Tuning Split Second Piggyback Ecu
Discussion in '1st Gen. Tacomas (1995-2004)' started by tupelolathrop, Mar 2, 2022.
  1. Mar 2, 2022 at 12:10 PM
    tupelolathrop
    tupelolathrop [OP] Member
    Tupelo
    Kauai
    1995.5 3.4l V6 Regular Cab
    3" lift ADS Coil overs, SPC UCAs, 4Runner Limited wheels,
    I'm looking for someone that can help me with tuning a supercharged Tacoma with split second piggyback eco and 5th injector. I'm located in Southern California and I'm willing to pay someone for their time and knowledge. Thanks
  2. Mar 2, 2022 at 12:38 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
  3. Mar 2, 2022 at 12:55 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    2004Taco[QUOTED] likes this.
  4. Mar 2, 2022 at 1:58 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You don't even need to disconnect it, there's no way to detect it through ODBII or full smog. Just make sure it's hidden in your dash.
    I can help via messaging OP. You just need to let us know what you're struggling with.
  5. Mar 3, 2022 at 1:29 AM
    tupelolathrop
    Tupelo
    Kauai
    I don't need to worry about getting it smogged. It can't pass anyway. I just need someone who can tune it for me. Thanks
    2004Taco likes this.
  6. Mar 3, 2022 at 6:16 AM
    02hilux
    Planet: EARTH
    Nothing to worry about. A handful full of guys with URD 7th injector (both 99 and under that require tail pipe sniff and 00+ with just obd port plug) passed without detection. Hell, even ov/kd tuned passed without detection.
  7. Mar 3, 2022 at 11:48 AM
    tupelolathrop
    Tupelo
    Kauai
    Just found out you can take it to the Split Second shop in Santa Ana and they'll street tune it for $125.
  8. Mar 3, 2022 at 1:53 PM
    e.deCastro
    Eric
    San Diego
    What???? Dyno tune? I will do that even if it’s not. Thanks.
  9. Mar 3, 2022 at 3:10 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    That sounds like an hour of labor, which I can tell you 100% is not going to be an ideal tune from the street. You literally have to shut down the engine after every adjustment with these. And if you don't have an O2 simulator you have about less than 3 mins to log data before the ECU throws in a massive error wrench and you have to reset the battery.
