Turbo BS Thread
Discussion in 'Performance and Tuning' started by Clay_916, Mar 20, 2017.
  1. Apr 7, 2022 at 6:38 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    @Rola2010
    I dont know any mild steel, but Ace Race sells stainless steel bits fwiw.
    Rola2010 likes this.
  2. Apr 7, 2022 at 6:45 PM
    Rola2010
    Rola2010 Well-Known Member
    Honolulu, HI
    2010 Tacoma 2wd base RC
    Thanks - Ace Race does have some mild steel stuff but it's fairly limited, and most of what I've found online is from plumbing shops, so I may just try to source something locally.
  3. Apr 7, 2022 at 6:57 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I know a guy that has more than 1 plumbing piece in his set up... And maybe a piece of trampoline frame as well...
    Torspd and Brake Weight like this.
  4. Apr 8, 2022 at 7:44 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  5. Apr 8, 2022 at 8:06 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Is it noticeably weaker under throttle? I had a pin hole once in my gauge supply and thought I was having issues. Found it when I did pressure test for leaks.
  6. Apr 8, 2022 at 8:43 AM
    Jon64l
    Jon
    I had a blocked cat on a Na Nissan truck. Wouldn't run much higher than 1500 rpm and minimal pedal input.
    Also check for cracks/exhaust leaks pre turbo.
    Torspd likes this.
  7. Apr 8, 2022 at 9:19 AM
    05Taco4x4
    2TR-FE Enthusiast
    Runs butter smooth through all rpm and builds to 2 psi quick, it maintains it but not past it.
  8. Apr 8, 2022 at 9:21 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I did ace race parts for my manifold but that was forever ago when we didn't have material shortages.
    I had a clogged cat once. Makes the truck feel like it's constipated or trying to rev out but it's not wanting to.
  9. Apr 8, 2022 at 10:00 AM
    Jon64l
    Jon
  10. Apr 8, 2022 at 1:20 PM
    05Taco4x4
    2TR-FE Enthusiast
    My manifold didn't suffer that, I posted a pic of it recently; it is possible it has since happened but I doubt that, from the outside it looks ok.
  11. Apr 8, 2022 at 1:54 PM
    Brake Weight
    Possible blown gasket? Should be a noticeable sound of it.
  12. Apr 8, 2022 at 2:01 PM
    05Taco4x4
    2TR-FE Enthusiast
    I replaced it recently, looks to still be there.
  13. Apr 8, 2022 at 2:02 PM
    05Taco4x4
    2TR-FE Enthusiast
    This problem is on the exhaust side, I'm 100% confident not on the charge side.
  14. Apr 8, 2022 at 2:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Melted cat? Clogged air filter?
  15. Apr 8, 2022 at 2:48 PM
    Jon64l
    Jon
    2 psi WG spring
    Torspd likes this.
  16. Apr 8, 2022 at 3:19 PM
    05Taco4x4
    2TR-FE Enthusiast
    Maybe but I don't think so, no and no haha
  17. Apr 8, 2022 at 3:43 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Something with the w/g could be bad. Whenever you have the chance to attach it to an air compressor, you could check its operation.
  18. Apr 8, 2022 at 4:18 PM
    05Taco4x4
    2TR-FE Enthusiast
    I did, it's good too.
    Torspd[QUOTED] likes this.
  19. Apr 8, 2022 at 4:33 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    What about disconnecting the exhaust and seeing if it spools better. The afr will be off but you'll know by sound if it's clogged.
  20. Apr 8, 2022 at 5:39 PM
    05Taco4x4
    2TR-FE Enthusiast
    I'm out of town at the moment, I was thinking do this around the block middle of the work day when I get back haha.
    Torspd likes this.
