Turn signal side mirror upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaKeema, Oct 3, 2024.
  1. Oct 3, 2024 at 5:02 PM
    TacomaKeema
    TacomaKeema [OP] Member
    2007 Tacoma base cab 4 dr
    Hi
    I have been trying to source information -
    Is it possible to replace the side mirrors on my 2007 Tacoma with turn signal side mirrors?
    I need some form of turn indicator to put at the side of my truck. Presently other drivers on can only tell I am turning if they are exactly behind me or directly in front of me. the turn signal at the front in the headlamp is turned to the inside near the front grill of the truck. Which I think is a factory design fault.
    Please help
    I would love to install a pair of turn signal side mirrors on my 2005 Tacoma
    help please
  2. Oct 3, 2024 at 6:06 PM
    caribe makaira
    Caribbean, Puerto Rico
    You'll need an upgraded door harness on each side. Then some pin moving around if you want it OEM.
    If not, then one wire from junction box to each side.
    And, of course, the new door mirrors with the LED lamps in them.
    TacomaKeema[OP] likes this.
  3. Oct 3, 2024 at 7:47 PM
    TacomaKeema
    Can you please share with me a link where I can get what’s necessary? Also if you have a video link to share the installation would be a bonus
    Thanks
  4. Oct 3, 2024 at 7:50 PM
    TacomaKeema
    @caribe makaira please be more specific with the specs of the door harness I would need to upgrade to. Where can I source it? Thanks
  5. Oct 4, 2024 at 3:03 AM
    caribe makaira
    2015 door harness. Remove current one (each side) and replace. Connector to Driver's door needs to be de-pinned and re-arranged to match new to old door switch.
    I suggest doing the one wire from BECU (Body ECU/fuse/junction box) to each door. Tap the connector that houses the rear turn signals.
  6. Oct 4, 2024 at 3:17 AM
    caribe makaira
  7. Oct 4, 2024 at 7:14 AM
    TacomaKeema
    I appreciate your assistance
    The instructions you share does it also work for the indicator/turn signal that’s in/on the glass itself? It’s the turn signal in the glass itself that I want to upgrade to.
    Turn signal on the back of the mirror is not the most visible.
  8. Oct 4, 2024 at 7:41 AM
    caribe makaira
  9. Oct 4, 2024 at 9:58 AM
    TacomaKeema
    Thank goodness
    Please direct me to a source that has the mirrors
    Big thanks
  10. Oct 4, 2024 at 10:30 AM
    TacomaKeema
    @caribe makaira i have spoken to my father and I am simply going to do your one wire BECU suggestion. Final info I need is - can the 2015 Tacoma side mirror fit my 2007 Tacoma?
  11. Oct 4, 2024 at 11:30 AM
    caribe makaira
    Yes indeed.
  12. Oct 4, 2024 at 12:27 PM
    TacomaKeema
    :) For all your consistent communication and support thanks a million
    I will keep you informed on the progress :thumbsup:
  13. Oct 4, 2024 at 12:37 PM
    caribe makaira
  14. Oct 4, 2024 at 12:44 PM
    caribe makaira
    Google Positaps. They could be a better solution to tap the signal wires at B1. Also, probe the screws on the door when you remove the door panel for a proper ground. No need to run ground wire to cab from door.
    Also, what mirror has the turn signal on it?
    If installing the 2015 one and adding the mirror surface turns you'll get 2 sources of indications for the rubber-neck folks.
  15. Oct 5, 2024 at 6:37 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I'm also interested in this. Wish there was a simpler step by step guide for it. I can solder and cut cables, but am unsure about following diagrams with certainty..
  16. Oct 5, 2024 at 6:59 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
