Truck wont start, blown fuse?
Discussion in '1st Gen. Tacomas (1995-2004)' started by maximilian55, Jan 22, 2014.
  1. Jan 22, 2014 at 4:28 PM
    maximilian55
    maximilian55 [OP] Well-Known Member
    max
    washington
    95.5 Tacoma 3.4l
    So today i was working my truck and i disconnected the battery. I reconnected it and then i tried to start it. everything was normal, all the lights turned on and what not. However when i went to start the engine. nothing happened, at all. So i went back to mess with the battery and see if i forgot to connect something. And when i touched it, it sparked. All the wires are connected on, but it still wont turn over. Any ideas?
  2. Jan 22, 2014 at 4:37 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Is the battery connection clean? Even though you just removed it and put it back on, you might try some sandpaper or a terminal brush on the battery post.
  3. Jan 22, 2014 at 4:38 PM
    maximilian55
    max
    washington
    95.5 Tacoma 3.4l
    Sorta, I used some coke and cleaned it a bit. but ill find a brush and go to town on it. But it wasnt more dirty than usual.
  4. Jan 22, 2014 at 4:40 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Could have just enough electricity in the battery to power lights and such, but not enough to start the truck. I'd try to check it with a voltmeter or try another battery.
  5. Jan 22, 2014 at 4:43 PM
    maximilian55
    max
    washington
    95.5 Tacoma 3.4l
    I might just go out and try to jump start it and see how it goes.
  6. Jan 22, 2014 at 4:47 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Do you hear relays clicking, mine does this sometimes where I have to hold the key in the on position for 5 sec. then it starts like normal.
  7. Jan 22, 2014 at 5:37 PM
    maximilian55
    max
    washington
    95.5 Tacoma 3.4l
    So i jump started it, and got it running just fine. drove around a few miles and then let it idle for 15 minutes. Then i turned it off and tried to restart it. But i had the same problem. Im gonna go pick up a battery from o rielleys or NAPA. The current battery is at least 150,000 - 200,000 miles old
  8. Jan 22, 2014 at 5:48 PM
    maximilian55
    max
    washington
    95.5 Tacoma 3.4l
    any recommendations on what battery to buy? I plan to have 6 extra running lights, a winch, and maybe a sub eventually. So id like to have a pretty good battery
  9. Jan 22, 2014 at 5:58 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  10. Jan 22, 2014 at 6:00 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Check your battery wire going from battery to the starter solenoid to make sure it's tight,maybe when you unhooked it from the battery it moved down below on the solenoid, breaking the connection.
  11. Jan 22, 2014 at 6:00 PM
    maximilian55
    max
    washington
    95.5 Tacoma 3.4l
    Ya the alternator would be a forsure. I was gonna copy what blackdawg did. I actually just checked out his build to try and figure out what battery he used haha.
