U-Joint Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fixedforbroke, May 4, 2010.
  1. Dec 16, 2013 at 12:37 PM
    #61
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Why in the hell do the prerunners not have zerk fittings? Mine has almost 65K on it and has always had a vibe in the mid-50's. How do you know when it is going out?
  2. Dec 18, 2013 at 4:54 AM
    #62
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    This is exactly what mine is doing right now...have to chexk for play in the driveline when I get off duty.
  3. Dec 18, 2013 at 5:03 AM
    #63
    hd99fxr2
    hd99fxr2 New Member
    CT
    07 SR5
    "Has anyone had their U-Joints replaced and how much was the total repair bill? I'm currently looking at replacing both U-joints and the carrier bearing. Also, I'm at 79,000 miles and consider myself to be an average driver. I feel like these wore out prematurely but, I'll admit I'm not that good with these things so I could be wrong. Any advice, comments, experiences, stories, jokes or otherwise will be greatly appreciated. " I have 2007 Access Cab/2.7 L, 85k miles - I initially thought the vibration was the needle bearing (see that thread), but my vibration/noises appeared to remain under acceleration in both 2WD and 4WD. At times, the vibration radiated to the driver's side door. It went away under deceleration. It was getting progressively worse. I thought I'd answer the question from a simpleton view - I paid $586 at the dealer, Lynch Toyota in Manchester, CT. I'm not mechanically inclined, so it wasn't feasible for me to do the repair. The difference was immediately noticeable - one u-joint was worn/slipping, the other two were replaced since they had the drive shaft(s)? down >> dealer words. In any case, I'm very satisfied - no noise, no vibration, no worries. The breakdown: 3.5 hrs labor = $346, parts (3) 04371-0K080 @ $80 each = $240. I hope that helps.
  4. Dec 18, 2013 at 5:12 AM
    #64
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For comparison purposes, the cheapest I've been able to find OEM u-joints is $40 each through Camelback Toyota. Tools required for install is either a press or a heavy shop vice and basic tools (jack stands, floor jack, socket set, needle nose pliers, a rubber mallet and a grease gun).
  5. Dec 18, 2013 at 5:14 AM
    #65
    clifpaul
    clifpaul Well-Known Member
    North Texas
    06 access cab 5 lug
    Too many to fit here now!
    I had all 3 of the ujoints replaced in my 06 access cab replaced at 90000 miles. Spent about 200. The ujoint that went on mine was the one in the middle next to the carrier bearing. It was squealing like all get out it reverse.
  6. Dec 18, 2013 at 8:13 AM
    #66
    erion109
    erion109 Well-Known Member
    Jayson
    Nashville
    06 TRD SPORT
    Weathertech FR & RR, DDM Tuning HID 55W 5000k Bi-Xenon, ARE topper, Yellow painted fog-lamp mod, anytime fog-lamp, Ipod interface, Red Top OPTIMA, Bilstein 5100s and 1.5 Toytech AAL, Redline Hoodstruts and EZdown tailgate.
    Problem solved!!!! I had one bad cap on the u joint at the rear diff. The bearings were turned into rusted dust. I can't believe I've been living with this issue for so long over a $20 part. Pulling the driveshaft was a breeze. Replacing the u joint was a little bit of a chore (I did all three), but all in all not too bad. Well worth doing it myself and saving $580 at the dealership.
  7. Dec 20, 2013 at 10:38 AM
    #67
    smtaco73
    smtaco73 Well-Known Member
    South Louisiana
    2008 and 2009 TRD Sport 4x4 DCLB
    TOYOTA FAMILY Three Tacomas and one corolla.
  8. Dec 21, 2013 at 5:56 AM
    #68
    erion109
    Jayson
    Nashville
    06 TRD SPORT
    The best way to tell is look under your truck and see if it has two or three u joints. I bought MOOG. Not sure if they are good or not, but they worked. I wanted spicer but none of the local stores stocked a spicer.
