UCA removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taniwha, Dec 5, 2021.
  1. Dec 5, 2021 at 3:18 PM
    Taniwha
    Taniwha [OP] Well-Known Member
    Dave
    Kamloops, B.C.
    2009 Taco 4cyl. 5 speed 4x4 Speedway Blue
    Did a bit of a search and couldn't find. Is there a step by step for replacing the UCAs on my '09 Taco? TIA Cheers, Dave
  2. Dec 5, 2021 at 3:45 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Just did mine this weekend
    Installed Icon UCA’s
    Use jack to support lower control arm”keep little pressure “
    Unscrew upper Ball joint nut, but don’t take off!
    Loosen until you only have a few threads left
    Hit UCA/ball joint hard with hammer may take a few Ugg’s duggs and hit harder
    It will drop hence leaving the nut attached
    Remove screws that hold speed sensor cable and move out of the way
    For both sides, easiest thing is get “duck bill” vise grips you will need to bend the pinch welds out of the way, don’t be afraid to bend the steel! Then the bolt will come right out, the nut may need some juice depending on how crusty they are
    I had a new frame 2
    Years ago, so mine were hit that bad
    With air tools, both sides took me 2:15
    eherlihy likes this.
  3. Dec 5, 2021 at 4:38 PM
    illjimae
    illjimae Well-Known Member
  4. Dec 5, 2021 at 8:28 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Thanks guys, big help!
  5. Dec 5, 2021 at 10:48 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    In addition to the one provided by @whatstcp there are multiple Tacoma UCA replacement videos on YouTube (including ones for 3rd Gens which are very similar if not the same). So watch a few of those to get familiar with what you're up against.
    IMO the most ignorant part of this job is removing the long UCA bolts as you'll have to bend/mangle the sheet metal of the inner wheel/fender wells. Some people really struggle with this while others claim they don't. Conveniently enough, the FSM completely glosses over this fact and simply says to "remove the bolts" (these are installed at the factory before the body goes on). Some guys just simply cut the bolt out and install the new ones backwards, which I'll admit I wasn't overly fond of until recently I saw a photo of the new fancy TRD UCAs on the 2022 TRD Pros being installed like this from the factory. So...:notsure:
  6. Dec 6, 2021 at 12:01 AM
    TacoTuesday1
    FL
    You bend the firewall to pull the bolt out with lubricant and knock out the ball joint with an air hammer.
  7. Dec 6, 2021 at 1:46 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I just bought a set of new bolts for when i do mine $27 oem bolts. For me the extra $30 bucks to not struggle with the sheet metal is worth it. I also scored a new set off uca’s from a 2021 tacoma for $25 bucks. Just have to install them. Question for anyone who has done this . Will it tighten up the road wondering on the highway?
  8. Dec 6, 2021 at 7:08 AM
    Taniwha
    Dave
    Kamloops, B.C.
    So you wouldn't have to bend sheet metal to get the new bolts in?
  9. Dec 6, 2021 at 10:42 AM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    Yes you just install them the opposite way
  10. Dec 6, 2021 at 10:51 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    It's been a few years since I've done this but it wasn't a big deal to bent the pinch weld. It's probably the same amount of time, if not less time, than it would take to cut the bolt.
  11. Dec 6, 2021 at 11:12 AM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    I just did mine this weekend. I had a friend help. He suggested and I agree with him. Not necessarily a good idea to turn the bolts around. As he explained it for Gravity Sakes. If the nut were to fall off after you turn the bolts around the bolt can slide out of the UCA. If you leave it in the original position when reinstalling and the nut falls off this can't happen. Agreed its a long shot of this happening but it just made sense to me so that's how I did mine. Just my .02
  12. Dec 6, 2021 at 1:40 PM
    burrito782
    08 TRD Off Road
    If you read my earlier post above you'll see that Toyota has decided to try and defy gravity by installing the UCA bolts backwards on the new '22 TRD Pros. Competition is starting to get stiff in the light truck arena so perhaps it's part of their marketing campaign, "The all new 2022 Toyota Tacoma TRD Pro, not even gravity can stop it!" or how about, "The all new 2022 Toyota Tacoma TRD Pro, F = mg need not apply!"...ok I'll just go ahead and see myself to the door.
