TruXedo TruXport vs Gator SRX Tonneau Cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jlevitt95, Sep 30, 2023.
  1. Sep 30, 2023 at 12:37 PM
    Jlevitt95
    Jlevitt95 [OP] Active Member
    Arizona
    '21 Cement Tacoma TRD OR
    2021 Double Cab Short Bed. I have the OEM Hard Tri-Fold and I'm looking to sell and pick up a soft roll-up cover in the price range of these two. Does anyone have experience with either or both?
    I like that the soft roll-ups are super easy to open and gives full access to the bed. My OEM hard tri-fold is very heavy to flip over and blocks 1/3 of the bed when fully open. Will I be sacrificing quality of weatherproofing moving to a soft roll-up?
    TIA!
  2. Sep 30, 2023 at 1:54 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Love me truxsport would have been fine with the gator as well seem very similar. Have co-workers with the gator who love them. For me it was price and availability. I couldn't find the gator in 6 ft.
  3. Sep 30, 2023 at 3:33 PM
    TyRoosevelt
    TyRoosevelt Well-Known Member
    Colorado Springs, CO
    2023 Tacoma TRD Offroad
    2.5 inch Dobinson Lift Accutune UCAs 285 70 17 Baja Boss Tires Method Wheels Meso Customs full blackout interior RSG Sliders Bakflip Revolver Tonneau
    I would also look at access. Gator and truxedo are ok but the access vanish is super low profile and outstanding quality. Many vendors will give you significant discounts if you ask as well.
  4. Sep 30, 2023 at 3:41 PM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    You will have to replace your bed rails when you remove the OEM cover.
  5. Sep 30, 2023 at 3:46 PM
    TyRoosevelt
    Yeah that’s true and those caps I think run around $125.
  6. Sep 30, 2023 at 5:02 PM
    Jlevitt95
    Arizona
    What do you mean? The two rails on the sides that have the sliding cargo tie-down points? Do you know the part#s for what I would need to replace with?
    EDIT: Never mind, I see what you mean. The black plastic top trim pieces of the bedside, not the "mounting rail". Part# 66248-04050 & 66249-04050. Is the only reason I would need a new one because the one I have from factory has the holes cut out for the Tonneau latching hardware? If that's the case hopefully the buyer will give me theirs since I am supplying mine.
  7. Oct 1, 2023 at 7:58 AM
    SSMTRDOR
    2020 TRD OR 4X4
    Yeah. I probably should have said caps, but yes you will need to replace them.
