Tundra brake swap questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by odiesplace, Apr 1, 2017.
  1. Apr 1, 2017 at 9:09 AM
    odiesplace
    odiesplace [OP] Well-Known Member
    Michael
    Oregon
    95 Tacoma
    I'm wanting to do the tundra front brake upgrade. I have a 95.5 Tacoma, and I need to know what year tundra parts I need to get. New to Tacoma trucks so I'm not sure what parts to get.
    Thanks
  2. Apr 1, 2017 at 9:16 AM
    Hootney
    Hootney Well-Known Member
    Jefferson Ohio
    09 Tacoma TRD dbl cab sb
    Locker mod, fog light on, seatbelt chime, map lights on& led so far.
    Good question same with me for a 2009 TRD I would like to do the same or just get new rotors and pads from ebc. I use ebc for my Harley and both my quads. I pull my boat on the weekends on my Tacoma and last year I had a Chevy half ton. So brakes weren't an issue.
  3. Apr 1, 2017 at 9:38 AM
    odiesplace
    Michael
    Oregon
    95 Tacoma
    I'm looking at pulling a glass drift boat so I'm hoping to do the upgrade.
    Hopefully some of the Tacoma gurus will chime in
    Hootney likes this.
  4. Apr 1, 2017 at 10:20 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    I have the 231mm Tundra up-grade. IIRC, 2003.
    You will need to drill out the end/ tip of the Tacoma banjo bolt on a drill press to insure proper seating into the Tundra caliper.
    Everything else is straight forward from there.
    DustStorm4x4 likes this.
  5. Apr 1, 2017 at 10:28 AM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    One of the best mods I've done to the truck. 2005 Tundra V8 4x4 parts. Everything you'll need to know:
  6. Apr 1, 2017 at 10:49 AM
    Hootney
    Jefferson Ohio
    That is a solid write up. Is it going to be the same for a second gen taco? I see the article is for a 1st Gen.
  7. Apr 1, 2017 at 10:58 AM
    McMash
    Tyler
    Gig Harbor, Wa.
    Sorry, this was in reference to 1st gens.
    I'm not very familiar with the 2nd gen brakes, but I believe the wheel bolt patterns are the same? I've only ever heard of this swap on a 1st gen, so I couldn't be of much help in that regard. Maybe someone's done it before and the 2nd gen section would have answers?
  8. Apr 1, 2017 at 11:03 AM
    Hootney
    Jefferson Ohio
    Thanks for that. I ain't familiar with the truck as far as the brakes. I haven't serviced them since I've owned it. They are starting to surge a little so I will be servicing them soon. I have heard that the TRD brakes are 4 piston already so pads and rotors will be a sufficient upgrade to the performances of them. But hey, where else to go to ask questions right?
  9. Apr 1, 2017 at 11:06 AM
    McMash
    Tyler
    Gig Harbor, Wa.
    No worries. I'm sure there are companies (EBC, Brembo, Stoptech, etc) that make performance-spec pads and rotors you could swap in easily and get noticeable improvement. That'd be simple and cheaper, too. Worth a try.
  10. Apr 1, 2017 at 11:08 AM
    Hootney
    Jefferson Ohio
    Yeah that's where I'm at, but the upgrades to these trucks are like tattoos. 1 thing leads to another next thing you know you're covered.
    ThunderOne, mechanicjon and McMash like this.
  11. Apr 1, 2017 at 11:23 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I got my calipers from a 2005 2wd Tundra. 2004-06 will work. The important thing is to be sure the caliper has the 13WL stamping on it. The same calipers are on the Sequoia of the same age.
    If you upgrade the brake lines with the ones from Wheelers offroad (and use their banjo bolts), then you don't have to drill out the stock banjo bolts.
    Dalandser and Ritchie like this.
  12. Apr 1, 2017 at 11:29 AM
    Ritchie
    A buddy I wheel with has a 2013 TRD Tacoma. His brakes are the 231mm so no need for the up-grade. I'm not sure of other 2nd gens.
    Hootney likes this.
  13. Apr 1, 2017 at 12:01 PM
    Hootney
    Jefferson Ohio
    That's cool to know. I will take a wheel off and figure it out first hand. I need a tire rotation anyways. Thanks for that.
  14. Apr 1, 2017 at 6:33 PM
    Ritchie
    IIRC, the 13WL version is the 199mm which are smaller. I could be wrong.
    Does anyone have a pic to verify to help OP?
  15. Apr 1, 2017 at 6:43 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  16. Apr 1, 2017 at 6:46 PM
    Ritchie
    Here are the part numbers which I originally purchased from NAPA:
    RT side caliper: LE 3264 (loaded w/hardware) $100.00 re-furbished
    LF side caliper: LE 3263 (loaded w/hardware) $100.00 re-furbished
    Rotors: UP 86931 2 @ $50.00 ea
    These are 2010 prices which may vary.
    Recently, I did replace rotors due to rust while sitting out, exposed to the rain. I went with Toyota rotors which are a much better piece than aftermarket.
    Good luck.
  17. Apr 1, 2017 at 6:54 PM
    McMash
    Tyler
    Gig Harbor, Wa.
    The 13WL's are the 231mm. The 199mm is the 13WE. This is referenced in the 1st paragraph of that write-up I linked up at the beginning. Not sure what needs to be verified, or what the issue is?
  18. Apr 1, 2017 at 7:13 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Sequoias up to 07 have the 13wl calipers.
    Fwiw, I bought my calipers off eBay and got new pads and rotors from Toyota.
    Ritchie likes this.
  19. Apr 1, 2017 at 7:13 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    I have the 13WL and the only modification needed was the small trimming of the dust shield everything was bolt on and smooth, I used wheelers brake lines too.
  20. Apr 1, 2017 at 10:22 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    For those that prefer videos over write-ups, my buddy Sean and I have a video you could use as a tutorial for this upgrade. We did the upgrade for a 3rd Gen 4runner but it's very similar. A subscriber to our channel did say they needed to install the wheelers brake line kit to make it work because the OEM fittings on your Tacos don't match up right with the Tundra calipers.
    <iframe width="560" height="315" src="https://www.youtube.com/embed/P8zy-j4UBUo?list=PLPMpPriBUyJC_aXG6cIRhjv6w4heeIZJ6" frameborder="0" allowfullscreen></iframe>
    philmdnls, jammer and Dalandser like this.
