Tundra front brake upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drico, Dec 31, 2018.
  1. Dec 31, 2018 at 9:35 AM
    Drico
    Drico [OP] Active Member
    Dave
    New Jersey
    1998 OD Green Tacoma 4x4
    Complete body Line X 6" Fabtech lift TIS 544 33 x 12.5 x 20
    Gents...does anyone have the part #s handy for the tundra front brake upgrade for our 1st Gens?....rotors...calipers...
    I believe it's off the 2008 Tundra 4x4....can someone confirm??
    Dave
  2. Dec 31, 2018 at 9:36 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    You can buy it in a kit
  3. Dec 31, 2018 at 9:37 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
  4. Dec 31, 2018 at 9:40 AM
    Drico
    Dave
    New Jersey
    Wow bro...that looks great...you said I can buy it as a kit...do you have a link or site I can look at?.. any forum vendors that offer this kit?
    Dave
  5. Dec 31, 2018 at 9:43 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Abeyancer, The Driver and 970btu like this.
  6. Dec 31, 2018 at 9:48 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
  7. Dec 31, 2018 at 9:53 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  8. Dec 31, 2018 at 9:54 AM
    Drico
    Dave
    New Jersey
    Nice bro...thanks...I was just on LCE..they have the complete kit for $500 ND change...rotors...calipers..brake lines...and pads...even offer extended brake lines for use with a lift kit...
  9. Dec 31, 2018 at 9:55 AM
    Smash8ight
    Smash8ight Well-Known Member
    04 trd
    Bone stock
    Lc engineering sells the kit.
  10. Dec 31, 2018 at 10:04 AM
    Drico
    Dave
    New Jersey
    Just pulled the trigger and ordered the complete kit...with extended brake line option...
  11. Dec 31, 2018 at 10:28 AM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    What length brake lines did you go with and how much lift if any on your truck?
  12. Dec 31, 2018 at 10:28 AM
    Smash8ight
    04 trd
    Bone stock
    The calipers will come raw(no paint)and I got three different boxes from different locations.
    Go ahead and go to advance auto and get the caliper paint.take time to apply several coats before install,it will payoff in the end.
    I don't have any pics of mine(not that guy)but me and a buddy did the install in a couple hours.I pressure bleed mine with a machine we use in the shop.
    This was my first upgrade before any suspension or tires,the brakes were fixed.
  13. Dec 31, 2018 at 10:31 AM
    Drico
    Dave
    New Jersey
    6" lines over stock...talked to LCE and confirmed...I'm running a Fabtech 6" DB lift
  14. Dec 31, 2018 at 10:33 AM
    Drico
    Dave
    New Jersey
    Sounds good ...I have a guy I use that does powder coating...may drop the calipers off to him and have him do his thing...
  15. Dec 31, 2018 at 10:35 AM
    Nevin
    Washington
    Ok. Thanks for the info.
  16. Dec 31, 2018 at 10:43 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yep. I have that kit in exception of the rotors. I went for Baer Performance Rotors instead of the ones that come with that kit. I also used the LC Engineering brake line kit which matches the stock Tundra lines.
  17. Dec 31, 2018 at 10:51 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Here's a full write-up with lots of pics if you want to go with links to OEM parts (which I did, and am very happy with)
    https://adventuretaco.com/new-to-me-tires-and-a-tundra-brake-upgrade/
  18. Jul 20, 2019 at 9:09 AM
    JpAdct
    JpAdct Well-Known Member
    PB County, FL
    2003 Tacoma ExtCab
    Hey all,
    I just did the upgrade and now have an issue with my (dang near) new OEM LCA bushings. I’m curious to see if the masses have seen this before.
    Brakes are working well, maybe a little too well because now my lower arm bushings are flexing causing my LCA’s to shift in the mounts when braking. I just installed new OEM lower arms and bushings 4,000 miles ago when I did the ball joints. Talked to some off-road techs and they agreed it wasn’t causing any issues or unsafe, just annoying and would likely cause my new bushings to wear prematurely. It sounds like new poly bushings will correct this, but I’m not in a hurry to tear it all down again just yet. With a crazy work schedule, I’m stuck having to pay for this work and costs are adding up.
    Any feedback would be appreciated. Thanks
  19. Feb 17, 2020 at 1:04 AM
    ToyotaTod98
    ToyotaTod98 Well-Known Member
    Tod
    98 limited 4x4 excab white
    Lift ,wheels,micky tires, 4.56 front and rear locker.
  20. Feb 17, 2020 at 1:08 AM
    ToyotaTod98
    Tod
    Love how that looks. Did u get new brake lines? I heard the stock Tacoma ones don't work. And if you did, which ones did you get and where from? Cause when I clicked on that Amazon link it pulled up that set and at the bottom it had a set of brake lines u could bundle with them. Did u get those?
