TSS Sensor Problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NINJAREC0N, Jan 13, 2024.
  1. Jan 13, 2024 at 1:48 PM
    NINJAREC0N
    NINJAREC0N [OP] New Member
    2018 Tacoma off road
    2 inch leveling kit and pro style grill
    I have a 2018 Tacoma with a pro style grill and a tss sensor garment from Amazon. I’ve been having issues with the pcs light coming on after 5-10 minutes of driving but before the light comes on it’s totally fine. Not sure what’s going on. I’ve tried using washers to level the sensor and make sure it’s centered but nothing seems to help. I bought the truck used and it already had the grill and a leveling kit on it. Any ideas?
  2. Jan 13, 2024 at 2:05 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don’t have any personal experience w it, but have read the aftermarket garnish are usually suspect.
  3. Jan 13, 2024 at 5:02 PM
    NINJAREC0N
    Yeah… So far I’m having to do trial and error with different garnishes. I’m not trying to fork over $400 for an OEM. I need some recommendations for a good aftermarket one if you have any.
  4. Jan 13, 2024 at 7:00 PM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    Does it do it with the garnish removed?
  5. Jan 13, 2024 at 9:35 PM
    NINJAREC0N
    So far, yes. The PCS light is coming on without the garnish on, but that’s without any washers added to change the angle. Does the sensor need to be pointed straight forward or should it be at a slight angle towards the ground? I’m not sure how these radar sensors should be angled. Also, do you know if it recalibrates itself after driving for a while?
  6. Jan 13, 2024 at 9:56 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    There are some proven Amazon garnishes that haven’t popped codes that you might want to try. I’ve been running this one for over a year and never had a TSS issue.
    TSS Garnish for Tacoma 2016-2023 TSS Sensor Garnish Cover TR D Pro Grille Sensor Cover Aftermarket Front Grill Radar Cover Garnish Plate Grill Insert for 3rd Gen Tacoma Accessories https://www.amazon.com/dp/B08Z7562X9
    NINJAREC0N[OP] likes this.
  7. Jan 13, 2024 at 10:02 PM
    NINJAREC0N
    Do you happen to have a lift or leveling kit on yours @TwinTaco31719? I’m thinking the leveling kit on my taco is really messing with it and causing the light to pop up.
  8. Jan 13, 2024 at 10:46 PM
    TacoVabes
    TacoVabes Well-Known Member
    22 DCSB SR5
    I just checked mine earlier cause I was having issues my screw was loose. So the TSS sensor was flopping and hanging a little. Tightened it up and drove a bit hasn't come on since.
  9. Jan 13, 2024 at 11:13 PM
    Ejctt
    Ejctt Well-Known Member
    2023 White Tacoma Off-road
    I believe that when you disconnect the negative battery terminal, it resets your computer and should give you a place to experiment on the angle if that is needed. Mine tells me it is shutting down when it rains, which it never does in the PNW, and then resets itself when it stops. Weird. I got mine from the Taco Garage.
  10. Jan 14, 2024 at 6:02 AM
    TwinTaco31719
    Eric
    Glenbrook, NV
    Oh good point. No, mine is stock suspension.
