Turn off your TPMS light FOREVER!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mach375, Feb 18, 2015.
  1. Feb 18, 2015 at 7:11 AM
    Mach375
    Mach375 [OP] Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    I can't personally vouch for years other than a 2011 DCLB (my truck), but I don't see why Toyota would move things around much.
    In the process of replacing my blown curtain airbags and ripped headliner yesterday, I found the TPMS Receiver box. Knowing my next set of tires I would be removing the sensors entirely, I tested what disconnecting the plug would do (light on? light off?).
    This is super-simple!
    The TPMS Receiver box is located above the headliner, DIRECTLY above the driver side coat hook. It's a black box about 2"x3"x1", with a single connector leading into it.
    Disconnect the plug, and the light will never turn on again. I removed mine entirely (single M8 nut...10mm wrench), drove around town, and didn't see the light come on.
    While I had removed my headliner entirely, you should be able to do this with minimal dis-assembly of the interior.
    You will need to remove BOTH rear coat hooks for sure: push a small flat-blade screwdriver under the front (hook side) lip, and twist the hook 90*, then pull it out. Then reach in from the outside through the rear window, pull down the headliner some, and either disconnect or remove the box (removal requires a 10mm wrench). The black box is located immediately above the driver side coat hook.
    RA77, Marc70, ARCHIVE and 12 others like this.
  2. Feb 18, 2015 at 9:44 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Slatroni, Marc70, rock headed and 7 others like this.
  3. Feb 18, 2015 at 10:27 AM
    Mach375
    Well, I suppose if one prefers to add extra steps, parts, labor, and cost, then yeah, that would work.
  4. Feb 18, 2015 at 10:30 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    waiting for pics
    :popcorn:
    mahaloTaco likes this.
  5. Feb 18, 2015 at 11:07 AM
    Mach375
    Done. :thumbsup:
    And though I have the headliner down, I looked it over, and I strongly believe the receiver can be reached by removing the coat hook, then going through the back window and pulling down the headliner slightly and reaching an arm up under and disconnecting the connector. I doubt any further dis-assembly is required. The connector tab is, thankfully, one of the easier ones to release!
    TacoTuesday!! likes this.
  6. Feb 18, 2015 at 11:51 AM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Awesome! Does yours have the stupid little antena on the roof? The TPMS thing you found seems to be in that area.
    Edit: never mind. I took a better look at the picture.
  7. Feb 18, 2015 at 12:00 PM
    cgs2k2
    cgs2k2 old man
    wow... i'm gonna be looking into this for sure. mine has been on for like 2 years haha
    RA77 likes this.
  8. Feb 18, 2015 at 12:04 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
  9. Feb 18, 2015 at 12:06 PM
    Mach375
    In the second pic, you should be able to see a large silver nut. That is the base of the XM antenna.
  10. Feb 18, 2015 at 12:08 PM
    Wasatch
    Wasatch Well-Known Member
    Wonder where it would be on my Access Cab....
    Same spot(ish)?
    RA77 likes this.
  11. Feb 18, 2015 at 12:28 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Are you sure this keeps the light off? It takes my truck time to realize the sensors aren't there. May be the same thing with the receiver. I would think if it can't see the receiver, it would eventually trip the light.
    There is a quick easy wire tap-and-splice that you can do behind the HVAC controller. That's what I did.
  12. Feb 18, 2015 at 12:51 PM
    RigidTaco
    RigidTaco Well-Known Member
    Kelowna, BC
    24 Sport Premium
    Solid question, can anyone vouch for this?
  13. Feb 18, 2015 at 1:42 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    What wires on the TPMS connector did you use? Is it the same wires shown on the Yaris link?
    737doc likes this.
  14. Feb 18, 2015 at 1:52 PM
    JOEKEN
    JOEKEN Well-Known Member
    PSL, FL
    2015 TRD Sport
    The circuit isn't complete with the receiver removed. Did the same to a 2005 Tundra.
  15. Feb 18, 2015 at 5:17 PM
    BassMaster06
    Dan
    South Carolina
    I seem to remember a black box that looked like this behind my stereo in my 2006. Did they relocate it in the newer tacomas? Either way im tired of looking at the light, and also every person new to riding in my truck telling me the light is on...
    RA77 likes this.
  16. Feb 18, 2015 at 5:23 PM
    BassMaster06
    Dan
    South Carolina
    Got link or write-up?
  17. Feb 18, 2015 at 5:36 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    So much heartache over a light. Mine has been on since I drove it off the lot 7 years ago. Blink blink blink, on. I can live with it. :)
    Provrev, WSW3 and ecoterragaia like this.
  18. Feb 18, 2015 at 6:33 PM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    I just followed the procedure below and installed a switch. I have two sets of rims and only one set have sensors, so the ability to enable/disable was a must for me. I have a 2011, so I needed to apply +12vdc to the blue wire as shown in the link below. Took less than half an hour to install and works great.
    http://www.toyotanation.com/forum/6...48-disabling-tpms-tpms-light-2006-tacoma.html
    Here's a pic of the switch I used...
    Jinxs, llamasmurf and Tex-Tac like this.
  19. Feb 18, 2015 at 8:55 PM
    vtdog
    vtdog Well-Known Member
    NH
    I don't understand what all the grief is about the TPMS. It does function as designed and actually tells you when a tire is low. 3 times I have gotten punctures on dirt roads in Maine from sharp shale pieces. The TPMS activated and I was able to stop and repair (I always carry a patch kit and compressor) before there was any damage to the tire.
    Just seems like some people have a hair up their ass for no reason.
    Williston likes this.
  20. Feb 19, 2015 at 4:24 AM
    js312
    Joe
    New England
