"turn signal stuck on"
Discussion in '1st Gen. Tacomas (1995-2004)' started by 360tacoma, Feb 21, 2011.
  1. Feb 21, 2011 at 4:24 PM
    360tacoma
    360tacoma [OP] Member
    98 tacoma SR5 v6
    Hi, I have a 1999 tacoma with the turn signal stuck on only when the head lights are on also the marker for the turn signal stays on in the cab of the truck, when the head lights are off the turn signal works but it makes the guages the clock and heater controls flash with it. I checked most of the fuses that I could see in the cab and under the hood. I have a alarm and some other lights on my truck but I disconnected them all and nothing changed:confused: please help thankyou.
    FixMyTaco likes this.
  2. Feb 21, 2011 at 4:32 PM
    KCin HBCA
    KCin HBCA 2020 TRD Sport 4x4
    Keith
    Huntington Beach
    2020 Dbl Cab TRD Sport 4x4
    Check your bulbs (combo turn/parking) sometimes when a bulb goes bad the element shorts across the other and causes problems.
  3. Feb 21, 2011 at 5:24 PM
    360tacoma
    98 tacoma SR5 v6
    I checked the bulbs they looked fine, I was thinking maybe something with the turn signal switch?
  4. Feb 21, 2011 at 5:31 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This is def the most likely cause. I would just disconnect the switch and see if the lights go out. Sometimes you can wiggle the switch and get it fix itself temporarily too.
  5. Feb 21, 2011 at 6:06 PM
    360tacoma
    98 tacoma SR5 v6
    I disconnected the plug from the switch but then nothing would work I pluged it back in nothing changed I also tryed to wiggle the switch. is there some way to maybe test the turn signal switch?
  6. Feb 21, 2011 at 6:16 PM
    NelsonTacoma
    Tucson, AZ
    Do your hazards work with the headlights on?
    The wires coming out of the switch to the flasher are Green for the L/turn signal and Green/White for the R/turn signal. If you have a test light you should get 12v at those circuits when the switch is turned on.
  7. Feb 21, 2011 at 6:21 PM
    360tacoma
    98 tacoma SR5 v6
    they only turn on but they dont flash with the head lights on they work with the head lights off tho
  8. Feb 21, 2011 at 6:27 PM
    NelsonTacoma
    Tucson, AZ
    You might check the ground at left side of the dash. It's called G202, your headlights, turn signals, flashers, & instrument cluster all ground through there, maybe the ground is bad and causing the problem? There is also a junction block connector just above your steering column that all those grounds go through, you might check that too. The wires are all White/Black.
  9. Feb 21, 2011 at 6:31 PM
    360tacoma
    98 tacoma SR5 v6
    if it reads anything but 12v is that a bad switch? ill have to go buy a test light.
  10. Feb 21, 2011 at 6:35 PM
    360tacoma
    98 tacoma SR5 v6
    thankyou for the info ill go and try these pointers ill let you know how it goes
  11. Feb 21, 2011 at 6:36 PM
    stoneham
    stoneham Member
    Your probleme is a trailler plug is a fault changer your trailler module.
  12. Feb 21, 2011 at 6:37 PM
    NelsonTacoma
    Tucson, AZ
    Pretty much. When your turn on the switch to left or right it makes the connection for your turn signals. So if there is voltage going in but not coming out, it's the switch.
    Just to recap for you Green is left, Green/White is right, and Blue/Red is power going into the switch.
  13. Feb 21, 2011 at 6:43 PM
    360tacoma
    98 tacoma SR5 v6
    I do have trailler plug that I have not checked yet
  14. Feb 23, 2011 at 3:38 PM
    360tacoma
    98 tacoma SR5 v6
    So I went to work on my truck used the alarm to open the door and the turn signal was still on. then when I started my truck and turned the head lights on then the stuck turn signal was off and is now working like it never happend "WTF". now im not sure what to check for I guess ill start with the grounds for now and hope it was just acting up. thanks for the info.
  15. Feb 23, 2011 at 6:23 PM
    jeff624
    jeff624 Member
    Jeff
    Bayport, MN
    3" OME, Armored, and custom front bumper
    I agree with the trailer lights. It sounds exactly like the trailer light convertor, I had the exact same random symptoms. They notoriously go bad for some reason on the Tacoma's.
  16. Feb 23, 2011 at 8:45 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I also had problems with a Uhaul trailer wiring converter box... I had my side marker lights come on with the brakes and they were flashing with the turn signals too. Try disconnecting all your trailer wiring and see if it fixes itself.
  17. Mar 7, 2011 at 7:17 PM
    austinjrex
    austinjrex New Member
    Austin
    Utah
    1997 Toyota Tacoma 2.7L
    I'm having identical issues and also have a trailer light switch that was installed prior to when I bought the vehicle. I never use the adapter and it's spliced into the rear lights. Can anyone confirm that this is most likely the problem? If so should I just remove the wires that're spliced in to the rear lights?
  18. Mar 7, 2011 at 9:45 PM
    austinjrex
    Austin
    Utah
    So I finally figured out that my trailer light adapter in the rear was causing the arc. Since I never pull anything I just removed the trailer light adapter and BAM! Fixed. I'll repost if the problem re-surfaces. Thanks for the above tips guys.
  19. Mar 8, 2011 at 4:47 PM
    MowTaco
    Kansas
    There's probably a converter box somewhere in the back of your truck (I think it's 5-wire to 4-wire? That's what I think mine says on it). You can just unplug it to test it and if it is the culprit yes just take out all the splices.
  20. Sep 15, 2013 at 12:34 PM
    raydiditagain
    raydiditagain New Member
    RAY
    COLORADO
    99 TACOMA
    My left signal stays on when headlights are on. When the headlights are off, the signals work fine, however the left side makes my dashboard and brake lights flast at the same time.
    I changed my trailer hitch plug, and it worked for a day, now it's doing it again. My trailer light box is spliced into my tail light wires, is this easy to unsplice and remove? I never use my hitch.
