Turn Signals Not Working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grizztek, Jul 12, 2015.
  1. Jul 12, 2015 at 9:03 PM
    Grizztek
    Grizztek [OP] Member
    Zach
    Knoxville/Birmingham
    2011 Tacoma Reg
    Leaf Spring Squeak Mod
    Alright, I've searched and searched and searched. Then searched some more.
    I have a 2011 Reg Cab Tacoma.
    Plugged in my new LED turn signals got in the truck, started it, hit my left blinker, it flashed once then nothing. My hazards won't work, nor my turn signals, I have already cut my green/red drl wire to the flasher relay so they didn't work to begin with. I put my stock turn signals back in and still the same thing. All of my fuses are good. I pulled my flasher relay and inspected it, it doesn't smell burnt or look like anything is wrong with it.
    Should I just buy a new flasher relay and see if it works or do any of ya'll know anything else to check?
  2. Jul 12, 2015 at 9:07 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Do you have a digital meter?
    turn on the blinker and check for power at the bulb socket.
  3. Jul 12, 2015 at 9:13 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Some reason I always say recheck your fuses. Any other things not working?
  4. Jul 12, 2015 at 9:16 PM
    Grizztek
    Zach
    2011 Tacoma Reg
    No, everything else is working fine, reverse light, parking light. All is working. Which fuse is are the turn signals on on the 2011, there is no turn signal fuse or horn fuse. I checked them all like 5 times and put replacements in each individual one.
  5. Jul 12, 2015 at 9:22 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Don't know if '11 is the same, but on my '07 the Trn-Haz fuse is a 15a in the engine bay panel.
  6. Jul 12, 2015 at 9:23 PM
    Grizztek
    Zach
    2011 Tacoma Reg
    No it isn't the same at all. :(
  7. Jul 12, 2015 at 9:26 PM
    Grizztek
    Zach
    2011 Tacoma Reg
    It basically has ign ,ign 1, ign 2, accesory, power outlet, and a bunch of power window fuses and power lock fuses but I don't have power anything.
  8. Jul 12, 2015 at 10:19 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    That's in the fuse panel in the dash, correct?
    The "trn/haz" signal fuse is in the panel under the hood behind the battery.
  9. Jul 12, 2015 at 10:36 PM
    Grizztek
    Zach
    2011 Tacoma Reg
    You are a life saver! You saved me a waste of $40. I had no idea that fuse box existed!
