Truck won't start/turn over after wet/cold conditions
Discussion in '1st Gen. Tacomas (1995-2004)' started by RUger714, Feb 9, 2014.
  1. Feb 9, 2014 at 12:19 PM
    RUger714
    RUger714 [OP] New Member
    Central California/Oregon
    01 4x4 2.7l
    Hi All,
    This morning my truck wouldn't start after a few days of light snow/very wet conditions here in Oregon.
    Last night, however, it started fine though the starter lagged a bit.
    When the key is in the ignition, the truck has NO power (no flickering lights, clock etc.). There are faint sounds coming from the starter when I attempt to get it running. Sounds like 1-2 second rapid bursts of very faint clicking, separated by 1 second of silence. Also, when my AC knob is on full blast, I can hear a slight buzzing, followed by what seems like dripping.
    Fuses look good, I detached/reattached terminals (there is some slight corrosion on one).
    Could it simply be a dead battery?
    Thank you
  2. Feb 9, 2014 at 2:22 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    What happens when you jump-start it ?
  3. Feb 9, 2014 at 2:26 PM
    RUger714
    01 4x4 2.7l
    I'm going to try that this afternoon if I can pull a friend in for some help, i'll report back.
    I appreciate the response.
  4. Feb 9, 2014 at 2:28 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    you'd be surprised what a dead battery does.
    but if it starts under dry conditions, i doubt thats the issue.
  5. Feb 9, 2014 at 2:30 PM
    SteveO86
    SteveO86 Well-Known Member
    South Korea
    2013 Super White TRD Sport DCSB 4x4 (Sold)
    BHLM w/ Retrofit, Window Tint, xB LED Fogs, Rigid Dually D2s w/ Amber Covers, Matt123 Skid & Tow Hook, Cobra 75 CB w/ 3' Firestik on BAMF mount, N-Fab Steps, Tonneau, Scangauge II, AVID Light Bar, Katzkin Seats, Remote Starter
    Sounds like a dead battery... Sometimes it just takes a freeze to kill them off. If it starts when you jump it, I would say your battery is toast.
  6. Feb 9, 2014 at 7:35 PM
    RUger714
    01 4x4 2.7l
    You guys were right, brought my friend's jeep over and jumpstarted just fine.
    Looks like time for a new battery eh?
  7. Feb 11, 2014 at 6:42 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Your battery could have just been undercharged due to driving habits and the cranking performance affected by colder temperatures or sulfation. You should fully recharge your battery and have it and charging system tested first, especially if the battery is less than five years old colder climates.
    Battery dealers will be happy to replace undercharged healthy battery with a new one.
  8. Feb 11, 2014 at 8:51 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Had a equipment battery die suddenly. It's a very odd thing when it does. cranking and running just fine, the next start and it is dead to the world and wont do a thing. Battery would charge up,,but once a carbon pile load was applied during testing,,the needle would drop real fast.
    Batteries used to not do that,,there was usually a slow crank warning or indicator that things were amiss,,now they just expire. Good is not cheap,,and cheap is not good.
    When I bought a new battery I also picked up one of these Jump boxes that I now keep in the JoBox in the back. Have used it a few times for stubborn equipment and such. Red button on the face runs the test circuit/gauge. 2 prong plug on the front is for wall charging it. Cigarette DC outlet for 12 stuff. HD clamps and cables.
    http://www.amazon.com/Clore-JNC660-...-N-Carry'+1,700+Peak+Amp+12-Volt+Jump+Starter
