True Dual Exhaust
Discussion in 'Performance and Tuning' started by TACOROCK, Apr 3, 2008.
  1. Apr 3, 2008 at 1:01 PM
    TACOROCK
    TACOROCK [OP] Well-Known Member
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    URD SUPERCHARGER 80MM PULLEY, DOUG THORLEY LONG TUBE HEADERS, MODIFIED Y-PIPE, TRUE DUAL EXHAUST MAGNAFLOW 2 IN 2 OUT, PRO COMP 6" LIFT, WIDEBAND 02/FUEL SENSOR, AVIC D3, 2 PIONEER SUBS ON A MEMPHIS 1200 WATT AMP RMS, DIY MOD FOR ALL INTERIOR SPEAKERS FULL TINT, LEER CAMPER, EURO LIGHTS, BILLET GRILL, BULL BAR WESTIN RUNNING BARS, AIR HORN, AND A RADIATOR POPPER
    Okay Let Me Break This Myth Down To You!!! True Duals On A Taco .1) Wont Sound Good. 2) Will Not Have Enough Back Pressure. 3) Not Enough Room. 4) Will Throw A Code!!!
    1) Bs!!!!!! It Actually Sounds Great!!!!!! I Have My Bck Cats Removed. The Same Concept As Urd Has For $500 I Had Done For $250 Pros: Cheaper Cons: I Can Not Replace It Back To Stock, Altered My Complete Exhaust Set Up.. So If You Dont Want To Go To A Shop I Would Definately Recomend Going With Urd's Y Pipe!
    2) Back Pressure ...... What Do You Think Exhaust Does!!! Gives The Engine Something To Leen On!! And Air To Try To Move Out, Its A Constant Battle!! And It Needs Some... But There Is Alot On The Taco 4 Cats!! C'mon People!!
    3) Plenty Of Room!!!! Run The Pipes Side By Side. Dont Try To Run 1 On The Drivers Side Thats Just Stupid!
    4) Rear Cats Are Not Monitored Period!!!!
    What I Had My Local Shop Do Was Cut My Y Pipe About 3" Past My Rear O2 Sensors On Both Sides. Ran The Passenger Side Straight Back To The End Of The Cab. My Drivers Side A Couple Of Bends Similar To The Stock Set Up With Out The Flat Line. And Run It Along Side Of The Passenger Side Exhaust Pipe. You Can Go A Couple Of Different Ways Here. X-pipe Or H-pipe For Alternating Flow To 2 Seperate Mufflers (flowmaster, Megan, Banks, Magnaflow Etc. And Do A Dual Exit.. Or Forget The Y-pipe And X-pipe And Get A 2 In 2 Out And That Will Act As Your Alternating Flow And Dual Rear Exit/ Dual Dumps/ Dual Center Exits....or You Could Also Do A 2 In 1 Out For A Single Side Exit.. Theres Other Things You Can Do As Well Let Your Imagination Run Wild. I Will Post Pics Later.
    DanishTaco and SpeedShift01 like this.
  2. Apr 3, 2008 at 2:37 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    hey...which place in town did u go to in order to get the rear cats removed? i've already got the catback system and i just want those rears removed.
  3. Apr 3, 2008 at 2:42 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Ha ha ha,
    seems we are on the same path of mods... how you liking that k&N?
  4. Apr 3, 2008 at 3:04 PM
    The_Hodge
    SC
    its doing good. i like the sound and the butt dyno power. i just hate the whistle from that tbs...lol
  5. Apr 3, 2008 at 3:16 PM
    TACOROCK
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    i'll tell you what.... if you guys wanna pitch in and buy me a mig welder.. we will do at my place or i can rent a bay on post. So you guys can learn at the same time!
  6. Apr 3, 2008 at 3:17 PM
    roxspin72
    NC
    Oh Yeah!!!
    Hey, that whistle only happens if you open the throttle to a certain point. For me its an indicator of open more or back off, ha ha... But yeah, if I keep it right at that throttle position, it could get annoying. But then again mine being 6 spd, it sounds cool when shifting, especially when passing some of the imports racers, keeps them thinking...:D
  7. Apr 3, 2008 at 3:23 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Thanks for the writeup. TW needs more of these...
  8. Apr 3, 2008 at 3:24 PM
    roxspin72
    NC
    Oh Yeah!!!
