Tundra Brake Swap and PowerStop z23 review
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kens04Taco, Oct 6, 2018.
  1. Oct 6, 2018 at 7:31 PM
    Kens04Taco
    Kens04Taco [OP] Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Hey First-Genians,
    I just finished my tundra swap and I wanted to give a few tips and tricks for those of you who would like to attempt this mod with the z23 power stop kit.
    I feel like the procedure for changing rotors, pads, and calipers are well documented and anyone can easily look up this information so I will omit the basic procedure. That being said I would like to add something that I have not seen in any other write up about this mod.
    13WL calipers for a 2005 tundra are designed to be mated with a steel line, not the flex line that first gen tacomas have. With this, you will see that the female bore that you thread your banjo bolt into will not thread in all the way. This is due to a pressed in feral inside the threaded bore. Now from what I've seen most people either buy a kit (wheelers) which I assume includes a shorter banjo bolt or some other solution to over come this feral. Another solution I found people using was to shorten the banjo bolt, then drill the banjo bolt with a 3/8 drill to create a a cavity that goes around the feral. After further inspection and a coffee break. We realized the feral was just pressed into the caliper and could be removed. So we very carefully got a screw with a course thread pitch and very slowly threaded the screw into the feral. After about 3 threads we pulled it out with relative ease. After that it was as simple bolt on deal. Trimmed the dust shield just a bit, mounted the rotors, installed the calipers/pads, and started my bleed process. I can say that at first I did have a bit of an issue with pedal "firmness" but after some extra bleeding I got the pedal to firm up to where I feel comfortable driving it. I will do another bleed tomorrow to get anything that might be left.
    Set up that pertains to the brakes
    Method 16x8 mesh wheels
    Z23 Power Stop brake kit from summit for a 2005 tundra
    factory hub/ factory wheel studs/ factory spindle
    marlin crawler extended front brake lines
    new copper crush washers
    factory banjo
    factory caliper mounting bolts
    PowerStop Z-23 Review
    So after reading a lot of reviews I decided on this kit from summit. I had my doubts but figured for the price it was worth a shot. After opening the box the rotors and pads looked great. After opening the caliper boxes I instantly noticed damage to the powder coat. I sent them back with no issues because summit is awesome with that kind of issue. They immediately sent me another set out and after opening the box I noticed basically the same issue but it was less and I made the choice to run um. After following the break in procedure they provide and after some extra brake bleeding this kit kicks ass! I've never had my truck stop like it does now. I can lock um up no problem. Although it is day one, I can say first impressions is great. I'm so happy with the performance of these brakes. I mainly got them with the hopes of a small amount of improved breaking but mainly to help with heat when I'm wheeling and going up and down hills for camping n such. It has immensely increased stopping power. Although my pedal does feel a bit softer than before. I assume that the 13WL runs a large piston diameter so I can understand a bit of a softer pedal. Hopefully I can stiffen it up after tomorrow.
    So thats my 2 cents. Hopefully this can help someone.
    Before and after pics
    cruiserguy likes this.
  2. Oct 6, 2018 at 10:29 PM
    Droner23
    Droner23 Driving the Unicorn
    Joey
    North Carolina
    2003 SR5 with locker
    None yet
    Nice man thanks for the review. I’m loookinh to do the tundra upgrade here soon.
    Can you link the kit you bought
  3. Oct 6, 2018 at 11:04 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  4. Oct 7, 2018 at 9:01 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
  5. Oct 7, 2018 at 9:05 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
  6. Oct 7, 2018 at 9:11 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    No difference whatsoever. If anything it’s firmer. I want to attribute that to the brake lines I used.
  7. Oct 7, 2018 at 9:28 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Hmm that’s interesting, i mean my truck stops bitchen I just would like a firmer pedal. Maybe I’ll get some lines made
  8. Oct 7, 2018 at 9:33 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I do believe it’s firmer than usual.
    If you really want to get complicated, you can swap in a bigger master cylinder. But I believe the results show that it makes not much of a difference.
    @Blackdawg can speak on the topic better than I’m capable of.
  9. Oct 7, 2018 at 10:37 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Thank you for this- I just got my kit in the mail (Amazon Callahan kit that looks just like the Summit option I guess) but already have extended Goodridge SS lines and was stressing on how to retain them vs. having to buy something like the LCE kit.
    Doing research to do this mod I read somewhere about a brake bleed located at the top of the rear line above the rear axle- I haven't checked on my rig yet but if its there and a lot of other people didn't know this IMO it could explain why so many people seem to have different pedal feel results from this mod.
  10. Oct 7, 2018 at 1:40 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    No problem, I had done a lot of reading about the swap and either i missed it or no one had address about that feral or the tundras using hard lines to mate with the caliper. In a perfect world I would have bought the LCE kit but because of my ignorance I jumped into this without all the facts. Removing the feral seems like the best way to modify the setup. Drilling into the bolt seems like it could be error prone and for some cause a big head ache. I also noticed a few posts about leaking banjo bolt. It seems like just jamming the banjo bolt in there with the feral is probably why they are leaking, that or they didn't replace the crush washers and its leaking from there.
    I just wanted to make a post to let people know ahead of time so when they are considering this swap they can either buy the LCE kit, get some off a donor truck, or use my method. As mentioned before theres always the drill the bolt method but to me that didn't seem like the route I wanted to go.
    (edit). Actually I bled all 4 corners but didnt do the portioning valve. Maybe theres the key
    I bet I'll get a better pedal. But theres always the master to consider but from threads I've read its not worth it.
  11. Oct 7, 2018 at 2:19 PM
    BlackSportD
    Los Angeles
    On that note where do I get new copper washers? I imagine just any ole AutoZone and specify for the taco?
  12. Oct 7, 2018 at 3:09 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    I went to this place called king bolt in covina, CA and just took the banjo with me. autozone will not have that information. I asked...i believe its a m10 banjo but I would look it up to be sure.
    BlackSportD[QUOTED] likes this.
  13. Oct 7, 2018 at 3:15 PM
    squarenut
    squarenut Well-Known Member
    russell
    FALLBROOK
    1995 single cab taco
    I scored Tundra calipers and rotors on craigslist the part # was off older Tundra.
    Fit without any mods. New brake line, rear drums and shoes. Bleed wheels and PV
    and good to go.
    Kens04Taco[OP] likes this.
  14. Oct 7, 2018 at 3:15 PM
    BlackSportD
    Los Angeles
    Shut the front door, I didn't even see that u are socal. Covina isn't that close but good to know I need to dig a bit vs going to a franchise.
  15. Oct 7, 2018 at 3:19 PM
    BlackSportD
    Los Angeles
    Those look like the 199mm but still an upgrade and digging the paint and decals. In fact I went on eBay to look for TRD decals for my kit ala speedy's garage.
  16. Oct 7, 2018 at 3:23 PM
    squarenut
    russell
    FALLBROOK
    Yes ebay decals (Paint-decals -clear)
  17. Oct 7, 2018 at 3:30 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    maybe those are the 13WGs? did you see that feral inside?
  18. Oct 7, 2018 at 3:35 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    born and raised :D
    meh a copper crush is a copper crush...if u can find it at homedepot,lowes, w/e... then grab it. just look at thickness and diameters.
