Truck won't start after fuel pump repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by ManwichOfTheDead, Apr 25, 2023.
  1. Apr 25, 2023 at 6:35 PM
    ManwichOfTheDead
    ManwichOfTheDead [OP] New Member
    Drew
    Kentuxky
    1995 Toyota Tacoma
    Hello everyone!
    I purchased a 1995 Toyota Tacoma this past November, and it has been a ton of fun so far. As someone who's been a rube about auto mechanics for pretty much my entire life, I've really enjoyed getting to learn how to do more than replace a battery in a vehicle. And next to my Haynes repair manual, this site has been an invaluable resource!
    Which brings me to my problem. About a month ago, I took the truck to a mechanic because of a fuel leak caused by some rusted out fuel lines at the fuel pump. Got the fuel pump hanger and lines replaced, and the gas leak was resolved - truck worked great!
    A couple of weeks ago, though, I went out to start the truck and the engine wouldn't turn over. All the lights, the radio, etc. all turned on immediately. The engine will rotate, but it wouldn't start.
    It was parked on the street in front of my house, so we pushed the truck into my driveway so I could maybe tinker around with it after doing some reading about what could have gone wrong. Well, after we pushed the truck into the driveway, I decided to just see what would happen if I tried to start the truck again. And tada - it started! I didn't actually do anything other than push it 30 feet, so I presumed this problem wasn't actually resolved.
    Turns out I was right. I went out the following day to start the truck again, and the previous problem occurred: the engine will rotate, but it won't start.
    I'm guessing there's probably a connection that has come loose/detached related to the fuel pump work I had done recently. I've poked around the area around the gas tank and it seems to me that it's not really easily accessed. So I wanna ask y'all: is there a way to check the fuel pump connections without having to drop the whole gas tank out? From what I've seen, it seems pretty involved and, while I'm eager to learn about this truck and how to take care of it, I'm also cautious about quickly getting in over my head here.
    And I'm also open to other ideas about what I should check or rule out before diving into this fuel pump work. I just figured this was a likely culprit given the work that was done on it recently.
    Thanks everyone!
  2. Apr 25, 2023 at 9:02 PM
    GoJo
    GoJo Well-Known Member
    Utah
    You should be able to get to it from above, only the double cabs require dropping the tank. You would just need to take out the driver side bed bolts, loosen the passenger side and then proper up your bed to get to the top of the tank and fuel pump assembly to check things out and even get into the tank and see if something may be going on inside. You mentioned rusted out, maybe rust in the tank clogging the filter/pump pick up there, what about the external inline filter was that changed too?
    Rougarou680 likes this.
  3. Apr 25, 2023 at 9:17 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    What size is the engine.....
    should be able to pop off the fuel pressure regulator return hose and check for flow.....
    you need a two or three feet of spare hose to shout out onto the ground...
    If you've got fuel.....next you go to spark.
    GoJo likes this.
  4. Apr 25, 2023 at 9:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you are going to get to the top of the fuel tank, replace the fule pump if it wasn't changed a month ago. And If it were me, I'd put a new fuel filter in it too.
    GoJo likes this.
  5. Apr 25, 2023 at 9:41 PM
    O'Silver_Taco
    MD
    And dont do what I do.....
    dumbass move.....dont try to reuse an old tank gasket......
    unless you like cel lights.....
  6. Apr 25, 2023 at 9:50 PM
    O'Silver_Taco
    MD
    There's always the nuclear option....
    I have a rhino bed and a tool box to cover it up....
    so I just took an angle grinder and cut an access panel ....
    little smaller than a lunch box.....barely enough space to get pump assembly out..
    put some super foil to insulate and took less than 5 mins...
    but I work with power tools alll the time at work tho....
    learned on someone else's nickel....
    Replaced everything new.....but that stupid gasket.....
    ....what a brain fart......
    I've got it sitting right here on my desk.....still in package.....
    so yeah not looking forward to chopping thru the liquid nails......
    but the evap code says different.....
  7. Apr 25, 2023 at 10:02 PM
    O'Silver_Taco
    MD
    And yeah I've wiggled into some incredible places in front engine bay....
    but getting access to top of tank is almost completely blocked on both sides...
    believe me...I've tried....
    frame rail on one side and drive line on other....
    an 8 year old could prob get up in there......
  8. Apr 26, 2023 at 5:00 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just how long did you crank the truck before deciding it was not going to start??
    Having the hardware to connect a Fuel pressure gauge is one of my go to fuel issue tests don`t guess know .
    For the most I do all the electrical testing from the harness connection under the drivers seat.
    Unless a damaged harness is visible along the frame rail.
    The thing is you have no idea if the crank no start is fuel related have any codes been pulled??
    A cranky relay failing to close on a intermittent basis either the coil having a open circuit or contacts getting old and tired.
  9. Apr 26, 2023 at 10:17 AM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    The PO of my 2001 Tacoma did that but just put the bedliner back without covering the hole. On the 2000 model I use to have I removed the bed. Long story short, my problem wasn’t the fuel pump. It was a severed wire on one of the coil plugs.
