UCA Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Sep 12, 2020.
  1. Sep 12, 2020 at 5:22 PM
    Skynet Surfer
    Skynet Surfer [OP] Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    At what point can I or should I, replace the upper control arms with something aftermarket? Does it really need to be done with a lift? What are some of the best choices for occasional weekend wheelers? I think my OEM ball joints are going out. I don't have a lift yet and not quite sure when I will be able to get around to that. I have a 15 4.0 4x4 DC SR with completely stock suspension.
  2. Sep 12, 2020 at 5:39 PM
    Jazz1one
    Jazz1one It is what it is
    Calgary AB
    2015 MGM DCLB sport premium
    SCS ray 10s. 315/75/16 Yokohama G003. Elka 2.5 dc w/remote resi. SPC uppers. Dobinson heavy leafs. Timbren bumps. Spindle gussets. Cab mount relocate. TRD catback. Toyota trifold tonneau. Full spare in bed. Hood deflector, side visors. Danger Customs Front/rear high clearance bumpers and full skids. 2 way remote start. Safari snorkel. Front 30% tint. Bed step. Anzo LED head lights. Weather tech mats. AllPro HD sliders linexed. 10k smitty x20 synthetic. Factor55 flatlink. Linexed bushwhackers. Rigid industries bumper pods. Ridged industries DSS ditch lights. Diode Dynamics amber pods. Prinsu roof rack. 42” Caliraised Amber single row. Switch Pros in sunglass holder. Custom Bed rail mounts for recovery gear.Northstar AGM battery. 4.88 nitro gears. Front and rear ARB lockers. ARB air compressor in bed cubby using expedition essentials mount.
    Can’t go wrong with SPC
  3. Sep 12, 2020 at 5:58 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    if you are not planning to lift your truck anytime soon, look around of craigslist or FB market place. a lot of upper control arms for sale from 2nd, 3rd gen tacomas and 4th, 5th gen 4Runners. they will all work and people usually sell them for about $50
  4. Sep 12, 2020 at 6:04 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Wrong. 4Runners are not all compatible. Different size ball joints on 4th Gen.
  5. Sep 12, 2020 at 6:26 PM
    pahaf
    paul
    NorCal
    really? i didnt know this. i only thought they would work because i used 5th gen upper control arms on my 4th gen 4Runner. seemed like they were the same.
  6. Sep 12, 2020 at 6:31 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    Once you lift the truck to 2.5"+ , an aftermarket UCA is required. SPC makes a good budget arm or you can go with the higher end brands like TC,DK, or Camburg. Definitely check craigslist if you don't plan on lifting, i'm sure you can find OE stuff on there for super cheap
    Skynet Surfer[OP] likes this.
  7. Sep 12, 2020 at 6:37 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    you are correct about finding stuff on FB marketplace all day long, but there are different ball joints between the 4Runner and Tacos. Same UCA design but different ball joint length and shank, you will notice if you go to put in the cotter pin and the castle nut isn’t even close to the hole. They don’t share the same spindles because of this as welll. Cruisers and 4runners and Lexus GX are the same though.
    SUMOTNK likes this.
  8. Sep 12, 2020 at 9:02 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    The above is 100% true.
  9. Sep 12, 2020 at 9:04 PM
    Skynet Surfer
    Dis
    15 DC v6 SR
    well new moog UCA's are only $50 each So why buy used?
