Truck making noise ONLY when I'm turning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KrnTaco08, Jan 4, 2017.
  1. Jan 4, 2017 at 6:27 AM
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    So my 2008 Tacoma makes "humming/rubbing" type of noise ONLY when I'm turning in the front tires. The noise gets worse if I'm making really slow turns. For example, backing out of my driveway, parking lots, etc. My truck is completely stock.
    I'll be taking my truck to a local mechanic today and just wanted to get a heads up before I get thrown into the wolves.
    Thanks guys.
  2. Jan 4, 2017 at 6:32 AM
    Chrisf06
    Chrisf06 Well-Known Member
    Bogart, Georgia
    2014 MGM Tacoma DC TRD Off Road
    sounds like your tires are rubbing. look under the front fenders and see if you can find black marks where the tires are rubbing at full lock. Backing up slowly is generally the worst rub.
  3. Jan 4, 2017 at 6:35 AM
    KrnTaco08
    LA
    2017 Taco
    My truck is completely stock though. I've been on 265/70/17 for 8 years and never had rubbing issues
  4. Jan 4, 2017 at 7:22 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    Have you checked your power steering fluid? If it gets low the pump will start to make noise when turning, usually what I would describe as a buzz or howl.
    KrnTaco08[OP] likes this.
  5. Jan 4, 2017 at 7:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Could be a wheel bearing also. Have him check it with the tire and caliper removed.
    jhrttn1983 and KrnTaco08[OP] like this.
  6. Jan 4, 2017 at 7:41 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    check your rack and pinion.
  7. Jan 4, 2017 at 7:44 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Does it only do it when turning one way? I would guess wheel bearing as well if so.
  8. Jan 4, 2017 at 8:58 AM
    KrnTaco08
    LA
    2017 Taco
    I appreciate all the input. I told the mechanic all the possibilities you guys provided me.
    I'll keep you guys posted. Much appreciated
  9. Jan 4, 2017 at 10:01 AM
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    wheel bearing
  10. Jan 4, 2017 at 11:50 AM
    uwu
    uwu Well-Known Member
    Don't turn, problem solved!!!
  11. Jan 4, 2017 at 11:56 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Sounds like a wheel bearing, no pun intended. (well, O.K., maybe just a little...)
    Mine did the same thing. Fine while going straight, growled on turns.
  12. Jan 4, 2017 at 2:29 PM
    Pirahna
    Pirahna Well-Known Member
    Prunedale, Ca
    2012 Black T/X Baja DC
    Mine did the the same while turning right on some turns. Turned out to be the passenger front wheel bearing.
  13. Jan 4, 2017 at 2:29 PM
    KrnTaco08
    LA
    2017 Taco
    I'm at the shop and they think it's a "rear diff" problem. The rear tires " vibrate" when making slow sharp turns.
    Update* I replaced the rear diff oil yesterday. Apparently they didn't add " the friction modifier fluid" ( whatever that is) with the change so they think that could be the problem.
    They knew they messed up and they're going to re-do the rear diff again. Does that make any sense to you guys??
    Also, I drove around like that all day. Should I be worried that they messed up my rear diff??
  14. Jan 4, 2017 at 2:44 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Well, IF that doesn't make a difference, have the front wheels spun slowly while it's on a lift, and listen for grinding/crunching noises.
    "Friction Modifier Fluid"? Snake oil in a fancy container??
  15. Jan 4, 2017 at 2:54 PM
    KrnTaco08
    LA
    2017 Taco
    Yeah.. I was like " a what modifier?" Haha. He showed me the rear tires vibrating when turning.
    Felt like the truck was in 4wd and trying to make sharp turns. Looked like the tires were sorta "skipping"
    Hopefully this fixes it.
  16. Jan 4, 2017 at 3:03 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Yep, 2008 has the true LSD, and needs that modifier.
    Crom and KrnTaco08[QUOTED][OP] like this.
  17. Jan 4, 2017 at 3:12 PM
    KrnTaco08
    LA
    2017 Taco
    Should I be concern with any rear diff damage? I drove around 20 miles before taking it back to the shop.
  18. Jan 4, 2017 at 3:29 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I wouldn't worry about it. Have them add the friction modifier fluid and you should be good.
  19. Jan 4, 2017 at 4:26 PM
    KrnTaco08
    LA
    2017 Taco
    **Final Update**
    It was indeed the " modifier fluid" for the rear diff. My truck feels brand new compare to yesterday.
    Thank you for all the replies and I've learned something new today.
    tomwil, 98tacoma27 and Crom like this.
  20. Sep 1, 2019 at 3:40 PM
    OrangieTaco
    OrangieTaco New Member
    Gerardo
    2018 Orange Tacoma TRD Sport
    Changed front grill
    Hi all,
    I have a 2018 Tacoma TRD Sport completely stock. When backing up, and turning the wheels to the left or right all the way, and when changing to Drive and straighten the wheels I hear a noice coming from the front. I am not sure if this is normal or if something is not right with the truck? I had a 2016 and it made the same noise, kinda hard to describe but sound like "clacking" sound. I was told by the mechanics a the dealership that this is normal, that it's coming from the drive shaft, that when cold it locks and when changing gears you can hear it. I am so confused . Wondering if anybody else have notice this sound coming from the front.
