Turn signal comes on when I press the brakes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yurokhip, Feb 27, 2017.
  1. Feb 27, 2017 at 3:10 PM
    yurokhip
    yurokhip [OP] Active Member
    yreka c.a.
    01 limited trd off rd four door
    tinted windows, 2 in lift, sittin on 31's dick cepek rims
    Right turn signal comes on when I press the brake?.. Possible short somewhere? Any ideas
  2. Feb 27, 2017 at 7:00 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Check your tail light harness, where it plugs into the light housing. 4 screws hold the light in place. Remove the screws then gently separate the lens from the housing to check bulb fitment.
    Flip the housing over and inspect the back where the wires come in.
    Mine was doing the same thing and it turned out to be the ground wire on the cheap aftermarket housing.
    If that doesn't do it check your trailer plug in if you have one. Cracked or corroded wires could cause an issue too.
  3. Mar 2, 2017 at 11:22 AM
    Endo-4x4
    Endo-4x4 Well-Known Member
    Did it always do that or just now start happening?
  4. Mar 2, 2017 at 11:23 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Same problem....different make/model. In for ideas.
  5. Mar 2, 2017 at 12:40 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    The ground off one of your tailight bulbs or the holder assembly is bad.The lampholder assmebly has a common ground. When the assembly ground isn't connected to battery ground (via the wire, and then the fram/body), the power goes through the brake filament, to that bulbs ground, then through the turn signal filament via their common ground connection. The turn signal switch/relay must ground their normally positive lead when you aren't running the turn signal, which means power flows through the filament to return to ground.
    Put your hazards on at night, and you will likely see your brake lights light up in unison with the turn signal lamps.
    This took me forever to figure out the first time! In my case, it ended up being the connection to the body from the lampholder assembly. I think ir re-tapped a hole, and I use KopperKote on everything threading into steel that needs to conduct power. It's basically copper anti-seize.
    Aught2TaCO likes this.
  6. Mar 2, 2017 at 9:47 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    I had a similar problem, but the whole dash would light up when I hit the brakes, and the third brake light would fire up when I turned on the head lights. Also lost cruise control. Turned out to be the right side tail/brake bulb with the two elements. One element burned and fused to the other element, replaced the bulb and all is normal. Hope your fix is as simple as mine was.
    Dalandser likes this.
  7. Mar 4, 2017 at 7:13 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Check your ground on your trailer wiring harness
