u bolt torque specs?
Discussion in 'Suspension' started by MAG GRY TACO15, Oct 31, 2018.
  1. Jun 14, 2019 at 4:49 PM
    Simia_4
    Simia_4 TacoSupreme
    Bozeman, MT
    2017 Super White DCSB OR Tacoma
    Icon 2.5" w/resi Nitro Gears 5.29 Mickey Thompson Baja MTZ 285/75/16 Falken Wildpeak AT3W 285/75/16 Mobtown Sliders MBRP 3" Cat back exhaust
    I’ve also got the wheelers flip kit but I’m still confused. Is it 37 or 70-80? Lol
  2. Jun 14, 2019 at 4:52 PM
    Simia_4
    Simia_4 TacoSupreme
    Bozeman, MT
    I’ve never actually checked mine since installing last Oct or so.
    Just watched this last night and about shit my pants at what I could’ve been doing this whole time. I’ve been plagued by the squeaks and the creaks with my leaves that I’ve been picking my head trying to resolve it.
    https://youtu.be/yPp9X4JdwHI
    Literally on my “To-Do” list for this weekend!
    mag4rnr and Taco-Obsessed like this.
  3. Jun 15, 2019 at 3:25 PM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    3 ugga duggas would've worked.
  4. Aug 8, 2019 at 11:12 AM
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    A859843D-15E2-431A-A8B4-B9ADEF345658.jpg My icon progressive states 120 ft-lbs. check out step 9.
    Bertw192 likes this.
  5. Aug 8, 2019 at 11:23 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    It's most definitely not 37ft lbs, that has to be an error in the FSM that Wheelers copied onto their site. On 1st gens the FSM torque spec for u-bolts is 90 ft.lbs, I can't imagine your guys' trucks are any less than that.
  6. Apr 29, 2021 at 7:59 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I went to 90 on my Dakars and the wheelers superbump flip. no issues.
  7. May 2, 2021 at 10:47 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    I went with 37 on my first go. Good boys follow the rules books. I drove about 250 miles with a bit of good off-road thrown in. I'm lucky I didn't lose something. Several bolts were backed off significantly and the springs had come out of alignment.
    Drooped the suspension, hammered the springs back straight, dropped it down and torqued to 82, same as my lug nuts. Drove 100 miles and retorqued with no noticable movement. Drove 1k more and rechecked. All is back to good.
    Now I'll just check them whenever I touch the lug nuts. 82 is my one size fits all. Now how do I get my oil drain plug off...
  8. May 12, 2021 at 8:12 PM
    GEN1_MK2
    GEN1_MK2 Member
    Roger
    San Diego, CA
    2000 Toyota Tacoma PreRunner to 4x4 Conversion
    4x4 Conversion, Tundra spec trans with red clutches and TransGo shift kit, FJ J-shift, Northwest Fab Eco Crawler with Trident triple shift, AISIN manual locking hubs, King Extended Coilovers with 650# springs in the front with King 12x2.5 in the rear with resi's & adjusters mounted on custom underside bed cage, JBA UCA, AllPro Expeditions, DuroBumps, Ubolt Flip, Fabzone Sliders, Yukon 4.56 Front & Back, Baja Design Lights, Prinsu Roof Rack, CBI Overland Bars, Smittybilt Defender Rack, Midland GMRS, K&N, Energy Suspension Everything, Custom Magnaflow Exhaust, AllPro Shackles & Spindles Gussets, Antirock rear universal swaybar, Marlin Crawler Brake Lines and Powerstop Rotors, Husky Tool Box, ProComp Rock Lights, SwitchPro 9100, BedSlide S, Wheels 15x10 Alcoa, 33x12.5 BFG K02's.... That's it.
    My 2000 Tacoma FSM stated 93 ftlb. So that's what I went with. No problems shifting or backing out as of yet.
    1rooster likes this.
  9. Jun 30, 2021 at 6:44 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'm at 86 ft lbs
  10. Jun 30, 2021 at 10:15 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The OME u-bolts for my flip kit stated 93 ft*lbs
  11. Jun 30, 2021 at 8:01 PM
    SpudGT
    SpudGT Well-Known Member
    Burt
    Boise, ID
    2021 Taco
    I went with 52 ft lbs on mine, from the 3rd gen service manual:
  12. Jul 4, 2021 at 3:50 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    The problem with this theory is that the lug nuts interface with the wheel is much broader than the interface of the round u-bolt onto a tube.
  13. Jul 6, 2021 at 11:24 AM
    state48overland
    state48overland Well-Known Member
    Erick
    Gilbert, AZ
    2011 & 2017 Tacoma DCSB 4WD
    Round u bolts —-on an axle tube if you run a flip kit, different than:
    Square u bolts which are factory and most if not all aftermarket still use the spring seat. In which the spring seat has more surface area under the axle tube and spreads the torque load.
    gilligoon likes this.
  14. Sep 29, 2023 at 4:14 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Thanks folks.
    I've been getting some creaking and the rear end was slightly out of alignment when I got new tires this week. I don't see why Firestone would not check u-bolts if the rear is +.4 -.2 and the customer complains it's still drifting right. Seems like they would know to loosen and re-torque u-bolts to see if it straightens out. The nuts on both front u-bolts were barely more than hand tight. o_O Yikes. My bad for not having a deep 19mm socket.
    So... I bought a shiny new socket, loosened all bolts and re-torqued. 75 is quite a few uggaduggas with a 80lb torque wrench.
    And now I see I only needed 52. :militarypress:
    Hopefully that solves the creaks and drift until I get Eibach springs and Icon leafs installed soon.
  15. Sep 29, 2023 at 4:32 PM
    #35
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Torque is determined by thread pitch and bolt size. If you're using aftermarket ubolts, the oem spec might not be the same.
    A good 'rule of thumb' is to torque ubolts the same as your lugs.
    I have both cranked to 110#'s
  16. Sep 29, 2023 at 4:42 PM
    #36
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My Icon RXT u bolts are 90 ft lbs.
    bkhlrTaco's likes this.
  17. Sep 29, 2023 at 4:43 PM
    #37
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Sounds like a more stable # than 73.
    OffroadToy[QUOTED] likes this.
  18. Sep 29, 2023 at 5:01 PM
    #38
    OffroadToy
    The 05-up Tacoma RXT u bolt torque was 75 ft lbs a few years back but got updated to 90 ft lbs in 2021.
    https://images.iconfigurators.app/pdf/I52050_REVB_7487.pdf
    edit: now running Timbren u bolt flip kit... torque is 75 ft lbs.
    bkhlrTaco's[QUOTED] likes this.
  19. Oct 18, 2024 at 9:39 PM
    #39
    Rickym72
    Rickym72 Well-Known Member
    2023 Tacoma TRD OR 4X4
    Any issues running at 110 ft lbs? I normally do 85ft lbs but the shop that worked on the truck went waaaay higher
