Truck Bed Tuning Bench: Bad Idea Jeans?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hafjell, Jan 14, 2023.
  1. Jan 14, 2023 at 9:39 AM
    hafjell
    hafjell [OP] Well-Known Member
    Idaho
    2023 TRD OR MT
    I'm hoping to use the bed slots for a 2x6 or 2x8 which could serve as a base for travel vises or even just slots for diamond stoning and waxing skis. Anybody ever do this? How would you keep the 2x8 secure?
    Unless you removed the gate (not going to happen) it seems like an ergonomic disaster, but maybe if you're only working on one pair, you could sit in the bed?
    Just keep it simple and go with this? https://www.swixsport.com/us/tools/tables/t77-3-professional-world-cup-table/?item=T0077-3-V
  2. Jan 14, 2023 at 3:54 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i would run a long bolt/all-thread up to the mounting rail and thread a bolt down to force the 2x8 to stay in place.
  3. Jan 14, 2023 at 5:33 PM
    hafjell
    Idaho
    2023 TRD OR MT
    Run it from where?
  4. Jan 14, 2023 at 5:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I would use a bench design that adjusted to wedge the bench from side to side. Think a threaded rod that can be extended. I would use bed stiffeners tho.
  5. Jan 15, 2023 at 4:52 AM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    I feel like you could build something that bolts to the tailgate using oem bolt locations
    hafjell[OP] likes this.
  6. Jan 15, 2023 at 5:13 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    How heavy are the vises?
    A lot of folks use the rails inside the bed to mount items such as shovels and high lift jacks, so if similar in weight maybe this idea would work:
    Google “T nut”. What you could do is mount a plate (maybe 3 inches by 6 inches) to the bed rail using a couple t nuts. Then mount a carriage bolt vertically down from that plate to the 2X6 planks. This would give you some vertical rigidity to the planks mounted in the molded bed slots.
    My main concerns are:
    - would all that stuff become a missile into the back of my head if I got rear ended?
    - would all that stuff be a PITA to remove if I needed to use my bed to transport something?
    The Swix table (and a locking bed cover to protect it while you ski) might just be the best option.
  7. Jan 15, 2023 at 8:34 AM
    soundman98
    NW Indiana
    the side accessory rail
    hafjell[QUOTED][OP] likes this.
  8. Jan 15, 2023 at 10:05 PM
    hafjell
    Idaho
    2023 TRD OR MT
    This is a good idea. Which ones are fair game?
  9. Jan 15, 2023 at 10:07 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Are you a ski racer or something?
  10. Jan 15, 2023 at 10:11 PM
    hafjell
    Idaho
    2023 TRD OR MT
    Parent.
  11. Jan 16, 2023 at 1:43 AM
    GBourne
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    as I think about it more, I’d get one of the steel tailgate panel replacements and replace the plastic OEM cover, then through bolt a setup to that using large fender washers to help distribute the load.
  12. Jan 16, 2023 at 1:59 AM
    HighCountryTacoma
    Colorado
    It wont impress the other ski dads but you could buy a 6x6 wood post chop it in to two foot long sections and wrap it in carpet or glue some foam or rubber on top. Cut a one or two inch deep slot in the middle for doing the side edge or sidewall planing and just put them on the tailgate.
    hafjell[OP] and bulalo like this.
  13. Jan 17, 2023 at 7:53 AM
    hafjell
    Idaho
    2023 TRD OR MT
    I've had good success with this approach using old bike tubes. Looking for less flex, but more stability. Hadn't considered 6x6" so thanks for the advice. That'd be more stable.
  14. Jan 17, 2023 at 7:54 AM
    hafjell
    Idaho
    2023 TRD OR MT
    Do you recommend a model?
  15. Jan 17, 2023 at 12:46 PM
    HighCountryTacoma
    Colorado
    I’ve got the relentless off-road one, I like it.
  16. Jan 17, 2023 at 2:32 PM
    hafjell
    Idaho
    2023 TRD OR MT
