Type of bulb in license plate lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jw1983, Sep 24, 2011.
  1. Sep 24, 2011 at 8:53 AM
    jw1983
    jw1983 [OP] Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Hey everyone!
    I was looking at the oem yellow that I hate so much. I got the thinking that I am going to change the oem bulbs to something else, probably a white. I am curious though, what is the type of bulb that is in there? Is it easy to go and check? Any advice would be great, thanks!
    jason
  2. Sep 24, 2011 at 9:40 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Pick up some 5smd led 168/194 bulbs. Big difference and looks better with the bright white accent, kinda gives the truck a modern day look.
  3. Sep 24, 2011 at 11:39 AM
    jw1983
    Alberta
    What about LED? Is there any ones that would fit in there? Or just incodesent lights?
  4. Sep 24, 2011 at 11:41 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
  5. Sep 24, 2011 at 11:45 AM
    jw1983
    Alberta
  6. Sep 25, 2011 at 8:22 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Wasn't hard to get the emblem off at all. I didn't remove the grill to do it either. The emblem just pops out, it's held in with plastic tabs. I got the emblem I have now from metal miller. He does custom emblems on this site
    http://www.tacomaworld.com/forum/buy-sell-trade/40819-custom-emblems.html
    Hope that helps. If you just want to paint your emblem a certain color, that's easy too. I've painted alot of things on my truck orange so far cuz I have an insanely horrible fettish with all things orange. Also I am a Longhorns fan. First thing you wanna do is get your supplies. You need to clean what you're painting, so various things will work, the best is either rubbing alchohol or mineral spirits. Then get some card board or even a box and go into a well ventilated area, unless you like getting high on paint fumes. Use an automotive primer so your final paint will last long. The light grey primer makes colors creamier looking, while the black primer makes the colors look deeper. One light coat, then dry, then another light coat. You can use a hair dryer or a heat gun to preheat the emblem so the paint dries smoother. After you have the primer dried, preferably over nite, do three light coats of your final paint. Dry time should be about an hour in between coats. Now if you want your paint to last you should use a clear coat. I used wheel clear coat. This stuff is trial and error, so Practice on your cardboard to get spraying down good. You need to let the paint dry over nite before applying clear coat. One good coat should do the trick. Just be careful not to spray too much. When it goes on it looks a little milky, not to worry, it dries clear. Good luck with all your mods on your truck, and if you need any tips or advice, as always just ask any body here on this site. I would be happy to help you with what ever you got goin on. Good luck.
  7. Sep 25, 2011 at 9:04 PM
    jw1983
    Alberta
    Yeah that's totally awesome!. When it comes to the paint though is it easy to take off if you want to change the colour? I suggested Plasti Dip because then I can take it off and put on another colour if I wish and I don't have to worry about paint and primer. Being a noob and all I don't know if I wanna chance using the paint and screwing things up. At least with the PD it's almost newbie proof.
  8. Sep 25, 2011 at 9:06 PM
    jw1983
    Alberta
    When it comes to the license plate lights can I use any as long they are 168/196 bulbs? Aren't some LED's different shapes and may not fit into the stock housing etc?
  9. Sep 25, 2011 at 9:10 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    PD works perfectly fine, especially if you don't want to be committed. I think you are limited to certain colors though. The only ones I've seen in stores so far is red and black, but I'm sure you could search the interwebz for more colors. The only down side of plastidip on the front emblem is how much beating it will take with road debris, but you can just re do it evry couple of months no biggie.
  10. Sep 25, 2011 at 9:18 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yup, did the same and work better than the ones I bought at pep boys. The map lights, license plate lights, and high center brake lights are all the same design.
  11. Sep 26, 2011 at 5:17 PM
    jw1983
    Alberta
    Where would I be able to get LJ Led's from? I live in Canada so I am not too sure where I'd be able to get them?
  12. Nov 12, 2017 at 11:44 PM
    GLube
    GLube Active Member
    Garrett
    Anyone have an update on where to get LEDs for the license plate for a 2nd gen in Canada?
    Even just a thread where it's well explained, and not an ebay link that's expired. I've looked and can't find anything good.
    EDIT: I haven't yet found a good link for license plate lights, however here is a good thread for LEDs:
    https://www.tacomaworld.com/threads/interior-dome-led-light-kits.347450/