    Shit im down, but what about pipe bending? Just wondering how to knock that out. Or are we talking about just cutting the cats off and replacing with 2.5" stainless piping.?
  9. Apr 3, 2008 at 3:29 PM
    The_Hodge
    SC
    mine has a slight whilstle anytime i'm on the gas...regardless of the force behind it. do they have welders at the auto skills places on base? i was at the one on pope today, but i didnt notice any welders.
  10. Apr 3, 2008 at 3:39 PM
    roxspin72
    NC
    Oh Yeah!!!
    Should have.. yeah not sure about that whistle. Guess Auto and Manuall a bit diff in working the RPM power band. I tell you what though, last night I took off like a bat out of hell, ussually I test intake and exhaust once I shift to second gear, well it does no justice till you take it from first and shift though each gear at about 4000 Rpm, then I let off cause I dont want to get cought speeding. Need to find a good on ramp to the interstate that would let me open up to that 70MPH limit, and see what kind of power I really got. But for just having Intake, headers and Exh. and running about 33" agressive tires, must say this truck is quick. IMO...
  11. Apr 3, 2008 at 3:41 PM
    TACOROCK
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    i think alot of people have tried stuff... and then bammmmm it works great.. share the knowledge!!
  12. Apr 3, 2008 at 3:50 PM
    TACOROCK
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    i dont have a pipe bender.. so it would be a cut and weld back... its an option. if you just want to remove the cats... but you can have them do it with a new y pipe build on... but its your call
  13. Apr 3, 2008 at 4:01 PM
    roxspin72
    NC
    Oh Yeah!!!
    Yeah that totally went over my head, as far as an option. The reason you took out your y-pipe, is because the duall pipes you ran. If I just want to remove the damn restrictive unnecessary rear cats, all I need is what, about two 10" long pieces of stainless 2.5" piping, and the tools to cut and weld.
    Oh, and lets not forget someone who can handle tools of this such alot better than I, :eek:
    Dude I know you are going to be busy as hell, but yeah if this is what JHODGE is thinking also, I can look into the shop rental thing. If not, the shop you referred said about $200 for the Y-pipe fab replacement, should be less than $100.00 for them to just cut and replace just the cats. Hmmm...:rolleyes:
  14. Apr 3, 2008 at 4:06 PM
    The_Hodge
    SC
    if the auto skills places on post have them, i get a bay on pope for $5 an hour. i'm not sure how they work on bragg, but tools and everything like that are included on pope
  15. Apr 3, 2008 at 4:11 PM
    roxspin72
    NC
    Oh Yeah!!!
    Yup yup...
    I will investigate tommorow, both on post shop and all pro. will post with my findings then, and we can go from there. If I do this, I'd like to get it done by the meet. This and my 285/75/16 spare mod will be the final mod for awhille... My wallet is on fire, Ha Ha HA:D
  16. Apr 4, 2008 at 3:42 PM
    roxspin72
    NC
    Oh Yeah!!!
    Could not find that auto place on bragg, so no luck with the info on welder or not. Went to All Pro, they quoted 1 Bill to cut out cats, replace and weld inplace 2 straight pipes. Plus agreed to inspect entire exhaust for leaks and if need spot weld any leaks. What you think?
    Beats the $469 URD Y-pipe, and why fab a new Y-pipe for $250.00 when all that is causing restriction are the cats...
    I will run this set up til later when I can push more air into the motor...
  17. Apr 4, 2008 at 3:57 PM
    The_Hodge
    SC
    thats not bad at all. worth it IMO.
  18. Apr 4, 2008 at 7:19 PM
    TACOROCK
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    great price.... bro... thats good... if yo want to just cut and weld it just go buy a damn mig welder... we can do that
  19. Apr 4, 2008 at 7:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i say do it man!!! im going to very soon. plus its essentially the same thing as the urd y-pipe,maybe a tad more restricted......but i doubt not even enough to tell a difference between 2 pieces of straight pipe and the urd set-up. gonna sound awesome too man!!!
  20. Apr 4, 2008 at 8:14 PM
    roxspin72
    NC
    Oh Yeah!!!
    Yeah I will have it done monday morning.... I figured it will be a little more restrictive than the URD Y-Pipe, but then again I am not running forced induction, so restriction is still needed till I get a SC. Then I will run a set up like TACOROCK, but it will be Dual side outs from each side of motor, just cause Im crazy like that...:eek:
