U-bolt plate
Discussion in '1st Gen. Tacomas (1995-2004)' started by SteveW504, Dec 9, 2021.
  1. Dec 9, 2021 at 9:05 AM
    SteveW504
    SteveW504 [OP] Active Member
    '96 4WD
    Body lift by previous owner. Rear welded locker by same fool.
    Okay guys and gals, next broken part discovered. The lower U-bolt plate under the rear axle, right side... the female threaded "tube" that the shock absorber bolts to is half as long as it was, apparently broken off some time back. I replaced the leaf springs and now shackles. The shocks maybe had some life in them, but were pretty beat up so I purchased a set. Installing the new ones, I found the lower mount broken, so I need the plate. Anyone know where I can get one? I've been searching online without success. I'd be happy with a used one from a parts truck if not rusty, or new depending on price. Thanks in advance.
  2. Dec 9, 2021 at 9:58 AM
    Green1GT
    Green1GT Well-Known Member
    Maryland
  3. Dec 9, 2021 at 10:00 AM
    SteveW504
    '96 4WD
    Found it. It's actually called a "Leaf Spring Plate", which is why I couldn't find it initially. No replies necessary. Thanks for looking.
    Green1GT likes this.
  4. Dec 9, 2021 at 10:01 AM
    SteveW504
    '96 4WD
    zjdietz, That's it. I found it probably just as you were replying. Thank you.
  5. Dec 9, 2021 at 10:03 AM
    Green1GT
    Maryland
    Haha good to hear. And if you haven't already, replaced the u-bolts while you're down there
