Two questions about AC drain line
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crobran, Jun 26, 2021.
  1. Jun 26, 2021 at 8:39 AM
    Crobran
    Crobran [OP] Well-Known Member
    Texas
    `21 DCSB 2.7L Silver Sky
    Trifecta 2.0, Ionic Nerf Bars, Tailgate anti theft device from @christian06, Husky Weatherbeaters, Bed lights, OEM bed mat, Derped badges and grille bezel
    I've been getting the apparently very common AC condensation dripping on my passenger side floorboard so I'm trying to fix that before our trip. Two questions:
    1) I'm still getting condensation dripping outside below the truck so that means the drain line isn't entirely clogged. Why would I therefore be getting dripping inside on the floorboard? Are there other causes for that?
    2) I ran a wire up into the drain line to clear anything out, but I could only get the wire about 6 inches in. Is that as far as I should expect or does that mean I'm running into a serious clog (and if I am, how am I still seeing condensation dripping below the truck)?
    Thanks.
  2. Jun 26, 2021 at 8:45 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
  3. Jun 26, 2021 at 8:48 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Do u have a sunroof?
  4. Jun 26, 2021 at 8:50 AM
    Crobran
    Texas
    Alas, no.
  5. Jun 26, 2021 at 8:52 AM
    Crobran
    Texas
    So that blows air in rather than sucking air out. Wouldn't that just blow whatever is clogging it further inside the system? Or is there a different rubber tube that I would use that on to blow things out of the drain line?
    SR-71A likes this.
  6. Jun 26, 2021 at 8:58 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    New windshield lately?
  7. Jun 26, 2021 at 8:58 AM
    Lt. Dangle
    Ohio
    Yes, but it dislodges the formation to wash out. It completely dismembers the gunk.
  8. Jun 26, 2021 at 8:58 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I've only had one clog on a different car but a quick blast of air up it from a compressor fixed it.
  9. Jun 26, 2021 at 8:59 AM
    Crobran
    Texas
    Nor that. It definitely only happens when the AC is running. I'm wondering if maybe something isn't sealed properly and condensation is just leaking out where it shouldn't.
  10. Jun 26, 2021 at 9:00 AM
    Lt. Dangle
    Ohio
    That would work as well.
  11. Jun 26, 2021 at 5:19 PM
    Crobran
    Texas
    UPDATE: After using a vacuum cleaner on the drain line, running a wire up into it AND using an air compressor, it's still dripping. I took a photo of what's under the dash. The drip on the floorboard is directly below the point where all of the wires come together. The green circle is around what looks to me to be another drain line but that was totally dry. I can't find any diagrams that are helping me figure out specifically where the dripping is originating.
  12. Jun 26, 2021 at 5:38 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    If it's super humid and dew point is high moisture can condense on the duct itself. It should slow and stop once the cabin temp/humidity lessens, though.
    SpensirG and Skydvrr like this.
  13. Jun 26, 2021 at 5:46 PM
    Crobran
    Texas
    ...so once I move out of Houston I can expect this to stop. :rofl:
    CrufflerJJ, MadKatt and Skydvrr like this.
  14. Jun 26, 2021 at 5:49 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Ha, maybe! Once the cabin cools and the humidity inside goes down, like after 15-20 minutes of driving with AC on, I would think it would slow down as the dew point drops below the temp of the duct surfaces. Next time its dripping take the same picture you just posted but from a couple different angles to try and see the sides of those ducts.
  15. Jun 26, 2021 at 6:56 PM
    RX1cobra
    19 OR
    Sounds like at this point you should go to the dealer.
  16. Jun 26, 2021 at 11:19 PM
    dnguy77
    dnguy77 Well-Known Member
    Duey
    Baton Rouge, LA
    '18 White Tacoma DC TRD Sport, '03 Grey Tundra AC SR5
    Living in Louisiana, I learn to live with the drips of water on my passenger side floorboard.
