Turning off AC before shutting off engine.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OriginalMan, Jun 11, 2018.
  1. Jun 11, 2018 at 6:52 PM
    OriginalMan
    OriginalMan [OP] Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Is it just me being ocd and weird that I have to turn off my air conditioner before shutting my vehicle? Or, does it even matter?
  2. Jun 11, 2018 at 6:56 PM
    Gatordog
    Gatordog Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    I've shut mine off first for years and years.... back in the day :) it took some pressure off the compressor or something to that effect therefore making the ac system last longer....
    austin2009 likes this.
  3. Jun 11, 2018 at 6:58 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    "Back in the day" AC was a big deal and it required a significant of hp to operate. So, starting up the vehicle with the AC on would put stress on the starter battery etc. I think, and I could be wrong, the autos are engineered to take this all in to account now.
  4. Jun 11, 2018 at 8:42 PM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    It has been my experience from multiple vehicles that if you don't run some outside air through the HVAC system before turning off the vehicle, that the next time you start up the vehicle, you will have the equivalent of baby barf odor emitting from your vents. Basically, moisture will condensate on the inside of your HVAC conduits if you don't vent, thereby allowing bacteria to multiply and prosper. This issue is especially bad when using max ac and recycling air instead of pulling air from outside the vehicle.
  5. Jun 11, 2018 at 8:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Does not matter. Do it or not.
  6. Jun 11, 2018 at 8:46 PM
    Avail211
    Avail211 Well-Known Member
    2016 BBP TRD OR
    Same here. I try to turn my A/C off about a min or so from the house, if I forget it smells like ass the next day for a couple min.
    BT17, cshrum and shakerhood like this.
  7. Jun 11, 2018 at 9:15 PM
    bruce316
    bruce316 Active Member
    2016 4X4 Dbl-Cab TRD Sport
    This! It may not happen right away but eventually it could happen and you will start getting a bad smell from your vents. I've seen numerous posts here and on other car forums with this problem occurring. Just get in the habit of turning off the A/C when you are a couple minutes away from your destination and let the fan blow to dry out any condensation in the system. It's easy to do and might save you a headache later on.
  8. Jun 11, 2018 at 9:24 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I leave it on running errands, shut it off about a mile before my destination if it will be sitting for an extended time.
    EdgeCrusher likes this.
  9. Jun 11, 2018 at 9:45 PM
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    I shut it off also. Including the ECT button lol
    tacobills and cblow5 like this.
  10. Jun 12, 2018 at 2:50 AM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    Doing this will prevent the dirty sock syndrome.
    Vanderjdm and Bastek like this.
  11. Jun 12, 2018 at 4:39 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Then if you are running recirculation only for those few minutes, over time it's going to become an issue. It is very unfortunate, you'll end up breathing in mold spores...
    Now, I'm not taking Toyota specifically, but that's an issue for most vehicles with Climate Control - whenever you turn it on it closes the flap and recilculates air.
    Now days since this problem is more widespread, more shops are performing evap coil cleaning, when that stuff was happening to my wife's older Infiniti (nice few years ago) the stealership wanted to replace the coils $$$!
  12. Jun 12, 2018 at 6:01 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    OCD OCD OCD.. I do the same as OP. Have no idea why. Sometimes I even turn off the radio but not always. Always turn off AC. Most times but not always I also turn off the lights. Sometimes but not always I leave windows open a crack. I always park between the lines or re-park. I sometimes but not always flex on Flex Friday.
  13. Jun 12, 2018 at 6:03 AM
    Ghser7
    Ghser7 Well-Known Member
    Bonaire, GA
    '16 BlazingBluePearl 4x4 OR DCSB
    Happened to mine. I though I had a leak from either the rear window or brake light like others. Pulled everything apart and was bone dry. I had remembered what a home A/C guy told me once about spraying Lysol to kill the mold in you system. So I tried that one night, and has been good since.
    What is frustrating is the fact that the recirc mode comes on every time you start the truck. I have to turn it off manually every time, but I have not had the smell come back.
  14. Jun 12, 2018 at 6:08 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Yes, same here. When I think about it, I shut the AC off and leave the fan going a minute or two before turning the truck off. I remember my mom doing the same thing in her car when I was a kid. Yes, the reason is to minimize condensation remaining in the system. It probably isn't even helpful in the dry climate I live in because condensation rarely happens here. But OCD is a bitch and old habits are hard to break.
  15. Jun 12, 2018 at 6:10 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    If you set the temp dial to just above the click before as cold as you can turn it, and turn off the ac and recirc before you turn off truck, the recirc wont come on when you start up the truck next time.
    OriginalMan[OP], Mnmlod and Mtn Mike like this.
  16. Jun 12, 2018 at 7:30 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I do it but the only reason is so it doesn't start in the AM
    when I leave.
  17. Jun 12, 2018 at 8:11 AM
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    I do it all the time.. I guess is my OCD as this action may not do anything good or bad to the AC or truck... :notsure:
  18. Jun 12, 2018 at 8:20 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    It IS important to turn off the fan so that it doesn't start on full blast the next time you start the truck and break that plastic fan attchment to the motor.
    Plenty of reports about that. As a former airline pilot, I shut down everything before I turn off the truck. Just good housekeeping. Keeps thing from going "bang" on the next restart.
    G.
  19. Jun 12, 2018 at 9:44 AM
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    I run windows down %90 of the time even down here in hot ass Tampa. When I do use the ac I switch between re-circulation and outside air.
  20. Jun 12, 2018 at 9:46 AM
    dylmatik
    dylmatik Well-Known Member
    Dylan
    16 DCLBTRDOR
    Sometimes I briefly turn off my A/C when I enter a freeway onramp. I don't have to do this when I have ECT on. Damn 3.5..
