Tundra Brake Upgrade Parts Reccomendation
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacuma, Sep 23, 2023.
  1. Sep 23, 2023 at 11:19 AM
    tacuma
    tacuma [OP] Member
    Lucan
    Oakland, CA
    1999 Tacoma 2.7 4x4 5spd
    Hey there, does anyone have experience with the Tundra brake upgrade kit on 1st gen Tacoma. I was going to go with OEM Tundra rotors and pads. But not sure what 13WL calipers to get as there are so many options. I was thinking of the A Premium calipers. If anyone has recommendations that would be great.
  2. Sep 23, 2023 at 11:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tons of threads on this, even write ups.
    ARCHIVE likes this.
  3. Sep 23, 2023 at 11:21 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
  4. Sep 23, 2023 at 11:24 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I like the Napa Calipers myself. But if you can find some used OEM calipers that are in good condition. Those would be good too.
    Also try the Search bar
  5. Sep 23, 2023 at 12:07 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    This page has a great step-by-step guide (with pics) on the upgrade, as well as links to all the parts needed (at varying price points).
    https://adventuretaco.com/guide/step-by-step-tundra-brake-upgrade-on-a-tacoma-or-4runner/
    OEM is best for the pads, but for the calipers you shouldn't pay the premium. Get them from your local parts store (ideally) or amazon, which will give a lifetime warranty in case you ever need to replace them.
    And don't forget the upgraded lines, they make a big difference with the larger calipers.
    SpokeWench and Madjik_Man like this.
  6. Sep 23, 2023 at 11:42 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Think I went with rock auto for the calipers, Amazon for the rotors, O'Reillys for the pads, and this guy ^ for the brake lines
  7. Sep 25, 2023 at 6:05 AM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    I went with this $200 Tundra Rotor/Caliper/Pad kit as well as Adventure Taco's brake line kit and Toyota OEM shims and the recommended Toyota OEM pads in the AT guide.
    https://www.ebay.com/itm/195545139293
    I also went with Motul DOT 5.1 Synthetic brake fluid, which I have used for years in all my vehicles. I believe the synthetic is shown to be more resistant to the damaging effects of water absorbtion.
    All is well after about 1300 miles on the parts.
    Laxtoy likes this.
  8. Sep 28, 2023 at 4:56 PM
    Lil'John
    Lil'John Active Member
    2002 Tacoma TRD 4wd
    Anyone know the pitch of the brake line to the Tundra caliper? It is M10 thread. Is it 1.0?
  9. Sep 28, 2023 at 5:09 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    mattyosh and semco-inc like this.
  10. Sep 28, 2023 at 6:40 PM
    Lil'John
    2002 Tacoma TRD 4wd
    That is an approach.
    But back in the day of FJ40s (and by extension minitrucks), we went to a single line in an effort to get rid of the hard lines from caliper. Two less leak points.
    From what I'm seeing, a standard rubber line is ~$15ea(Summit search) but I'm trying to narrow down pitch at caliper. I could go 3an stainless plus fittings. *cheap bastard hat on*
  11. Sep 28, 2023 at 7:24 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I have that same hat! :hattip::thumbsup:
    In the case of the Tundra upgrade, I initially wore that one too. Turns out, not such a good idea due to the design of the 13WL and 13WE calipers, which were/are designed for a situation where there's a hard line into the caliper rather than a banjo.
    After going through the process of having a 13WL seize up on the trail, and having to source a replacement that would actually work with the single-line setup, I wrote up my analysis.
    Making It Right: Tacoma-to-Tundra Brake Upgrade
    You'll see at the bottom there, that's how the kit came to life.
    Lil'John[QUOTED] and TRD493 like this.
  12. Sep 29, 2023 at 2:14 PM
    Lil'John
    2002 Tacoma TRD 4wd
    I wasn't planning on banjo at caliper. There is male threaded M10 flex lines available. I'm trying to find pitch needed for Tundra caliper.
    As I noted, old FJ40s and minitrucks ran the same exact "short hardline" setup. Many/most people got rid of it and went male threaded flex line to the caliper with no issue.
  13. Sep 30, 2023 at 1:47 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Why not go with the banjo bolt setup? Keeps the brake line tight to the caliper so nothing sticking out to get hit by debri.
    IMG_0900.jpg Not my truck, but mine are the same. Been running for more than 10 years, no problems
    Wheelers Offroad, LCE, poly performance all sell extended stainless steel brake lines with a banjo fitting.
  14. Sep 30, 2023 at 4:08 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Banjo only works with certain 13WL (and 13WE) calipers, since they were designed for hard lines. No way to know prior to getting your hands on the specific caliper. Details here: Making It Right: Tacoma-to-Tundra Brake Upgrade. So, not to say that you can't make it work (and many do, I did initially even), but it's not easily guaranteed.
