Turn signal fast blink
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockTock, Jan 15, 2017.
  1. Jan 15, 2017 at 1:03 PM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    Ok this has happened before and was an easy fix, but I can't remember how.
    Bulb is STILLL GOOD. Although it looked a little burned.replaced and problem persists.
    Also if I move the turn lever slow it will blink normal . (??)
    But it will go fast blink of I just hit the lever normally.
    Any ideas?
  2. Jan 15, 2017 at 1:07 PM
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Not sure but is it possible maybe the flasher is going bad or that maybe one of your signal bulbs is not making real good contact like caroded a bit so sometimes it flashes normal and sometimes it flashes fast as if bulb is out ... just a thought
  3. Jan 15, 2017 at 1:09 PM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    This is ALMOST ALWAYS caused by a blown fuse or bad relay or blown bulb. Something is creating a short and that's why you get the quick blinking, it 'over powers' the turn signal relay.
    QMEDJoe and mechanicjon like this.
  4. Jan 15, 2017 at 1:13 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Check trailer harness if you have one.
    dirty deeds likes this.
  5. Jan 15, 2017 at 2:57 PM
    RockTock
    Colorado
    No trailer harness. Works some of the time, not a consistant problem. But annoying as hay.
    How do I check the relay?
  6. Jan 15, 2017 at 3:04 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Do all the bulbs flash when it is blinking fast?
  7. Jan 15, 2017 at 3:10 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    if it works normally when you move the lever slowly, but not when you move it quickly, best guess is that there is corrosion or a bad contact or ground in the switch on the steering column that is making a poor contact when moved quickly, IF all the lights blink.
  8. Jan 15, 2017 at 3:26 PM
    RockTock
    Colorado
    -No bulbs blink when it goes fast.
    -Would this entail taking apart the steering column to test/ fix?
  9. Jan 15, 2017 at 3:32 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Well, change the bulbs first to be sure it isn't them, even if they look good. The make sure contacts are clean, and a good ground on the lights before going into the steering column. But if NONE of the bulbs blink, it sounds more like the switch or something in the wiring harness is bad.
  10. Jan 15, 2017 at 3:51 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    Before taking the steering wheel off, you could try grabbing and wiggling the steering column wire harness to see if it affects it. Maybe you'll get lucky and find it's a bad connection under there. On another Toyota I found a broken solder joint holding a wire to the back of the switch assembly, but that was on the high beam wire, so I wouldn't be surprised if it was something like that.
  11. Jan 15, 2017 at 4:08 PM
    RockTock
    Colorado
    Ok cool thanks
  12. Jan 15, 2017 at 4:12 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Basic question, but have you put a new flasher in and checked it?
    RockTock[OP] likes this.
  13. Jan 15, 2017 at 4:14 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I think someone asked this, but I didn't see if you answered it or not..
    Have you checked the relay?
    Try swapping your horn relay into the turn signal relay and see if it still does it..
  14. Jan 15, 2017 at 5:30 PM
    RockTock
    Colorado
    No have not put in New flasher or relay. Is the relay expensive? Is this an easy fix?
    What part exactly is the flasher?
    Thx= l
  15. Jan 15, 2017 at 6:27 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    have an Owner's manual? it should be near the fuse panel...
  16. Jan 15, 2017 at 6:29 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Turn on the ignition, turn on the turn signal slowly, so it blinks regularly, and stick your head under the dash. You will hear it "clicking" as it works. Just follow the sound...
  17. Jan 15, 2017 at 7:33 PM
    Indy
    Indy Master of all I survey.
    The flasher is mounted on the back side of your fuse panel. As you are facing it reach behind the dash and to the top left. If you turn on a blinker you will feel it clicking. Pull it straight out. Its about 10 seconds to swap one.
    But if the way things performbased on how a separate component is used, its unlikely tobe the relay and more likely to be the manipulated component.
    Iirc it takes about a minute to pull the signal stalk. Id start with that, check for a loose connection, bad joints, and then clean before reinstalling to see if the problem goes away.
  18. Jan 16, 2017 at 5:52 AM
    dirty deeds
    Nick
    Eastern KY
    Last time I attempted to replace a flasher, it was in a POS s10. Nearly had to drop the whole dash to get to it, real pain in the ass. I gave up.
    I sold the truck! lol
    I'm tellin ya...check all the bulbs, check the fuses. God forbid the stalk switch is bad!
    As far as part numbers, are you afraid to go to the auto parts store? They generally have zero problem giving part numbers lol, Google is great for this too. Not being an ass, that's how I would approach getting an answer if I was in your shoes. Plus, I like going to the auto parts store, I get smelly goods for the tuck, hand cleaner, and shop towels!
  19. Jan 16, 2017 at 6:25 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Pretty much all my experience with this type of situation is in the bulb OR the socket the bulb plugs into, and a lot of the times the ground side of the socket up inside. Make sure the bulb compress the spring, or what ever is inside to keep it tight inside the socket. Now I'm talking about #57 and # 56 type round brass socket bulbs. I don't know if yours is the flat type plug in. I always put some anti-corrosive paste (just a dab) inside the socket also.
  20. Jan 16, 2017 at 6:26 AM
    RockTock
    Colorado
    It's all good thx. I'll keep this thread updated.
