Turn signal mod the easy way on 1st gen.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tmolina, Nov 19, 2009.
  1. Nov 19, 2009 at 3:32 PM
    tmolina
    tmolina [OP] Well-Known Member
    Thomas
    AZ
    '02 Tacoma dbl cab Prerunner
    2 inch lift with SAW's on front, AAL on rear
    Bakabomb02 and Colchicine like this.
  2. Nov 19, 2009 at 5:41 PM
    machman
    machman Well-Known Member
    NE Alabama
    03 DC PreRunner TRD V6
    Whats this for? The link didn't show me anything. I have been having a problem with that site for quite some time now.
    Thanks,
  3. Nov 19, 2009 at 6:16 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    This is awesome! I've been wanting to try this for some time now.....thanks!
  4. Nov 19, 2009 at 8:17 PM
    tmolina
    Thomas
    AZ
    This mod is similar to Alternating Turn Signal/Side Markers (#27), but doesn't use relays!
    From what I can tell the side markers blink with the turn signals when they are off, and opposite of the turn signals when the parking lights are turned on. I'm not sure yet as I haven't done it yet. Will post up after I try it.
    Parts:
    • 2 pieces of wire
    • 2 butt connectors
    • 2 quick splices
    • shrink tube, electrical tape, etc
    Just cut the black/white wire on the side markers in half and splice it into the Green/Black on left. For the right cut the black/white and splice to Green/yellow.
    Myfirsttacoma00 likes this.
  5. Apr 22, 2016 at 2:58 PM
    Myfirsttacoma00
    Myfirsttacoma00 Member
    Do all of these turn signal mods need extra parts and stuff? Or is it just hooking up wires with wires? My Tacoma was bought rebuilt but things are still a little banged up. Will this make it more difficult to do the mods?
  6. Apr 22, 2016 at 3:23 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Just switching the wires accomplishes the goal of making them the blinkers. Most put in brighter bulbs and resistors to stop the hyperblink. This also sets you up for the fog light mod.
  7. Apr 23, 2016 at 11:24 AM
    Myfirsttacoma00
    Can you try to help me to make it simple on the wires I don't want to short out a fuse or something. My Tacoma is a 2000
  8. Apr 23, 2016 at 11:44 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Behind your side marker lights youl see a loom. Open up loom and you find a set of wires going to blinkers and a set going to marker lights (youl have 1 extra on passenger side for the horn). All you have to do is cut both positives (both green with a stripe if i remember right) and switch them. Leave the ground wires alone.
    TheCursedTaco and Brie like this.
  9. Apr 23, 2016 at 2:57 PM
    Myfirsttacoma00
  10. Apr 26, 2016 at 12:02 PM
    Myfirsttacoma00
    Toyota wiring sux. Both parking and bumper don't light at the same time. Made me blow a fuse again. It's useless just having park blinkers they're too dim. I had cut the green parking wire and mixed it up with the green blinker/ bumper one but they only worked together during hazard lighting. I mixed the white/black wire from parking pair to blinker green and I think that caused the short to twilight lighting. Just decided to put everything how it came at first. Now only my bumper light are blinkers again
  11. Apr 26, 2016 at 12:30 PM
    devinzz1
    devin
    2023 aclb trd or mt
    What
    What are you trying to accomplish? That mod is to make the park lights the blinkers for people with aftermarket bumpers and for making the signals fog lights.
    Lukass likes this.
  12. May 2, 2016 at 9:11 AM
    Myfirsttacoma00
    I want both the parking and fog lights(original turn signals)to be turn signals. I know there is a way but can't figure it out.somebody has to know how to do it
  13. May 2, 2016 at 1:07 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Just hook both lights up to the blinker wires. Dont hook anything up to park light wires.
    Brie likes this.
  14. May 2, 2016 at 1:46 PM
    Myfirsttacoma00
    Which ones are the blinker wire?? each side has a green/black stripe and white/black stripe wire. Have you had this done before?
  15. May 2, 2016 at 1:48 PM
    Myfirsttacoma00
    The original blinker is the bumper/ fog light do I have to use the white wires? I read you shouldn't touch those. I hooked up the greens with a white and it blowed a fuse before
  16. May 2, 2016 at 3:25 PM
    devinzz1
    devin
    2023 aclb trd or mt
    You can look and see what color wires run into the socket. Its just as simple as connecting them to the park lights or whatever else you want to come one with them.
    Wulf likes this.
  17. Aug 22, 2016 at 1:02 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  18. Jun 13, 2017 at 10:47 AM
    kamaaina1
    kamaaina1 Well-Known Member
    Sean
    Vancouver, WA
    2004 TRD Tacoma x-cab
    Sorry to dig up an old thread, but...
    Just want to clarify this mod. My 04 Tacoma has the following wires: (Left/drivers) Green/black stripe & White/Black stripe then (Right/pass.) Green/white strip & Gray/Black stripe. So this mod is as simple as cutting the Green w/stripe wires and swapping and connecting them. The question I have is that I currently have an ARB bumper, but going to replace with another aftermarket bumper with no turn lighting. What should I do with the old marker wire? Does the circuit need to be complete for the mod to work? In other words, I will only have the marker light converted to a double duty marker/turn signal.
    Wow! That took a lot to "slpain" :D
    Thanks for your input!!!
  19. Jun 13, 2017 at 11:39 AM
    devinzz1
    devin
    2023 aclb trd or mt
    they can only be either park lights or signals. not both. atleast not without a switchback led/circuit.
  20. Jun 13, 2017 at 12:17 PM
    kamaaina1
    Sean
    Vancouver, WA
    Yeah, after I posted I realized that's not what I wanted. I'm wanted both marker & signal. Guess I'll need to do the add bulb mod. So I believe I need to buy sockets & bulbs. My original stock turn signals are long gone.
    Please chime in with advice.
    Thanks gang!!
