Tundra OEM tie down - fits aftermarket batteries
Discussion in '2nd Gen. Tacomas (2005-2015)' started by unclemat, Dec 13, 2020.
  1. Dec 13, 2020 at 5:36 PM
    unclemat
    unclemat [OP] Well-Known Member
    2012 TX Baja
    As most folks know Toyota put a non-adjustable battery tie down on the truck which means virtually no aftermarket battery fits. While the factory tie down can be drilled out to fit a normal J-bolt I wanted an OEM bolt-on solution. Turns out Tundra uses a tie down with adjustable J-bolts on both ends. Part numbers:
    74481-0C030 tie down
    74451-0C020 rear j-bolt
    90080-18073 nut
    The j-bolt is tad long but works. Picture shows the new tie down installed and the original Tacoma one next to it.
    JDM likes this.
  2. Dec 13, 2020 at 11:35 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I got generic J hook bolts on Amazon for less than $7 that fit the oem hold-down bracket. Cut to length. And that was cause corrosion got to one of the bolts; otherwise, the OEM setup worked for the first battery replacement I got, a Walmart group 24
  3. Dec 14, 2020 at 7:22 AM
    unclemat
    2012 TX Baja
    The OEM parts were under $15 total FWIW.
  4. Dec 15, 2020 at 12:36 PM
    BEE-ROCK
    BEE-ROCK Well-Known Member
    Brock
    Dallas, TX
    2013 Tacoma TRD Sport
    TRD Pro Grille, TRD Pro Headlights, Bilstein 5100's and 5125’s.
    I just did this to my Tacoma! Although, I already knew about the Tundra bracket because my last truck was a Tundra! I even bought the same battery you have!
  5. Dec 16, 2020 at 6:53 PM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Thanks for the perfectly timed great info. Just ordered:thumbsup:
  6. Dec 28, 2020 at 5:38 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    This Tundra tie-down, 74481-0C030 tie-down, does it fit nicely/fits without modification over an aftermarket 27F battery? I had to gently massage the OEM tie down in my Tacoma to fit aftermarket 27F batteries, as they are just a tiny bit larger than the 27F that came originally in it. Even with some gentle persuasion, it still leaves marks on the outside casing of the battery. I'm hoping this would fit much better.
    thanks
