Truck feels like it's sliding on a slick road even in dry conditions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by critterdamage, Dec 28, 2023.
  1. Dec 28, 2023 at 7:39 PM
    critterdamage
    critterdamage [OP] New Member
    2015 Tacoma Sport
    Recently when driving at highway speeds my truck feels like it is struggling to maintain traction as if the road is wet or icy, but it happens when the road is completely dry. Especially when turning at those speeds it has the sensation that my rear is going to slide out and I'll go into a fishtail, but it doesn't.
    At lower speeds it has actually started to fishtail especially if roads are wet, which is new in the years I've been driving it so it's not that I'm too heavy footed or suddenly need weight on the rear axle.
    It's a stock 2015 sport with fairly new BF Goodrich trail terrain tires, and I just had an alignment and the tires balanced but the shop didn't see anything else.
    Any ideas of where to look or what could be causing this would be appreciated because it's driving me crazy and makes driving the truck feel unsafe.
  2. Dec 28, 2023 at 7:42 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    Was any other suspension work done recently?
    Also what are your tire pressures at?
  3. Dec 28, 2023 at 7:54 PM
    TacoTuesday1
    FL
    Stock shocks are bad. Probably not in alignment.
    Sugar Silva likes this.
  4. Dec 29, 2023 at 3:41 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    How many miles on it? Check your tire pressure. Improper inflation can cause this as can worn suspension. Is the front sway bar still in? I know a lot of people remove these thinking they’re offroady.
    lynyrd3 likes this.
  5. Dec 29, 2023 at 4:21 PM
    TacoTuesday1
    FL
    OP said rear
  6. Dec 29, 2023 at 7:08 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Curious about tire SIZE AND PRESSURE. If you deviate from the stock size, the air PSI changes.
  7. Dec 30, 2023 at 9:11 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    If you switched from P rated tires to LT you have to increase the air pressure in your tires or it will ride like it is going to spin out. I am running LT265/75 R16 and I had to increase the air pressure to 38 to 42 psi.
  8. Dec 31, 2023 at 3:44 AM
    cmoore
    cmoore Well-Known Member
    Charlie
    Dallas, Texas
    PreRunner
    When my Tacoma was new it felt like the front end was in the air all the time. That feeling went away when I had decent tires installed. Michelin's.
  9. Dec 31, 2023 at 4:41 AM
    Clearwater Bill
    Billy
    Largo Florida
  10. Dec 31, 2023 at 5:32 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    It’s your tires. Assuming you’re a new driver?
  11. Dec 31, 2023 at 5:45 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Other than what was already mentioned, bad swaybar links might cause similar issues.
  12. Dec 31, 2023 at 5:48 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Put 100 pounds in the truck bed. Balanced over the axle is preferred.
  13. Dec 31, 2023 at 8:44 AM
    TacoTuesday1
    FL
    Front sway has nothing to do with rear end.
    also, throw it out.
  14. Dec 31, 2023 at 8:48 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    If he's drifting around like I imagine, it can be difficult to tell if it's coming from front/rear.
  15. Dec 31, 2023 at 8:49 AM
    TacoTuesday1
    FL
    drifting means rear.
    his shocks are bad.
