Turbo or supercharger for towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by User Name01, Aug 26, 2013.
  1. Aug 26, 2013 at 1:15 AM
    User Name01
    User Name01 [OP] Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Straight to the point. I am wanting to get some forced induction for my 2011 but am undecisive on which route to take. I will be towing a 16' lowboy and a 12' enclosed trailer, both with loads up to 6,000lbs. I was leaning towards a supercharget but I am probably wrong..........and yes, i tried the search function first, no luck with towing advice. Thanks in advance.
  2. Aug 26, 2013 at 1:51 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You would be better off getting a supercharger if you want to go with TRD but honestly forced induction with air bags and different leaf springs would help you out a lot
  3. Aug 26, 2013 at 3:58 AM
    minameismud
    minameismud Well-Known Member
    Jacksonville, FL
    11 DC PreRunner SR5
    Fog light mod, clamped tailgate
    +1 on the supercharger, unless your plan was to get a turbo that spooled up waaaaay to soon to do any good at mid- or high-rev range. and if you don't have the leaf spring TSB, do that. *and* the air bags.
  4. Aug 31, 2013 at 10:28 PM
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Disregard Fords ecoboost effort. For the Toy and towing, the TRD SC will be the best bet.
  5. Aug 31, 2013 at 10:44 PM
    Nutzo333
    Nutzo333 FreakShow333
    Cory
    Canada
    Lifted 06 SR5
    6" Fabtech Lift, 315/70 r17 Duratracs, TRD Cold Air Intake MBRP stainless with duel side exit rear exhaust
    When it comes to towing anything, Supercharger is the only way to go. Power on tap right when you need it, 0 lag.
  6. Aug 31, 2013 at 10:55 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
  7. Aug 31, 2013 at 11:50 PM
    User Name01
    Bolbi Stroganovsky
    Yeah, I was thinking supercharger but I am not too informed on "turbos" so I decided to seek knowledge since it is for towing. Plus, I am a fan of bolt-on applications, I don't like to cut/chop. Thanks guys
  8. Aug 31, 2013 at 11:57 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Turbo...diesel :D
  9. Sep 1, 2013 at 12:33 AM
    User Name01
    Bolbi Stroganovsky
    No joke, you're right. Toyota needs to get on it, for the states
  10. Sep 1, 2013 at 12:37 AM
    MGMTacolover55
    Orygun
    floor Mats
    Toyota needs a diesel option and updated engine options
  11. Sep 1, 2013 at 12:43 AM
    User Name01
    Bolbi Stroganovsky
    Yeah, Toyota seems to be lacking in the engine department. They should just implement the v8 in the Tacomas already. The Chevy colorado/canyon has an optional v8 and I hear Nissan is leaning towards deisel in the next gen trucks. Oh well
  12. Sep 1, 2013 at 12:56 AM
    MGMTacolover55
    Orygun
    floor Mats
    They will most likely be forced to make the tundra a diesel, make the Tacoma better with more engines and get off their butts and innovate
  13. Sep 1, 2013 at 7:39 AM
    Diehl1228
    Diehl1228 New Member
    Nissian titan will have a 5.0L v-8 cummins in the next generation.
  14. Sep 1, 2013 at 7:53 AM
    BamaToy1997
    Bill
    Navarre, FL
