of; but I've not lived or looked any farther SE than I currently am..
  17. Sep 9, 2024 at 10:17 AM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    Knudsen likes this.
  18. Sep 9, 2024 at 11:25 AM
    Stuck in VT
    Utah
    2019 SR SX MGM
    Looks like patriotliner north of Atlanta in Cartersville does Krown. May be a little far for you in Southern Georgia but I come up with zero places in utah except the rubberized crap. Oildrop guy has video for diy. Assuming you're driving to Utah there may be a place along the way.
  19. Sep 9, 2024 at 6:35 PM
    ABA180
    East Bridgewater MA
    True, if there's nothing else to be done though I suppose. That said, I myself would rather just pay to get it done as wel.
