Tundra Steering Rack into a Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hualampeter, Sep 8, 2018.
  1. Sep 8, 2018 at 8:40 AM
    hualampeter
    hualampeter [OP] Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
  2. Sep 8, 2018 at 9:33 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
  3. Sep 8, 2018 at 10:05 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
  4. Sep 8, 2018 at 10:29 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What are the benefits of this
  5. Sep 8, 2018 at 10:43 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Its a stronger steering rack, which is mainly needed with larger heavy tires, hard offroading, and esecially long travel trucks. I plan on it whenever my stock one goes out.
  6. Sep 8, 2018 at 11:23 AM
    Arcticelf
    Gladiator
    Pretty much what @Sterling_vH111 said. Bigger piston, bigger gears, built for a half ton truck.
    It's stronger than your tackma tie rods, and probably than the spindles.
    12TRDTacoma and hualampeter[OP] like this.
  7. Sep 8, 2018 at 1:52 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    What kind of fab is required?
    12TRDTacoma likes this.
  8. Sep 8, 2018 at 2:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Now here is an amazing functional mod which would be incredible to have for better longevity into the Taco.
    I would love to know myself what type of fab is required to make this fit, if and when mine gives up the ghost I will replace it with a Tundra one if the mod is fairly straight forward to do.
    hualampeter[OP] likes this.
  9. Sep 8, 2018 at 3:07 PM
    Arcticelf
    Gladiator
    You have to notch the frame where the rack passes through. Then weld in plates.
    You have to grind the mounting bungs out of the frame and move them outboard 1/2" center to center. Then weld them back in.
    Changing the rack is otherwise the same, remove and replace the lines, reconnect the steering shaft, and bleed the power steering.
    Then go get an alignment.
    In addition to the rack from solo you need:
    -mounting bolts (I used 1/2" grade 8),
    -boots (tundra boots from Rock Auto)
    -boot clamps (hose clamps)
    -steel to plate up the notches
    -grinder, cutting wheel, welding tools.
  10. Sep 8, 2018 at 3:13 PM
    Arcticelf
    Gladiator
    I'd recommend also doing solo tie rods with hiem joints. You can get them for mid travel (stock geometry) or any size if LT. It's a much stronger system than the OE, and it makes the rack stronger than the frame.
    Check out my Instagram and build thread for more pictures of what's involved.
  11. Feb 6, 2024 at 10:48 AM
    eglouch
    eglouch Member
    14' ACLB
    3" lift - Toytec Boss Coilovers SPC UCA's. SOS Concepts Front bumper. FN Pro 5 Star Bronze Wheels - General Grabber AT/X 285/75/R16
    Do you have full contact with your stock steering stops with the new rack? I just swapped in a Toyo-steering rack upgrade and I just got my alignment dialed in and I have and inch of space at full lock from my steering stops to my LCA.
  12. Feb 7, 2024 at 1:17 PM
    Arcticelf
    Gladiator
    Yes, I have full range from lock and to lock. Which upgraded rack did you use?
  13. Feb 8, 2024 at 10:14 AM
    eglouch
    eglouch Member
    14' ACLB
    I got a rack from Toyo-steering
    It was a little cheaper than the alternatives and it installed fine but I didn’t realize that you loose some steering angle. I got the kit with the tundra tie rods and I’m wondering if switching to a hiem would allow the geometry to change.
