U-bolt lengths
Discussion in 'Suspension' started by White lightning boosted, Jul 1, 2019.
  1. Jul 1, 2019 at 6:33 AM
    White lightning boosted [OP] Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm getting deavers delivered soon and want to know if stock length u-bolts work. I got a new, oem set for free. Hoping they work. If anyone has info to help me out I'd appreciate it.
    Thanks!
  2. Jul 1, 2019 at 4:27 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    think the oem are 6.5 " and too short. Think you need 7.5" minimum. I have some I got from a member and never used? Cheap. Check our vendors for your setup and I think they will indicate what U-bolts are needed to match. GL.
  3. Jul 1, 2019 at 4:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you end up buying new u-bolts do a u-bolt flip with new bump stops while you are at it.
  4. Jul 1, 2019 at 4:42 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm changing from a block lift to springs. New hangers and relocate bracket too. What's the benifit of a flip kit? I still may need 1" block. Better than 4" haha!
  5. Jul 1, 2019 at 5:04 PM
    rnish
    Tacoma 2nd gen
    Less to snag on the trail.
    Stock
    U-bolt flip
