Ultraguage, what does "pending" code mean?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ImpulsedComa, Jan 28, 2017.
  1. Jan 28, 2017 at 8:02 AM
    ImpulsedComa
    ImpulsedComa [OP] Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    "Pending" code P0430... I cleared it, but is there anything to check or worry about. Seems like it could be a number of things, but what does "pending" mean for the code?
    Also want to add that there never was a check engine light on.
    thanks
  2. Jan 28, 2017 at 8:13 AM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    • Pending codes mean that the OBD-II monitoring system has failed the operation of an emission control system at least once and if it fails again the Check Engine Light will be turned on and the malfunction becomes an Active code.
    PzTank likes this.
  3. Jan 28, 2017 at 8:15 AM
    ImpulsedComa
    NJ
    Thanks, weird cause this is the third time the pending code has came back after clearing it. The check engine light has never come on.
  4. Jan 28, 2017 at 8:19 AM
    mike s
    South Carolina
    2019 TRD OR
    The computer will run tests on the system only when certain conditions are met, like up to operating temperature for a specific period of time. You may be resetting the code before the conditions reoccurs for the next test.
  5. Jan 28, 2017 at 8:21 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    You are getting warned there is an emissions problem...how many miles on your truck?
  6. Jan 28, 2017 at 8:22 AM
    ImpulsedComa
    NJ
    126,000 miles
  7. Jan 28, 2017 at 8:37 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Time for a new kitty cat, pending.
  8. Jan 28, 2017 at 8:40 AM
    ImpulsedComa
    NJ
    damn, dont wanna replace the cats.... The truck runs good with no hesitations at all. Possibly the 02 sensor?
  9. Jan 28, 2017 at 8:44 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    more than likely the 'pre cat' is going...I had to replace my front one (Got it from East Coast Cat Supply), the rear is still the original (312,00 and counting)...I replaced my O2's, although I am not convinced they were the culprit, as I still got codes after O2 replacement, stopped when I replaced the front cat....
    YMMV....
    ImpulsedComa[OP] likes this.
  10. Jan 28, 2017 at 8:52 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Try this stuff first.
    I'm not a believer in most of this stuff, but I had a P0420 code on a first gen of mine that kept tripping my CEL no matter how many times I cleared it. Ran this through on a low tank of gas. Code never came back and was still good when I sold the truck a year or so later. Never even got a pending code again.
  11. Jan 28, 2017 at 9:06 AM
    ImpulsedComa
    NJ
    Thanks, gonna give that a try. Also forgot ri mention that the plugs were changed and the injectors cleaned about 1500 miles ago at the dealer.
  12. Jan 28, 2017 at 9:07 AM
    ImpulsedComa
    NJ
    Thanks, that could be my second in line after the fuel treatment.
  13. Nov 7, 2018 at 11:21 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I get a pending code alarm everytime I start the truck now. Started today and beeps every minute or so until I use the scroll down button to silence it.
    It was just a low fuel alarm. I never reset the guage upon last fillup. You can either set it to alarm off or just reset the fuel guage upon fillup.
