typical wheel bearing lifespan?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lthompson, Aug 18, 2018.
  1. Aug 18, 2018 at 2:14 PM
    Lthompson
    Lthompson [OP] Well-Known Member
    I think I have a wheel bearing on the way out on the passenger side, Because I get a slight hum, but when I turn right it goes away. But its only at speeds over 60 I notice it.. With that said, what is the typical life span of the bearings? I just rolled over 80k on my 2011.
    wilcam47 likes this.
  2. Aug 18, 2018 at 2:40 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    My driver side went at around 70ish thousand....my passenger side is still going strong....I have a spare assembly on standby in my tool box for the day it goes bad.
  3. Aug 18, 2018 at 2:41 PM
    Bishop84
    Bishop84 Well-Known Member
    Many many factors, but I usually see it around 150,000kms.
    Way sooner, almost every 50k with severe offroading.
    Water, rust, oversized tires, load, all kill a bearing sooner.
  4. Aug 18, 2018 at 3:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no "typical".
    Norton likes this.
  5. Aug 18, 2018 at 4:59 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Mine driver side is bad at 90k miles
  6. Aug 18, 2018 at 6:47 PM
    ashjwilliams
    ashjwilliams Well-Known Member
    My passenger side went bad at 125k miles driver side still going. I have a slight hum also. Factory suspension, no lift, OEM size tires, very-very little offroad.
  7. Aug 18, 2018 at 7:03 PM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    Both driver and passenger went bad immediately following my lift and 285’s @115k
    Running Board Man likes this.
  8. Aug 18, 2018 at 7:04 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Rear passenger went out 70k. I prophylactically changed the front ones around the same time.
    HillJackJDS likes this.
  9. Aug 18, 2018 at 7:22 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm at 190,000 and 11 years on the ones that came from the factory. Oversize tires, especially combined with lots of wheel offset or wheel spacers put a lot more strain on them.
    Stryker420 likes this.
  10. Aug 18, 2018 at 9:52 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    My rear passenger wheel bearing went out at 27k miles
  11. Aug 18, 2018 at 9:58 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    the warranty exists for a reason...
  12. Aug 18, 2018 at 10:06 PM
    fast5speed
    Washington D.C.
  13. Aug 18, 2018 at 10:07 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I think a lot has to do with environmental conditions and or winter de-icer...seems like some dont last past 80K..
  14. Aug 18, 2018 at 10:25 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    5 lug? PreRunner? 4x4?
  15. Aug 18, 2018 at 10:31 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Front left went at 60k-ish along with the needle bearing. Stock spec drivetrain wise with gentle dirt use. Ready for the pax side to to go, hoping it is in the next 30k miles before my warranty kicks.
  16. Aug 18, 2018 at 10:50 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I've got 217K mi now, no noise or play. Had 265/75r16 for 4 yrs, then 285s for the past 10 yrs.
    05Taco4x4 and Running Board Man like this.
  17. Aug 18, 2018 at 10:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    81k with 275s and spacers the whole time. No problems
  18. Aug 22, 2018 at 12:22 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    195 k on drivers
    15k or so on passenger
    stock tire size and driven in the snow
    Mine might have failed early from the semi trailer dragging my taco into the curb, they replaced the LCA that bent
  19. Aug 22, 2018 at 5:05 PM
    Lthompson
    I guess its getting replaced tomorrow. Hope that's it anyway, im worried to drive too far, I drive 16 miles in the morning, and 16 home that evening typically.. I have a longer trip this weekend, and don't want it to grenade on me.
  20. Aug 23, 2018 at 5:48 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Mine are all 200,000+ and I guess they are fine? Might have them checked soon.
    Is it possible to open them, clean them and repack them with grease? That was something we used to do back in automotive tech but I remember them saying that it's only possible on certain vehicles.
