Trutrac vs Yukon Duragrip?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacked Burton, Jan 6, 2020.
  1. Jan 6, 2020 at 4:29 PM
    Jacked Burton
    Jacked Burton [OP] Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    So I just got a quote from ECGS for a rear Trutrac,Yukon 4.30 ring and pinion,and master install kit $935 shipped which seems to be a sweet deal.
    While looking at Yukon's site I noticed that they have what looks to be a similar style lsd https://www.yukongear.com/productdetails.aspx?ProdID=28183.
    It says that theirs is rebuildable while Eaton says that theirs is not.
    Anyone know what the difference between the two would be? https://www.eaton.com/us/en-us/skuPage.913A541.html
    Just wanted to make sure before I pull the trigger on the Trutrac.
    MattCowsmasher likes this.
  2. Jan 6, 2020 at 4:56 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    The Yukon has clutches and springs which will wear over time requiring a rebuild which means down time for the truck.
    The trutrac which I have and love uses worm gears that never need rebuilding, in theory should last the life of the truck givin you don’t have a major failure from the rear end.
    shaeff, 12TRDTacoma, whatstcp and 4 others like this.
  3. Jan 7, 2020 at 6:41 PM
    woollypullover
    woollypullover Well-Known Member
    2019 Tacoma Sport
    Matt, How does the trutrac work with the auto LSD/VCS/trac/atrac(whatever they're calling these functions)? Is there any noticeable difference in traction when you turn off these systems?
    Do you ever wish you had gone with a locker rather than the trutrac?
  4. Jan 7, 2020 at 7:47 PM
    DG92071
    DG92071 Well-Known Member
    The TruTrac is a locker.
  5. Jan 7, 2020 at 10:12 PM
    Hobbes_4x4
    Hobbes_4x4 Active Member
    2015 SR5
    With your trutrac is there any noticable effect on-road? Do you get any tire chirping on tight turns?
    How does it behave offroad? On loose media like silt/sand/mud can you feel it kicking in?
  6. Jan 8, 2020 at 1:47 AM
    woollypullover
    2019 Tacoma Sport
    I'm not an expert but everything I've read dictates this is incorrect. I believe Trutrac is closer to a LSD than a locked air/e-locker or spool.
  7. Jan 8, 2020 at 2:41 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    It works great with the traction system I’ve had no issues with it. I notice no difference normal driving it still acts a open diff.
    I wish I had a front locker is all.
    No tire chirping or anything like that, it operates like a open diff until you lose traction.
    It behaves great you can feel a slight shudder in the seat when it kicks in that’s all.
  8. Jan 8, 2020 at 2:50 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I have been running a TruTrac in my Prerunner for many years. My truck is a 2010 and had the stupid electronic traction control.
    You asked about on road. In all the miles and years of use, never has the TruTrac chirped or hopped while turning.
    As far as feeling it kick in. No, I never had that sensation of kicking in. You as the driver do nothing. If the diff senses a slip of a wheel, the diff does it thing and drives both wheels. I have never felt it kick in, but the mirrors show the truck was using both rear tires to drive forward.
    Want to add, mine being a 2010, before installing the diff, even the slightest wheel spin would set off the Nanny with lights flashing and beepers sounding off. Now, with the TruTrac, when you mash the throttle, both tires spin at the same rate. This obviously gives better grip, but the Nanny does not see one tire slipping, so no flashing lights or beepers.
    FWIW, the TruTrac so far has also worked when reversing also. Meaning, both tires drive in reverse too.
    Marc70 and MattCowsmasher like this.
  9. Jan 8, 2020 at 4:17 AM
    DG92071
    If you say so, I can't tell if Eaton makes a Detroit TruTrac and a Detroit Locker or if they're the same part, lol.
    One thing is for sure, the Detroit TruTrac doesn't operate like any other LSD and neither does a Detroit Locker operate like any other locker.
    I've owned 4x4 with a LSD (a true LSD with clutch packs) in the front and one with a Detroit Locker in the front and they drive very different.
