Under-hood lighting project
Discussion in 'Lighting' started by wordtothis, Feb 4, 2012.
  1. Feb 4, 2012 at 7:37 PM
    wordtothis
    wordtothis [OP] Well-Known Member
    david
    atlanta
    '11 DC SB, V6 4X4, 6spd
    Husky floor liners, in-channel vent visors, billies, khaki softopper, Wet Okoles, OTHER STUFF - kinda STOCKISH!
    I think I've probably seen something like this somewhere on this site before, and have wanted to do it for a while.
    SO, a trip to Advance Auto Parts, and $35 later, I went from this...
    (this is a picture of the hood open at night - no way to work on the truck without an external light source, right?)
    to this...
    the lights themselves...
    This pic is a bit misleading because they are actually super-small flexible LED strips, not some crazy stupid light bar, but they're so bright, they look enormous. The whole install is really stealth... when it's not on, and when it's not dark of course.
    the switch...
    Overall I am very happy with the result. The light is 100% usable and draws next to nothing, they could stay on for WEEKS and it would be just fine.
    For $35 between the "extra bright" LED strip lights, and the switch, and an hour or two snaking the wires around and shrink wrapping, the results are worth it.
    :D
  2. Feb 4, 2012 at 7:39 PM
    wordtothis
    david
    atlanta
    pics in the daytime would be much better to show the actual setup, but the nighttime pics are the most impressive in my opinion.
    D
  3. Feb 4, 2012 at 7:44 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Very nice! :thumbsup:
    Assuming it's not too much trouble I'd also like to see a little more of the wire routing and a parts list.
  4. Feb 4, 2012 at 8:00 PM
    wordtothis
    david
    atlanta
    not a problem man...
    I used these lights...
    http://www.alpena.ca/Product.aspx?id=1073
    with this switch...
    http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Metal-Bat-Toggle-Switch-Pre-Wired-10-Amp-(120W)-On-Off-Dorman---Conduct-Tite_5470137-P_N3138_A|GRP2037_____
    and then some 12/16 gauge wire I had on hand. Shrink wrapped it directly from the battery to the lights and the switch... - the lights draw next to NO current, so you don't need an in-line fuse or relay, so it was really easy.
    as far as the routing, I will post some more pics tomorrow during the daytime.
  5. Feb 4, 2012 at 9:25 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Great Install- I might have to give this a shot! Did you use an add-a-circuit?
  6. Feb 5, 2012 at 9:18 AM
    wordtothis
    david
    atlanta
    Pics from daytime (see below):
    Mounted light detail from passenger side of hood...
    Same light, different angle...
    Close-up of driver's side hood light...
    (Attention was paid to use existing seams and holes, no holes were added for this install - except for the switch mount on the plastic radiator shroud).
    Shot of light configuration during daytime to show positioning, (green line shows where wires were routed behind bodywork).
    Another green line-enhanced shot of the wire routing down the side of the hood...
    A shot of wire routing at hinge (green line shows route to body seam)
    Piggy back shot of wiring just zip-tied to existing wires for switch (improved visual with green line)
    No add-a-circuit here, just wired straight to battery, not enough amperage draw to necessitate any extra stuff.
    Notes to route behind body seams (especially where high-strength, one-time-use adhesive is used) - simply snake the wires behind the adhesive points, using some solid core wire as a snaking hook/hoop works really well. The routing of the wires took the most time, other than that, it was a pretty straight-forward and quick install.
    siniquezu likes this.
  7. Feb 5, 2012 at 9:24 AM
    Norton
    Green highlights make this very easy to follow/understand. Thank you!
  8. Feb 5, 2012 at 12:58 PM
    jep527
    jep527 Well-Known Member
    jerry
    Dickinson TX
    07 trd dc tacoma
    rear led blacked taillights, front headlights blacked out, grillcraft grill with lights behind, bed lights,black vinyl armrest,fog lights anytime mod,h1 minis 4300k,hood lights,
    looks good i put 2 small leds on my with a push switch to turn on when the hood opens.
  9. Feb 5, 2012 at 2:25 PM
    wordtothis
    david
    atlanta
    thought about the pressure switch route, but decided against it for simplicity's sake and it was not the easiest thing to find.
  10. Dec 19, 2014 at 4:42 AM
    bryanbyers28
    bryanbyers28 Well-Known Member
    Bryan
    Woodstock, GA
    2013 Black Tacoma 4x4 TRD Off-Road
    WeatherTech floor liners LED Map, dome, and license plate lighting Home made console organizer 30" LED Light Bar in lower grill Toyota Bed Mat
    So you have the positive and negative go to the toggle switch?
  11. Dec 19, 2014 at 5:04 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If anyone is looking to do this, Ford F150's have a hood pressure switch on their vehicles. The part is $20. If anyone is looking for a way to make their lights come on when the hood is opened, that switch wouldn't be a bad option.
    No, power into the switch from the battery, then power from the switch to the lights. The switch itself doesn't need to be grounded and the lights can be grounded where they are mounted.
  12. Dec 19, 2014 at 6:11 AM
    bryanbyers28
    Bryan
    Woodstock, GA
    Thanks man!
  13. Nov 8, 2017 at 6:39 AM
    jpoppinmoneyunit
    jpoppinmoneyunit Member
    Jake
    Alaska
    '10 Tacoma 4x4 SR5 TRD Sport
    Mostly interior mods. Hood work leds, in-cab outlet (I have it switched to the front plug for a cabin heater in the winter), 400w all the time on the inverter, heated mirror add-on, and 4x4 switch illumination. Up coming I want a level kit and hood scoop light bar and possibly line the bed with the led strips.
    Man I feel like this is one of the most under-rated and cheap mods you can do for the taco to make life much easier. I bought these leds from Amazon for $11 bucks prime and had the rest. IMO the flat spot close to the front of the hood is the best spot to mount the strip so they're angled towards the rear of the vehicle and not full blast in your eyes. Also, I had to use double sided tape because the 3M sticky tape on my roll wasn't good enough.
  14. Jan 6, 2018 at 5:42 PM
    dblj70
    dblj70 Well-Known Member
    Jeff
    2013 DCSB TRD Offroad SpruceMica
    Thanks to the OP @wordtothis. I just finished this. Basically the same way. Just a little different with the wire routing.
    Before
    After
    Lights
    Switch
    Wires coming from the switch to the battery and lights
    Ground wire from lights
    Red wire on the right is coming from the switch to the battery. The one on the left is for the alarm /remote start.
    This is coming from the switch. The left one goes to the battery and the right one goes up the fender to the hood along with the ground wire.
    There's a small hole in the hood right there that I used.
    I snaked the wire through from one hole to the next closest one and used a curved pick to grab it and pull it through.
    The lights were $20 at Walmart. The switch was $5 at Advance. Everything else I already had.
    stvhwrd likes this.
