Tundra steering rack upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vanillion, Oct 26, 2018.
  1. Oct 26, 2018 at 10:44 AM
    vanillion
    vanillion [OP] Well-Known Member
    Canadia
    09 trd offroad
    superduty axles swap, custom 3 link front, chevy 63's rear
    Has anyone upgraded their steering rack to a Tundra rack? I know Solo Motorsports sells one modified and ready to be fabbed in. Anyone have any experience with this? Or modifying a Tundra rack themselves?
  2. Oct 26, 2018 at 10:45 AM
    MikeGguarantee
    MikeGguarantee Member
    Michael
    '17 DCSB
    Cali Raised lighting
    What would the potential benefit of this be? Different steering ratio?
  3. Oct 26, 2018 at 10:54 AM
    vanillion
    Canadia
    09 trd offroad
    Larger steering shaft and bushings to hopefully last longer and increase overall rigidity of the steering rack
  4. Oct 26, 2018 at 10:55 AM
    vanillion
    Canadia
    09 trd offroad
    Biblebuilt4x4 likes this.
  5. Oct 26, 2018 at 12:06 PM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    It looks like a healthy upgrade but for the price and fab work you'd really have to justify it. Hopefully Marlin releases theirs soon.
    03taco and 12TRDTacoma like this.
  6. Oct 26, 2018 at 1:27 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
  7. Oct 26, 2018 at 1:58 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Holy moly thats pricey. Guess you gotta pay to play though.
    Redsyota likes this.
  8. Oct 26, 2018 at 2:00 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Much cheaper to just replace existing rack with warrantied reman units as needed unless you really have a race truck
    jjhitchen likes this.
  9. Oct 26, 2018 at 2:46 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    This seems awesome but the price is a killer.
    I'm seeing reman Tundra racks on ebay in the $200-$300 dollar range. Is it worth $1200 to cut down the shafts and bump up line pressure? The line pressure thing might be as simple as an orifice change or adjustment. Plus it still needs fab work to fit the Tacoma.
    I could see $1500 if it was a super tough bolt on. It makes me wanna get a rack from the wrecking yard to experiment with...
  10. Oct 26, 2018 at 4:09 PM
    Charger92
    Charger92 Built for pure function!
    British Columbia Canada
    2007 Tacoma double cab long box
    I would just solid axel for that price!
    Mully likes this.
  11. Oct 26, 2018 at 8:00 PM
    vanillion
    Canadia
    09 trd offroad
    I was considering hacking up a tundra rack. I'm curious as to what exactly needs to be done to a tundra rack to make it compatible with our tacos. Could possibly just get it machined myself
  12. Oct 26, 2018 at 9:23 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    @Arcticelf has one, perhaps he can provide some insight. I know he was telling me about it the other weekend.
    fatfurious2 and vanillion[OP] like this.
  13. Oct 27, 2018 at 4:48 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    The voodoo in the solo rack is the valveing changes. Otherwise it's just cutting the Piston down and re-tapping the inner tie rod holes. Both the solo and Marlin rack with make turning big tires easier, and stronger.
    Mounting it isn't that hard, you have to move the mounts 1/2" farther apart center to center, so 1/4" each.
    If the Marlin rack is bolt on, that would be a huge advantage. Otherwise I understand it's pretty similar.
    The other thing to consider is that the tie rods are matched for the rack on our trucks. Beefing up the rack makes them a real weak spot. Beefing up tie rods makes the spindle a weak spot.
    Bottom line, I'm very happy with my solo rack, and would recommend it, or something like it.
  14. Jul 29, 2019 at 2:37 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    not when the replacement job is a total cunt like on the 3rd gens.
    I wonder if theres an option for doing this on the 3rd gen.
    I'm currently waiting on Toyota corporate to say whether they will warranty my steering rack thats fucked already at 58,000km
    tacoma16 likes this.
  15. Jul 29, 2019 at 2:38 PM
    Joe23
    pretty sure marrack is a no go for stock. need to run their LT kit
  16. Aug 6, 2019 at 10:30 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    I did my tundra rack mod myself...and soon I'm gunna be offering a few options for people to help with the cost making this mod more affordable and helping me buy parts for my LS swap lol...
    I'm gunna offer a complete modded rack assembled.
    And
    Offer machining services for the rack gear and control valve if you have a rack and take it apart and send me those parts...
    My dad and I are workin on making a general dissassembly/reassembly video for youtube and a general overview of what you gotta do for the install.
    The Marrack...from the looks of it they say must be used on LT and it looks like they're using the factory inner tierods which also makes me wonder if they even shorten the rack gear?..... there's no reason why a tundra rack modded to the Tacoma width wont work on a stock width truck.
    And no it's not quite as simple as just chopping and retapping....the rack gear is hollow and you must make a press fit chromoly insert for one side and tig weld it in then post machine it flat....its a bit of work to do it...even with all the right tools(which I have)
    sil80s13, TireFire, zippsub9 and 2 others like this.
  17. Aug 6, 2019 at 11:28 AM
    Joe23
    Pretty sure the inners are beefier on marrack and based on their thread it won't work because it's too long to fit without LT.
    but I'm definitely interested to see a Tundra swap for a 3rd Gen
  18. Aug 6, 2019 at 12:04 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    want
  19. Aug 6, 2019 at 12:09 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    In for when you get it sorted
  20. Aug 6, 2019 at 2:16 PM
    Basikbiker
    Trav
    Exactly my point....all they're doing is swapping in a rack directly....which is poop sandwhich as far as bumpsteer geometry goes...the inner tierods on a tundra are alot beefier than the taco ones...which makes me wonder if they even machine them down or not
