u bolts are to tight, possible issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyan, Oct 17, 2016.
  1. Oct 17, 2016 at 11:05 PM
    kyan
    kyan [OP] Member
    kevin
    i just installed a procomp add a leaf and also bought new u bolts, however they dont seem to fit quite right. im able to tap them down over the axle but they spread out about 1/4 of an inch to wide for the bottom plate that they sit in. i managed to use c clamps to bend them and get them in but could this cause issues?
    ChadsPride likes this.
  2. Oct 18, 2016 at 4:05 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    do not use incorrect size ubolts
    kenstar, Harry, 03f5sp and 5 others like this.
  3. Oct 18, 2016 at 5:21 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Correct u bolts should fit perfect. If they are spreading they are too small. Get the correct ones. If they are too small they may also not be as strong. They should replace them for free if they sent you the wrong ones.
  4. Oct 18, 2016 at 12:16 PM
    kyan
    kyan [OP] Member
    kevin
    Update, talked to 4wheel parts apparantly that is pretty standard install method, thanks for the input though
  5. Oct 18, 2016 at 1:16 PM
    moondeath
    Pa, Gardners
    Ive never had u bolts spread at the bottom and have to use something to bend them back to fit into the bottom plate.
    ChadsPride and RelentlessFab like this.
  6. Oct 18, 2016 at 1:18 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    There's your problem... it's 4 Wheel Parts giving you advice. I wouldn't trust those boobs to mount a tire properly let alone reattach my axle. Get the correct size ubolts and insist they take the undersize ones back. Ubolts should fit perfect, mine did on both vehicles I've changed them on.
  7. Oct 18, 2016 at 1:24 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    LOL
    if you bend a ubolt at home by eyeballing it, you have a shape mismatch.
    not -maybe-
    you will have a mismatch where the springs are clamped down,
    and premature spring failure will result
    it is just a matter of flexing and time
    ubolts are pretty critical, they are not just a hunk of iron.
    are you gonna have a problem? maybe not. but I would be getting
    ones that are factory made that fit correctly with no unusual loads
    needed to be applied to install them.
  8. Oct 18, 2016 at 1:24 PM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    I couldn't have said it better. Ubolts are cheap, it would really suck to fawk up a truck just because of poor fitment.
  9. Oct 18, 2016 at 2:02 PM
    kyan
    kyan [OP] Member
    kevin
    I think I need to clarify a bit, the new ubolts are the same size as the old ones, they are just longer it's just that the add a leaf is about an 1/8 of an inch wider than the factory springs causING the bolts to spread out a bit. So when I needed to add some prsure to bend them in place... that sound about right?
  10. Oct 18, 2016 at 2:03 PM
    Speedytech7
    So you have the wrong add a leaf for your truck, how much wider is it?
  11. Oct 18, 2016 at 2:04 PM
    kyan
    kyan [OP] Member
    kevin
    So no matter what size ubolts I use the leaf spring will push them out
  12. Oct 18, 2016 at 2:04 PM
    kyan
    kyan [OP] Member
    kevin
    About 1/8th of an inch, the package says they match my truck
  13. Oct 18, 2016 at 2:05 PM
    Cable
    Cable Well-Known Member
    California
    2017 TRD Off Road 4x4 Quicksand
    So it's not the U-bolts that are the wrong size, it's the AAL?
    Speedytech7 likes this.
  14. Oct 18, 2016 at 2:05 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    It's a common problem for them, I've had the same issue when I was leaf sprung. Just bend them into the holes and hammer it down. Never had a problem with a broken u-bolt before, just make sure to tighten them evenly enough.
    The leaf being wider is not right though.
  15. Oct 18, 2016 at 2:06 PM
    Speedytech7
    Sounds like a situation where you just have to use your best judgment, when people build custom leaf packs its not uncommon for then to shave the leaf down using an angle grinder. If it seems like it fits okay then run it I suppose.
  16. Oct 18, 2016 at 8:38 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    so it's the leafs ?
    your springs will eventually bust and maybe the ubolt too
    bad idea all around to have mismatched parts which bind together
    and constantly flex
  17. Oct 18, 2016 at 10:20 PM
    kyan
    kyan [OP] Member
    kevin
    the springs are the rated for tacomas 2005 - 11, mines a 07 so they are the correct springs. the u bolts are the old man emu ubolts for this specific 1.5inch lift in the back which im doing. (4 wheel parts gave me this info and i checked and its correct). but for whatever reason it was a bit of a bitch getting the ubolts on as they were being spread apart just barely so they wouldnt quite fit in the holes of the underclamp, by the ever so slightly wider ad a leaf. however once i got them on they tightened down fine and fit very snug.. the only issue i can see is the ubolts might have a bit of tension on the sides. so maybe ill go back and trim the sides of the ad a leaf...
  18. Oct 18, 2016 at 10:48 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Santa Rosa
    2015 Supercharged Taco
    Mostly whatever sweet stuff I can find at Vatozone
    Asks for advice.
    Doesn't listen to said advice from people he originally asked.
    Takes advice from 4WP.
    Good luck.
    You seem special.
  19. Oct 18, 2016 at 10:56 PM
    kyan
    kyan [OP] Member
    kevin
    cheers bud, no need to be a dick. im just trying to get all the different possibilities here... i appreciate everyones advice here, except for your arrogance
    Torspd likes this.
  20. Oct 18, 2016 at 11:51 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    If it's the right leaf for your truck, just take the leaf to the bench grinder and shave off 1/16" on each side of the leaf. Shouldn't take more than 5 minutes to achieve that.
