Truck won’t start after battery disconnect
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dtodd87, Jan 20, 2021.
  1. Jan 20, 2021 at 2:57 PM
    Dtodd87
    Dtodd87 [OP] Well-Known Member
    Dylan
    06 4.0L TRD OR
    Engine: 1GR-FE stock ARB Safari intake CSF Performace radiator Front Suspension: B8 6112 shocks B8 upper control arms Rear Suspension: B8 5160 shocks Deaver Expedition series 2 Leaf springs (stage 2)
    Hey guys,
    I just changed my headlights in my truck, and disconnected the battery for safety reasons
    when I reconnected the battery I got a clicking which stopped once I secured the bolt. But now the truck won’t turn over, electronics are on but no start
    I know Toyota has some reset you have to do but it’s been so long I don’t remember the process
    please help, thanks I’m advance
  2. Jan 20, 2021 at 2:59 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Did you fully disconnect or just remove the negative? Does your ground have a good connection? Hopefully someone with more experience will comment.
  3. Jan 20, 2021 at 2:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you have an aftermarket security system?
  4. Jan 20, 2021 at 3:01 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Only thing I can think is making sure both + & - are tight. Otherwise bad battery or needs charge, coincidence.
    12TRDTacoma and whatstcp like this.
  5. Jan 20, 2021 at 3:03 PM
    Texas T
    TX
    '14 T Force
    I’ve fully disconnected and replaced mine and never had to do a reset. Aftermarket anti theft might be a thing though.
  6. Jan 20, 2021 at 3:03 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    I disconnected the negative
    both are secure as well as ground, battery is three months old and no aftermarket security system
    if I remember correctly it has something to do with Toyota’s manufactured security system that needs a reset
  7. Jan 20, 2021 at 3:04 PM
    Texas T
    TX
    '14 T Force
    Do you have your manual? Again never had to do it with mine.
  8. Jan 20, 2021 at 3:05 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    Going through that now as we speak
  9. Jan 20, 2021 at 3:05 PM
    Texas T
    TX
    '14 T Force
    The clicking sound and then no clicking sound tells me your battery needs a charge
  10. Jan 20, 2021 at 3:06 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It's normal for it to start and stall after a battery disconnect. On the 2nd attempt it will start. Or you can just leave the ignition on for a few seconds and it will usually start on the 1st try.
    But it sounds like you have something else going on.
    Did you remove the negative post 1st and reconnect it last? If not, you could have accidentally grounded the positive
    12TRDTacoma likes this.
  11. Jan 20, 2021 at 3:06 PM
    Texas T
    TX
    '14 T Force
    It doesn’t matter how old it is cold weather will drain a battery
  12. Jan 20, 2021 at 3:11 PM
    TnShooter
    Deogee
    STOCK
    To clarify, the truck does not crank? Correct?
    Or does it crank and not start.
    Can you give us a picture of your key fob?
    I’d start by check the battery voltage while cranking.
    You might try the 7.5A STA and the 30A fuse.
    Those are the fuse that have to do with the starting circuit.
    You also need to be sure the gear shift is in park or neutral.
    Other wise the STA relay will not work.
    Jimmyh likes this.
  13. Jan 20, 2021 at 3:11 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    Puts a battery tester on it to make sure and it’s fine
  14. Jan 20, 2021 at 3:14 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    No click right? I had this a few years ago and it was related to the security system. Took me way too long and I stashed away my notes. Going to try to find the stash lol ... but no click right? In my case it was security related. Looking ...
    Dtodd87[OP] likes this.
  15. Jan 20, 2021 at 3:14 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    clicking with no crank or start,
  16. Jan 20, 2021 at 3:17 PM
    TnShooter
    Deogee
    STOCK
    Looks like the OEM fob.
    So we can pretty much rule out aftermarket alarm
    Mine looks the same.
    I have never had to reset anything after a battery disconnect.
    Does the truck NOT crank?
    Or does it crank, but not start?
    whatstcp likes this.
  17. Jan 20, 2021 at 3:19 PM
    Plain Jane Taco
    USA
    A voltage check doesn't mean much. Make sure it's a load test
  18. Jan 20, 2021 at 3:20 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    this is the issue I believe, I didn’t write it down and am having trouble finding it
    no crank or turn over, electronics are on but nothing when I turn the key
  19. Jan 20, 2021 at 3:20 PM
    Plain Jane Taco
    USA
    I'm still leaning towards this for now
  20. Jan 20, 2021 at 3:22 PM
    TnShooter
    Deogee
    STOCK
    Let’s hope not.....:fingerscrossed:
    Some of the bigger fuse are no fun to replace.
