Tying down gear in the bed, how do YOU do it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rimfire7, Jul 1, 2021.
  1. Jul 1, 2021 at 3:57 AM
    rimfire7
    rimfire7 [OP] I'm here for the tacos
    beth
    2021 army green taco
    Toytec lift, old man emu springs, Victory 4x4 front bumper and skids, light bar
    I went to the dunes for the first time last weekend and had a BLAST but my gear boxes in the back all came loose while I was marauding around the dunes. I used ratchet straps to secure boxes to the sides of the bed. Does anyone have a way they secure gear that is more secure? TIA
    Malvolio likes this.
  2. Jul 1, 2021 at 4:47 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Install D dings on the bed floor. The attachment points on the sides of the bed kind of suck.
    philth, rimfire7[OP] and Grossomotto like this.
  3. Jul 1, 2021 at 4:51 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Ratchet strap to bulkhead or diagonally strap down corner to corner.
    ORtoCOTaco and rimfire7[OP] like this.
  4. Jul 1, 2021 at 5:12 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Ratchet straps going over or around containers doesn't work for bouncing around and having fun off-road. If you are going to put stuff in containers instead of mounting it directly, the containers should have mounting or tie down points to directly connect to and at least two of them should be in opposition. I'm no loadmaster but it's worked for me for years. When I bought coolers in the past I always look for tie down points up to the task if holding a 100lb cooler while off-road.
    rimfire7[OP] and Chew like this.
  5. Jul 1, 2021 at 5:22 AM
    WZ00R2
    TN
    2020 Cement OR
    CPS-65, rimfire7[OP] and Grossomotto like this.
  6. Jul 1, 2021 at 5:33 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Add more D-rings, which attach to the frame, in the bed. Ratchet straps and macho adjustable bungee cords.
  7. Jul 1, 2021 at 5:42 AM
    madcratebuilder
    madcratebuilder Well-Known Member
    PNW
    ZR2 Deepwood Green
    skidz, gears, tune, zeon 12-s
  8. Jul 1, 2021 at 6:00 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    vvvvv this, you can put 6 rings in the bed bolts. Way better for strapping down a wheel or anything heavy.
    rimfire7[OP] likes this.
  9. Jul 1, 2021 at 6:40 AM
    rimfire7
    beth
  10. Jul 1, 2021 at 6:44 AM
    rimfire7
    beth
    Does anyone else hate Ratchet straps too? They are always getting stuck or pinching my fingers. And don’t get me started on what the sand has done to them!! They are useful tho
  11. Jul 1, 2021 at 9:44 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    rimfire7[QUOTED][OP] likes this.
  12. Jul 1, 2021 at 9:57 AM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    I put in d-rings on the front two bed bolts and run chains from them to the back factory d-rings for multiple attachment points. The only thing I trust the bed wall loops up front is for securing the milk crates, which I put miscellaneous crap or 5-gal gas cans/20# propane tanks in.
    PapaBear15, nlb, G8R_Taco and 5 others like this.
  13. Jul 1, 2021 at 9:58 AM
    rimfire7
    beth
  14. Jul 1, 2021 at 10:12 AM
    Lgeekdws
    Lgeekdws Well-Known Member
    2015 Magnetic Grey V6 4x4 SR5
    Try salt water.. 6 months of strapping my kayak down and they all got a vinegar soak and lube session last week.
  15. Jul 1, 2021 at 11:46 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I used these o-tracks to tie my mini bike down, they are pretty solid.
  16. Jul 1, 2021 at 12:03 PM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
  17. Jul 3, 2021 at 12:23 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Are those flush/below the bed corrugating or do they stand proud?
  18. Jul 3, 2021 at 12:27 AM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
  19. Jul 3, 2021 at 12:30 AM
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
  20. Jul 3, 2021 at 10:14 AM
    5nahalf
    Erik
    Minnesota
    They sit in the grooves and sit pretty flush with the top.
    [​IMG] [​IMG]
    They are held down with plus nuts
    Then I get these rings that hook on for tie downs.
    rimfire7[OP] and Travlr like this.
