Trying to use vacuum cleaner with electrical outlet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hiphopcr, Sep 27, 2009.
  1. Sep 27, 2009 at 6:27 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I don't know how well Margarita's and vehicles mix but it would be good for tailgating.
  2. Sep 27, 2009 at 6:29 PM
    Jason'sLawnCare
    Son of a bitch. I wanted to run my flux capacitor off of it. I guess I'll just have to get some plutonium.
  3. Sep 27, 2009 at 6:30 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I run a 100psi compressor off mine with no problems.
  4. Sep 27, 2009 at 6:33 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Toyota should up the ante with a "Worksite package". Put a 2nd aux battery to run a 1200-2000 watt inverter, an outlet in or near the eng. compartment, 1 in the cab too.
    This could easily be done as a mod for 1/3 what toyota would charges us though. Only hard part is getting a 2nd battery under the hood reasonably(would look just like the starter battery ,but would be a deep cycle).
  5. Sep 27, 2009 at 6:37 PM
    Tacoyota
    08 4wd
    Nevermind the work pkg... it would weigh around 60 lb and a whole new round of yellow stickers... 5 leaf pack springs etc:D
  6. Sep 27, 2009 at 6:40 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    This might help. A little electrical formula that will help everyone determine what can and can't be run off of the inverter.
    PIE or Power(P) is equal to Current(I) multiplied by Voltage(E).
    P/I=E Power divided by Current will tell you the Voltage.
    P/E=I Power divided by Voltage will tell you the Current.
    If you have a 400W inverter and know that the outlet is capable of 120 volts. then 400W/120V=3.33333 amps. If running at 100W then your current output at 120V is only .83 amps.
    If you don't know the power draw of an item you can look at the tag on it and it will twll you that it is rated for XXX volts and XX amps. If your running a household vacuum cleaner that draws say 10 amps then you would multiply Voltage and Current to get the power requirements of the item, in this case 120Vx10A=1200 Watts 3 times the capacity of the inverter.
    Hope this helps.
  7. Sep 27, 2009 at 6:52 PM
    Tacoyota
    08 4wd
    Here is my universal, domestic/import, portable 600watt charger i bought around 8 yr. ago.
  8. May 31, 2017 at 11:21 AM
    GLube
    GLube Active Member
    Garrett
    Replying to the original post.
    My cabin button will light up for a few seconds then go out. This is truck on in "park" , and every other configuration. Anyone got an idea?
    2006 DCSB TRD Sport manual
  9. May 31, 2017 at 11:26 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    The initial amp draw is too much...
    Benzdriver81 likes this.
  10. May 31, 2017 at 11:29 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Amperage, my friend, as mentioned before.
    But there are plenty of uses for that outlet. I've run power drills and my DA polisher off of it, just to name a couple. No, it's not very practical, but it's nice to have for small tasks when you're on the trails or the extension cord is too short :D
  11. May 31, 2017 at 11:36 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    So are you telling me I can't run my plasma cutter off my bed outlet... DAMN IT ALL!
  12. May 31, 2017 at 11:43 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Do you have something plugged into the outlet or is empty?
    I've used mine to run a soldering iron, charge my laptop, MiFi Device, portable stereo, a quick charger for my USB C phone (phone charges fully in about 45 minutes), and numerous other small electronics.
    For those saying 3k for the TRD package, that gets you alot more than a bed outlet.
  13. May 31, 2017 at 11:53 AM
    GLube
    GLube Active Member
    Garrett
    Sorry I should mention that my flicker is regardless of anything plugged in or not
  14. May 31, 2017 at 11:57 AM
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    I am puzzled by those that use it to charge laptops and phones etc - or light lights? doesn't the 12v in the cab do that very well? I figured the electrical outlet was more powerful than that - I don't have one and thought I was maybe missing out - but maybe not?
  15. May 31, 2017 at 11:58 AM
    #35
    Chase8059
    Chase
    ESVA
    Does it light up both lights briefly or just one?
    From the factory, you get 400watts when parked and 100 Watts when driving. I would make sure this is still relevant for the breif time the light does come on.
    Did you buy your truck used? Possibly from a TW member?
    A few things could be happening here, but it sounds like the breaker is tripping, or you have a loose connection.
  16. May 31, 2017 at 12:01 PM
    #36
    GLube
    GLube Active Member
    Garrett
    I'm not at my truck but I believe it lit both up and both went out simultaneously.
    I read my owners manual so I tried the 100W and 400W setups, same result.
    I bought it used a month ago and went out to May Long (Canada) and it wouldn't turn on the stereo so started investigating. Even with nothing plugged it does the same sequence
  17. May 31, 2017 at 12:20 PM
    #37
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Seriously!!! WTF, TOYOTA!?!?
    TacomaMike37[QUOTED] likes this.
  18. May 31, 2017 at 12:22 PM
    #38
    Chase8059
    Chase
    ESVA
    I don't have a 12v plug/adapter for my laptop. My phone is USB type C and a normal cable wouldn't actually charge my phone. It was just keep it charged. I ended up tapping into the converter and putting a AC outlet in the cab.
    If both are lighting up regardless of being in Park or Driving down the road, then someone has messed with the wiring so that 400 Watts is always on. From the factory it's only suppose to be 100 Watts while driving.
    If that's the case, you may want to pull your center console apart and see if you have loose connection or a crap wiring job.
