Under hood insulation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thoy, Apr 2, 2023.
  1. Apr 2, 2023 at 7:08 PM
    Thoy
    Thoy [OP] Active Member
    2000 White Tacoma PreRunner 2.7
    The under hood insulation serves a few purposes
    1) in the event of an engine fire, the plastic retaining clips melt which allows the insulation to drop over the engine and smother the engine fire
    2) sound deadening
    3) protects the paint from heat of the engine
    4) allows the heat of the engine to dissipate
    RedDemolisher likes this.
  2. Apr 2, 2023 at 7:14 PM
    Madjik_Man
    Colorado Front Range
    Never thought of point 1.
  3. Apr 2, 2023 at 7:25 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    I started fighting fires at age 15 and still am at age 57 Volunteer and Career and I have never scene point 1 work.
  4. Apr 2, 2023 at 7:57 PM
    Thoy
    Thats supposedly the main reason for the insulation. To snuff an engine fire
  5. Apr 4, 2023 at 7:58 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    O.K. What material would you use to replace (missing) factory underhood insulation? I have the plastic retaining clips but don't want to pay for a Toyota OEM replacement. Something I can cut to fit?
  6. Apr 4, 2023 at 8:16 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
  7. Apr 5, 2023 at 3:24 AM
    Thoy
  8. Apr 6, 2023 at 6:16 AM
    hpidriver
    hpidriver Active Member
    '03 4x4 Xtracab 3.4L TRD SR5
    That eBay link says for 95-00 models, would it fit 01-04 models? I know the hoods themselves don’t interchange but the mat should have more leeway maybe?
  9. Apr 6, 2023 at 8:04 AM
    Madjik_Man
    I had the same question but just assumed the fasteners wouldn’t line up with anything on an 01-04 hood.
  10. Apr 6, 2023 at 12:02 PM
    texan626
    texan626 Active Member
    Rick
    Waco Texas
    2000 2dr SR5 2.4 automatic
    JustADriver, how do you like the product? Seem decent, fit well, etc?? Thanks
  11. Apr 6, 2023 at 6:13 PM
    Thoy
    I’ll give a follow up report once I’ve received it & installed on my 2000 PreRunner
  12. Apr 6, 2023 at 6:55 PM
    texan626
    Rick
    Waco Texas
    Sounds good.
  13. Apr 6, 2023 at 7:06 PM
    JustADriver
    Yeah I got it like a year ago. Fit is good. Clips are good.
  14. Apr 6, 2023 at 7:08 PM
    texan626
    Rick
    Waco Texas
    Appreciate your response.
  15. Apr 7, 2023 at 6:03 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
  16. Apr 7, 2023 at 6:11 AM
    Thoy
    All due respect, I’d rather have the clips that would melt in the event of an engine fire, and snuff out the blaze
  17. Apr 7, 2023 at 6:20 AM
    Kiloyard
    Phoenix, AZ
    I have a 10-lb fire extinguisher in the cab. I don't see how the hood liner could effectively choke off oxygen from a fire. The position it's in when the hood is closed would be almost unchanged without the clips, and air can still enter from below.
  18. Apr 7, 2023 at 6:27 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Mine fell of long ago and have been running without one for about 8 years. Didn't notice a difference besides less crap on the top of my engine from the old one disintegrating.
    Kiloyard likes this.
  19. Apr 7, 2023 at 6:27 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have insurance! If you got a good fire going it might keep the paint on the hood from blistering.
  20. Apr 7, 2023 at 6:36 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    MARSHBUSTER[QUOTED] likes this.