  10. Jan 8, 2020 at 10:05 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I have the TruTrac and I love it! I haven't noticed any unpredictable engagement in any situation. I have noticed on tight turns (wheel close to lock) in wet conditions or dry if I give some power it will lock up. But in those cases you would likely just light up the inner tire anyways. It doesn't seem to have any unpredictable engagement in snow either. I have driven many miles in sub par winter conditions (ice and snow) and have never had it lock at a time that caused concern. It doesn't lock unless you have power applied, so it will not lock up randomly while cruising if you hit a slick patch. On gravel it handles very well also. If you give it the beans on sharp turn it will drift very nicely! But again, normal driving you won't notice it. I was originally concerned somewhat as my wife drive the truck from time to time and I didn't want it to be unpredictable as she isn't the most talented driver......I would have taken it out if I thought she wouldn't be able to drive it safely.
    One semi-negative I have found is in really slow 4wd crawling it doesn't always lock. However you can generally tap the brake while the wheel is spinning and it will lock up. I have only had that happen a couple times, but it still worked great.
    EDIT: Keep an eye on ebay as well. I got mine for a touch over $400 shipped
  11. Jan 8, 2020 at 10:54 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    The "Detroit Locker" design was basically originally developed for WWII trucks and became popular in racing in the 1960s because it was the most positively locking differential you could have that would still allow you to go around a turn. This was a different design than the current TruTrac- which uses helical gears as a locking mechanism. But it looks like Eaton is kind of combining the names now which is confusing- they are not the same design. Both are more durable than the typical clutch pack differential. The clutch pack type still lasts ~forever under normal use, but it is not positive locking. None of the above are the same as a "locker" where both wheels are locked together - that isn't drivable around a turn on pavement.
    edit- this is what the inside of a clutch type "posi-traction" differential looks like. It uses flat washers and dished washers as clutches and these wear with abuse. See the second pic
  12. Jan 8, 2020 at 11:38 AM
    DG92071
    You're awesome, thank you for the great post.
    MattCowsmasher and TacoFergie like this.
  13. Jan 8, 2020 at 12:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    TruTrac is a helical geared LSD with a 3:1 biasing ratio. Great for turning, the track, and laying 11's. :D
  14. Jan 9, 2020 at 6:12 AM
    Steve_P
    TN
    Thanks, and you're welcome!
    The TruTrac design should also be safer on snow and ice since they are torque sensing and do not send power to a wheel if it has no traction. Clutch pack LSDs do and can be extremely scary on snow/ice- leading to severe white knuckle moments. I've been there, and I was driving like an old lady with an egg under my right foot.
    DG92071[QUOTED] likes this.
  15. Jan 9, 2020 at 6:44 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I keep coming back to the TrueTrac. User-friendly, quiet and nearly bullet-proof enhanced traction with no added systems necessary (compressor, plumbing, solenoids, wiring, switches, etc). I'll be adding one to my SR5/non-TRD Off-Road rear when I re-gear this year.
  16. Jan 9, 2020 at 7:40 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    You're not confusing a "clutch" type LSD with a Posi-traction are you? Posi-traction does an immediate lock up, where LSDs do a gradual lock up.
    https://itstillruns.com/identify-limited-slip-differential-7805308.html
  17. Jan 9, 2020 at 7:52 AM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    Actually found a Street Muscle article discussing the different Eaton differentials. When I think of the "Posi-traction" diff, I'm actually thinking of their Detroit Locker. Eaton's Posi-traction diff is a clutch type LSD. It should give similar performance to the Truetrac on the street, but will encounter wear on the clutch discs over time. A Truetrac should last the lifetime of the truck without requiring a overhaul.
    https://www.streetmusclemag.com/tec...ted-slip-we-look-at-four-eaton-differentials/
    MattCowsmasher and DG92071 like this.
  18. Jan 9, 2020 at 7:54 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Frucky, knottyrope and TodayWasTHeDaY like this.
  19. Jan 9, 2020 at 7:59 AM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    I drive my TruTrac in snow and ice conditions, no issues.
  20. Jan 9, 2020 at 8:01 AM
    DG92071
    Posi-traction diffs have clutches, Detroit lockers do not. I had a Detroit Locker in the front axle that had manual hubs (not a Tacoma) and it was awesome. The truck's off road capabilities went through the roof after the install. It climbed so well that the carburetor would run out of fuel from the incline angle before it lost traction, lol.
    Larzzzz and MattCowsmasher like this.