  9. Dec 21, 2013 at 6:02 AM
    #69
    Pugga
    Massachusetts
    Look under your vehicle but I'm pretty sure you have 3 joints. I purchased my u-joints from Rock Auto. I bought Moog but would not buy them again. Their tolerances were way out. I bought 3 joints but only 2 actually fit and one of them still had to be shaved a bit. The Moog ones were $10/ea, OEM is Spicer and they'll run you $50/ea at Camelback Toyota.
  10. Dec 21, 2013 at 6:21 AM
    #70
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    same here
    i went with federal joints for $6 a piece
    they worked great....
    and a $25 center support bearing from driveshaft parts
    and after 1000k no complaints
    oh and i used the barbarian way 17mm deep socket and a bfh
  11. Dec 21, 2013 at 11:25 AM
    #71
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Does it matter if the replacement U-joints have the grease fitting between two caps, instead of in the end of one of the caps like the OEM ones?
  12. Dec 21, 2013 at 12:53 PM
    #72
    smtaco73
    South Louisiana
    Was going to order from Rockauto but my squeaking in get more frequent so probably head the autozone, oreillys or advance auto sometime today. Gonna attempt to change them myself after watching several YouTube videos. Another question I have is do I grease them after installing them or they greased already?
  13. Dec 21, 2013 at 1:30 PM
    #73
    brutalguyracing
    F.U> GUYZ
    broken mods
    nope
    yes
    and as soon as you get the new u joints and are ready for install take all caps off and pack them with some grease to hold the needles in
  14. Jan 6, 2014 at 12:36 PM
    #74
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Got part numbers for those?
    Rock Auto lists:
    FEDERATED Part # 354
    $5.92
    MOOG/PRECISION Part # 354 Premium One of our most popular parts
    $9.57
    MOOG/PRECISION Part # 254 Non-Greasable Super Strength
    $13.76
    MOOG/PRECISION Part # 270 Greasable Super Strength
    $14.81
    Federal Mogul site lists:
    Universal Joint - Premium: Moog 354
    Universal Joint - Greasable Super Strength: Moog 270
    Universal Joint - Non-Greasable Super Strength: Moog 254
  15. Jan 6, 2014 at 12:41 PM
    #75
    Pugga
    Massachusetts
    FYI, that greasable super strength MOOG u-joint requires a different sort of grease fitting than the standard nipple. I ordered those first and sent them back because I didn't want to have to buy the new head for my grease gun or deal with adapters. I returned them and went with the 'premium' greasable, they have a standard grease fitting in the middle of the cross.
  16. Jan 6, 2014 at 7:06 PM
    #76
    brutalguyracing
    F.U> GUYZ
    broken mods
    THIS IS WHAT I USED
    I REMOVED THE ONE MOOG THAT WAS INSTALLED....IT WAS TOO TIGHT / STIFF
    PUT A BUNCH OF MILES ON AND SO FAR SO GOOD....
  17. Jan 6, 2014 at 7:37 PM
    #77
    Sandman614
    Tim
    '06 SR5 Off Road
    :thumbsup: thanks! Any gripes with the Carrier Support bearing rock auto has?
  18. Jan 6, 2014 at 10:48 PM
    #78
    brutalguyracing
    F.U> GUYZ
    broken mods
    Got mine from driveshaft parts
    No exp. With rock autos
  19. Jan 6, 2014 at 10:55 PM
    #79
    seedless024
    seedless024 Well-Known Member
    norman
    SL,UT
    01' TRD ext cab white
    i changed them myself on my old 96.
    changed all 3, for 8 a piece, new grease gun and grease 15.
    took about 2 hours with a table vise. never had any problems again till the truck was totaled... then it didnt matter.
    speaking of which, this reminds me to grease my new truck too. thanks for the food for thought
  20. Jan 7, 2014 at 7:00 AM
    #80
    Sandman614
    Tim
    '06 SR5 Off Road
    Which one do I need??
    Really, don't shop here..
