Truck won't turn over sometimes?
Discussion in 'Technical Chat' started by Xolude, Aug 2, 2021.
  1. Aug 2, 2021 at 10:27 PM
    Xolude
    Xolude [OP] Member
    Liam
    2010 2.7 Silver Access Cab
    2010 4cyl 5speed here. Sometimes I get in, push in the clutch, and turn the key, and depending on the truck's mood, it'll either start up just fine or not even try to turn over. I hear the relay clicking from putting the clutch in, and I get the same results if I use the clutch start disable button. Pretty tired of hoping I don't have to bump start the truck every time I get in. Any ideas?
  2. Aug 2, 2021 at 10:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Check battery terminals. Make sure they are really tight. If they are then check the rest of your wiring running to the starter. Loose bolts or nuts will cause the starter solenoid to engage but not turn the armature needed to start turning the flywheel over.
    MR5X5 likes this.
  3. Aug 2, 2021 at 10:48 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Starter solenoid is dying, wire (or connectors)to the solenoid is loose or damaged, problem with the starter relay. That’s where I would start. If the solenoid isn’t functioning properly and pushing the starter gear fully forward, it won’t switch power to the starter motor. Could even be a loose starter where the starter gear isn’t meshing with the flywheel properly because of the misalignment and not allowing the starter gear to move fully forward.
  4. Aug 3, 2021 at 6:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Test your starter using the methods shown in this video (skip to around the 5 min mark) it's on a Jeep but the concept is the same, the big wire should have power all the time and the small wire should have power with the key in the crank position and the clutch depressed.
    https://www.youtube.com/watch?v=rH_sOURHX8U
  5. Aug 3, 2021 at 7:01 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Check battery, may be time for new one
  6. Sep 28, 2024 at 6:44 PM
    volcomman
    volcomman Member
    Elliott
    Phx
    Change battery on key... transponder not making connection.... was wondering same issue and one day locked car and opened with key and wouldn't start...once I changed battery all good...2032 is size of battery
  7. Mar 8, 2025 at 4:10 PM
    volcomman
    volcomman Member
    Elliott
    Phx
    Not battery same issue happening now after fixing ground issue... fml ordered spare BCM now waiting will keep you posted if it fixes these issue
