Truck will start but won't move
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kbUSMC2012, Aug 1, 2018.
  1. Aug 1, 2018 at 12:40 PM
    kbUSMC2012
    kbUSMC2012 [OP] Well-Known Member
    Kevin
    2019 TRD Off Road 4x4
    Started my truck this morning, tried putting it in gear and the shifter moved just fine and on the electronic display in the dash it shifted to Drive, but gave it some gas and it would not budge. Put it back in park, tried shifting to drive again, and it would not move. Tried all the low gears, tried reverse, tried lifting and releasing the parking brake, nothing.
    Got the shit towed to Toyota for them to take a look, but out of curiosity, anyone ever seen this before?
    HondaGM likes this.
  2. Aug 1, 2018 at 12:42 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Another one of these, dang. Next time, if you have 4wd, engage and hit the gas as hard as you're comfortable to see if it'll unlock. Seems the brakes get stuck. Good luck.
    HondaGM, Saeid.R, Reserved67 and 2 others like this.
  3. Aug 1, 2018 at 12:50 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Give it a lot of gas or bang on the rear brake drums with a hammer or something to help release the brake shoes.
    HondaGM and Saeid.R like this.
  4. Aug 1, 2018 at 1:04 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Definitely this! To start with this could be the culprit. I’ve had it happen very briefly twice to mine. Just tried reverse and the drive and it popped right out of it. Sometimes if you wash it or don’t drive it for a few days the drums can stick a bit. Tell us what happens!
    HondaGM and Reserved67 like this.
  5. Aug 1, 2018 at 1:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    wilcam47, HondaGM, BillsSR5 and 4 others like this.
  6. Aug 1, 2018 at 1:12 PM
    specter208
    California
    I'm a Yard Shifter and tandem axle trailer brakes almost always freeze after a few minutes. Solution is to use a lot of throttle.
  7. Aug 1, 2018 at 1:13 PM
    RustyTrumbone
    RustyTrumbone Well-Known Member
    Phil McCracken
    2018 Tacoma SR5 Short Bed
    when it got towed did the rears drag or roll?
    HondaGM and xxTacocaTxx like this.
  8. Aug 1, 2018 at 1:20 PM
    Whitetail Assassin
    Tedric
    West Virginia
    Once mine did it when it was cold out and the other time it was warm out. Luckily I had seen the threads about this issue. Otherwise I would have been freaking out! Easy fix.
    HondaGM and specter208[QUOTED] like this.
  9. Aug 1, 2018 at 1:25 PM
    specter208
    California
    I don't think I've had this happen to mine yet. I'm guessing this happens a lot in humid enviorenments. One night I think my brakes might have been dragging cause I heard a quiet metal screeching sound but it could have been the wind for all I knew.
  10. Aug 1, 2018 at 1:27 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    HondaGM and Skeou like this.
  11. Aug 1, 2018 at 1:42 PM
    kbUSMC2012
    Kevin
    Don’t know. Had to take my wife’s car to work.
  12. Aug 1, 2018 at 4:06 PM
    kbUSMC2012
    Kevin
    So they towed it on a flatbed truck so I don’t know how it got on there, but apparently when they got it to the dealer the tow truck guy hopped in my truck and just fuckin drove it off and parked it. The dealer called and said they can’t see anything wrong with it and it’s been driving fine, but when I asked them about the brake drums being stuck he told me “No, that would give off an ECU code and we would have seen it. Definitely not that.” He suggested it might be a cold start issue. Guess we’ll see tomorrow. Does this guy know what he’s talking about?
  13. Aug 1, 2018 at 4:33 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Dragging it onto the flatbed, or driving it off the flatbed, broke the rear brake shoes loose, so everything is back to normal now. That guy isn't aware of the common issue of the rear brakes "freezing" to the drums. It's a mechanical issue that won't throw a code. His "cold start" comment is laughable.
  14. Aug 1, 2018 at 4:43 PM
    Jaino
    Jaino Well-Known Member
    Northern Cali
    17 Tacoma 6spd Offroad
    Man just had this happen to my old mans truck. Literally happened last Saturday, old man had the truck sit for about 3 weeks, parked on an incline with e brake engaged. Came home, started the truck and had the exact symptoms you’re having. I’m surprised your tow truck driver was able to get it on a flatbed, they towed my dads backwards with the ass end up.
    Toyota emailed us on Monday saying that this is probably a brake based problem, and gave my dad a rental. Haven’t heard from them since.
    I should’ve checked on here first before we called the tow truck driver, sounds like an easy fix but I didn’t want to chance it. Now who’s knows how long they’re going to keep the truck.
    HondaGM and TashcomerTexas like this.
  15. Aug 1, 2018 at 5:23 PM
    kbUSMC2012
    Kevin
    How can my brakes “freeze” to the drum? It’s been 90+ degrees for months here.
  16. Aug 1, 2018 at 5:59 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Are there skidmarks from where it was parked?
    Also I'm not sure the truck would throw a code for stuck brakes. I've never seen that mentioned here.
    HondaGM and shakerhood like this.
  17. Aug 1, 2018 at 5:59 PM
    Lt. Dangle
    Ohio
    Think stuck, not actually frozen as in cold. Rust can form quickly in the right conditions.
  18. Aug 1, 2018 at 6:21 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    An ECU code for stuck brakes ? Ask him what the code number for that might be.
  19. Aug 1, 2018 at 6:33 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    What is the humidity level and has it rained in the last day or so?
    Also, asks for that guys name that said there would be a code for stuck drum, and request that he does not go anywhere near your truck.
  20. Aug 2, 2018 at 8:04 AM
    kbUSMC2012
    Kevin
    Humidity is off the charts here man.
    HondaGM likes this.
