Truck smells like rancid gym sock after rain
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Aug 16, 2015.
  1. Aug 16, 2015 at 2:00 PM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I don't know if there is some sort of moisture leak somewhere or what, but every time it rains and my truck sits out in it, the cab ends up smelling like a cat pissed in it or a hamper full of post-game basketball socks have been sitting in the truck. Not sure what I should be looking for. Any ideas? All the carpet is dry when I check it.
  2. Aug 16, 2015 at 6:02 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    we used to have a cat that did just that, piss in the hood cowling vent and when it rained and got wet it smelled horrible inside.
    go to car wash and spray the hell out of the fresh air vent at the back of the hood and then see if that helps.
    as long as a cat smells its own piss there it keeps "reapplying" fresh piss on top of it to mark his territory.
    clean the area best you can then mix 50/50 pine sol and water and pour a good bit of that all over the vent. your trying to cover up his scent so he goes elsewhere to mark his territory. it may even be more then one cat with another pissing on top of the first cats piss in a turf war over claiming your truck
    that said, it could also be funk in your a/c not draining, does it get funky when the a/c starts making water? if so clean out the a/c drain, that stuff can smell like sewerage sometimes.
  3. Aug 16, 2015 at 6:07 PM
    DrFunker
    DrFunker Well-Known Member
    Got any hints of how to do that?
  4. Aug 16, 2015 at 6:10 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Have you checked your cabin air filter? They should be changed at least annually, if not more frequently. I know they sell ones that are charcoal impregnated to combat odors. They can pick up dust, mold, and other debris that could become smelly when they come in contact with moist air during a rain? Anyway, it's simple to pop it out and see and cheap to replace.
  5. Aug 16, 2015 at 6:11 PM
    DrFunker
    Good point.
  6. Aug 16, 2015 at 6:17 PM
    mountainwolfpup
    Vancouver, WA
    You would know if your AC drain line was clogged (unlikely btw). But if it were clogged the drain pan would overflow and the carpeting under the glove box would be noticeably wet (not just damp, but totally wet). And even if this was happening I doubt it would smell like "cat piss". Probably smell more like musty wet carpet. The water in an AC is compressed out of the air and is therefore pretty clear and pure (now I'm not saying that I'd drink it, but it looks like tap water).
  7. Aug 16, 2015 at 6:19 PM
    DrFunker
    Was thinking that the carpet would be soaked. The reason for my asking is that I did the AC divert when it was cooler out and now with the warmer weather, I have been running the AC a bit but haven't seen water. I think I am just being paranoid that I eff'd up the divert.
    Thanks for the assurance.
  8. Aug 16, 2015 at 6:32 PM
    keakar
    karl
    louisiana
    same way the cat piss goes in, from the top, and rinse/flush the area best as you can.
    no way to get in there to clean it unless you want to unscrew the grill and even then there is a lot of area piss can drain to that you cant reach so car wash pressure washer would be my first choice followed by pouring a gallon or so of pine sol water all over in it after
  9. Aug 16, 2015 at 6:48 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Mine smelled at one time. Water was leaking under my hood down the drivers side firewall where the wires go through a big grummet and getting under the carpet on the drivers side floorboard.
  10. Aug 16, 2015 at 6:52 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    mine was leaking from same spot too. Pulled it out to run some wires for lights and forgot about it.
  11. Aug 16, 2015 at 6:53 PM
    Toyota4x46921
    Michael
    Warner Robins, GA
    I tore mine running an amp years ago
  12. Aug 16, 2015 at 6:54 PM
    DrFunker
    Will a little dab of silicone work?
  13. Aug 16, 2015 at 6:59 PM
    Toyota4x46921
    Michael
    Warner Robins, GA
    Yep.....I put a big glob of that shit around it and squirted it where the wires run
  14. Aug 16, 2015 at 7:00 PM
    DrFunker
    Fixed?
  15. Aug 16, 2015 at 7:01 PM
    Toyota4x46921
    Michael
    Warner Robins, GA
    Yep no leak for 6 years or more
    devinzz1 and DrFunker like this.
  16. Aug 16, 2015 at 7:10 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    1st Gens don't have a cabin filter.
    As others have mentioned, check the air intake underneath the windshield and that the AC is draining properly. Might have to pull the carpet or the dash out to see if you have any wet/rust spots to give you a better clue on where the water is leaking in and pooling.
    Wulf likes this.
  17. Aug 16, 2015 at 7:32 PM
    mountainwolfpup
    Vancouver, WA
    Hmmm. I can't believe it but you are correct tomtom, 1st gen has no cabin air filter. Thanks for the reality check :)
  18. Aug 16, 2015 at 7:45 PM
    tomtom
    The Desert SW
    2012 FJ
    As a guy with massive allergy and sinus problems, I really, really, really wish they did.
    I should have ponied up the money for a 2nd gen before sinking so much into my 1st gen.
    Wulf likes this.
  19. Aug 16, 2015 at 8:49 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Going in sig. Still laughing my ass off. :rofl: #outdoortruckproblems
    That being said, I'll try the pine sol trick. The smell goes away after the truck dries. And I don't think it's the AC drainage because it doesn't smell when I use the AC (only after rain), but I tried to look for the tube one day to check it but couldn't find it.
    I've seen someone stuff some sort of filter material somewhere but it looks like it'd be a PITA to do and a PITA to have to periodically replace so I never tried it.
  20. Aug 17, 2015 at 10:04 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Passenger side firewall in the engine bay. Short black one or so inch nipple/hose thingy sticking out.
