True ANYTIME 400 Watt Inverter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toycoma2021, Oct 20, 2024.
  1. Oct 20, 2024 at 5:33 PM
    Toycoma2021
    Toycoma2021 [OP] Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    By TRUE, I mean when the truck is totally off; as in the engine is not running or the ignition is not on or in Accessory mode, etc..
    I've performed the not-so-anytime 400Watt mod in the past.
    My purpose is to be able to charge my chainsaw batteries while clearing trail either in the Spring when I find plenty of felled trees or early winter wheeling, when I also find trees down.
    I may spend up to an hour outside the truck clearing trail with the engine not running and thus the batteries not charging. This time not charging I do not wish to endure. It could mean the difference between clearing the trail and getting to my destination or not.
    Things I'm not worried about:
    1)Depleting the vehicle battery and thus not being able to start the vehicle - I have multiple batteries. One battery is always disconnected and in reserve with the truck off.
    2)Not turning the inverter off after 4-wheeling for the day. I have other accessory items not controlled by the truck ignition that I control with a master switch.
    I have included the schematic to the inverter if anyone is interested in exploring this option with me. What I do not have is a "Theory of Operation" detailing the operation of all the inverter controls.
    What I do know:
    1)I will have to supply fulltime power to the Inverter Relay on pin 2. A Pink wire.
    2)Same full-time power to pins 5&6 of the M2 Main Switch. Pink and Violet wires.
    3)My vehicle is an Autio Trans so nothing to do with the Light Blue wire on V8 pin8 on the inverter.
    What I do not know:
    Where Junction 5 Connector is located within the truck.
    What the inverter connection to the Engine ECU does? V8 pin 9, a black wire; past exploration tells me this is a data control circuit. There is no power available from this connection.
    SOLUTION: 8 November 2024
    Found the Junction 5 Connector behind the speedometer cluster on the driver's side and tied the two leads high to a switched 12VDC source.
    Also tied the pink wire of the Inverter Relay high.
    I now have TRUE "Anytime" Factory inverter.
    Picture in Post #27.
  2. Oct 20, 2024 at 5:49 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Seems like a lot of work that a gas chainsaw would avoid, I’m guessing it’s a dual battery saw?
    Curious if (autoKerrect) the 400w inverter is enough for the charger.
  3. Oct 20, 2024 at 7:03 PM
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    How about using a Jackery or similar to charge your saw batteries while the truck is off, and use the truck to top off the Jackery while the vehicle is running?
  4. Oct 20, 2024 at 7:26 PM
    Toycoma2021
    The choice was buying another gas chainsaw or try a new technology - I'm daring and picked a new technology. I currently have two batteries for the saw. One battery in use, while the other charges. This last weekend I went through 1.75 battery charges while clearing trail without an inverter in another vehicle. The inverter will also charge all my other battery tools too. The chainsaw was just to use as an example of my uses.
    Yes, the inverter is good to go on charging the saw batteries. Plugged it in while driving away from the store. Wondered the same thing and was prepared to upgrade if needed.
    I have three batteries in the truck, two are always for the vehicle only and another that is a spare but charged by the vehicle, disconnected when the truck is off and can be used for Starting the vehicle. No need for a separate device, such as a Jackery.
  5. Oct 20, 2024 at 9:18 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Maybe I'm missing something? Is there a link to the specific inverter you're referring to?
    Also, have you considered an LVD for your Accessory Circuit Master Switch? Mine works great. :thumbsup:
    helix66 likes this.
  6. Oct 20, 2024 at 9:45 PM
    Toycoma2021
    My battery setup is just fine. The inverter I’m using is the stock inverter and it is adequate to the job too. What I’m going to do is to enable the stock inverter to be able to be turned on at all times, even without the truck being on. Theoretically a simple change. Just some controlling of the power and possibly an input or two.
  7. Oct 20, 2024 at 9:55 PM
    RyanDCLB
    4/19 DCLBOR
    Got it. Hardware the stock inverter and switch so that it stays on constantly. @caribe makaira might be able to help. :thumbsup:
    Edit: If you do consider hardwiring a separate inverter w/ switch (under the passenger seat for example), then you might install a remote plug in the bed like this one for convenience. :notsure:
  8. Oct 20, 2024 at 10:34 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Which electric chainsaw are you using?
    I trail ride on a two stroke and a buddy was suggesting a battery one...I have all makita 18LXT and they make a dual battery one but my 3.5gal tank of premix makes more sense than several batteries in my backpack on hard trails.
    Chew likes this.
  9. Oct 20, 2024 at 10:42 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
  10. Oct 20, 2024 at 10:54 PM
    RyanDCLB
    4/19 DCLBOR
    For the LVD, see my posts in the Aux Fuse thread here :thumbsup:
    helix66[QUOTED] likes this.
  11. Oct 20, 2024 at 10:59 PM
    MGMDesertTaco
    Stihl ms261c and forget the inverter imo. It's lightweight and cuts through anything like butter.
    Veet-88, ridefreak, fmb and 2 others like this.
  12. Oct 20, 2024 at 11:02 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Quick peek, it looks nice, but I need the tray space for the voswitch and the same fuse panel.
    I'm looking to mount the mrcb on the battery to minimize the un-fused cable length and not sure on the lvd.
    RyanDCLB[QUOTED] likes this.
  13. Oct 21, 2024 at 6:36 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you have a spare battery, why not charge off of that?
    One thing to note, if you only need 1hr to charge, the Taco uses under 0.2gal/hr of fuel at idle. Not the greatest thing, but that is a very small amount.
  14. Oct 21, 2024 at 6:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I got a Milfuckee since my other tools are similar. Brought it along a couple times but didn't need it. I have used it around the house and think that it is pretty damn cool. But, it is pretty freaking big to pack along on a bike? I'd suggest a nice folding hand saw.
    doublethebass likes this.
  15. Oct 21, 2024 at 10:38 AM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Usually ride with a fiskars folder, nice and sharp….replaceable blade that you can’t find anywhere!!
    Chainsaw is the only way to clear fallen trees.
    I have an echo cs3510 16” bar, it’s 8 lbs.
    I can’t see a single battery saw lasting long, the dual battery saws for sure. ….also my sawzall is pretty heavy without the battery.
  16. Oct 21, 2024 at 12:17 PM
    Toycoma2021
    Saw is a Hasqvarna 350i.
    Some of my reasons for going with the electric was my old Echo was not running well, and I wanted to have something that starts when it has power. So far I really like it with the caveat of no clutch, which leaves basically on or off in the speed of the chain.
    I know of several people who ride and clear lots of single-track trails. They have mounts that have the chain bar extending down the front fork. Neat and all custom built. For that use I would keep with gas. I can't remember how they were carrying their extra gas and oil for the chainsaws. I was just mesmerized by the mounts.
    It hasn't escaped my surprise that under no load the Tacoma is more economical running than many generators. I've considered using jumper cables from the truck to my solar system if I run out of battery power for the house backup.
    As for leaving the truck running while out of the vehicle clearing trail, I just like silence in the woods when I can - Yes, the chain saw makes a lot of noise - all the more reason for wanting silence. I have disabled the 30 minute runtime limitation of the newer 3rd generation engines. Just leave the vehicle in Neutral, not Park.
    The saw batteries and the charger that come with the saw take a lot more than an hour to charge, more like 4-6 hours, don't know for sure as it is still new to me, and I just plug the battery in and leave. All the more reason for not wasting any time charging that could be used. There are optional chargers that say they charge in an hour though. If this does not work out, I may get one - have not even checked prices yet.
    RyanDCLB and tonered[QUOTED] like this.
  17. Oct 21, 2024 at 12:30 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think I have seen one of these. Thanks for jogging my memory. Probably the best location for a rider. I agree that it is wild.
    It sounds like you have it thought out.
    On the Milwaukee M18 12.0, it is about 1.5hr on the rapid charger that came with the mower. That said with the mower, a high load use, then a charge, and then a use soon after gave me bad performance. It was the first time I ever tried to do this for battery tools or radio control stuff and was enough to make me worry about doing it again. Cooling before and after charging will be my game going forward.
    Just as far as ecosystem, taking along the saw, charger attachment, and a few batteries has proven nice and convenient so far.
    I was on a trail a few years ago where it would have been great to have a saw to clean it up.
  18. Oct 21, 2024 at 1:01 PM
    RyanDCLB
    4/19 DCLBOR
    MGMDesertTaco likes this.
  19. Oct 21, 2024 at 1:06 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  20. Oct 21, 2024 at 5:25 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Those mounts are nice, but it really sucks ass on the forks.
    I have a shit backpack and stuff it in there, it still sucks but centered on the bike mis better imo.
    My 3gal tank can take me over 100mi and run the saw as much as I need.
